Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
After turning the radio signal off in the D-Link 624, it doesn't allow connectivity. Makes sense, but how do I get back in to turn the radio back on?
  • 820 Answers
There's an online manual:
manual
The login to the router is: http://192.168.0.1 (factory default login):
User name is: admin
Password: [leave blank]
In case the password has been changed earlier you'll have to perform a default reset by pushing the reset button with a e.g. paperclip on the rear side for 10 seconds and then releasing it: After this the router will reboot to the default factory settings.
Check "Broadcast SSID" = radio signal:
See page 29: in the router select Advanced > Performance:
SSID Broadcast should be enabled: Apply to have settings saved.
Check broadcast SSID name and WEP security access:
See page 13: in the router select Home > Wireless.
Posted on Sep 10, 2009
  • YourZEN
    YourZEN Sep 10, 2009
    Copy and paste the link between the brackets in the address bar
    and enter for the manual link ( fixya has put an extra unwanted link in front):
    [ ftp://ftp.dlink.co.uk/di_broadband_gateways/DI-624_rev_cx/di-624_rev_cx_man_v104.pdf ]
2002 TT roadster battery goes dead. pulling fuse 42 stops the drain on the battery. what is the likely problem?
I dunno, just a couple of guesses...do you leave ur radio "on" when you turn off ur car?...if radio amplifier causing prob, this would b the easiest to put a on/off switch on it..in the end if everything fails, get an on/off for positive battery side...
Dec 18, 2013 | Audi TT Cars & Trucks
My Behrigner SO400 Unit doesn't bypass the signal!! It only works when the unit is turned on...it makes no sense! Thank you
Often the problem is the switch itself is broken internally. Test contiuity with an ohmmeter. If one really stomps on these the mechanism in the switch can easily be broken. Often the switch directely connects input and output with contacts and if those break, no bypass will be done but the effect position might still get through.
Jul 06, 2011 | Behringer SO400 Super Octaver Stomp Box...
I'm from Ukraine and is weak in English. A child accidentally pressed the program MOBILINK radio off. USB720 modem please help. Give a realties software than to fix radio modem off SB720. During the...
I also have this problem! MobiLink3 software allows you to turn radio off, but apparently doesn't provide a way to turn the radio back on! Radio is now disabled internally in the USB device itself, and LED will not come on even if I plug the device into other computers. Crazy!
Apr 24, 2011 | Novatel Wireless USB720 (NOVSB720USBMM5DB)
DI-624 always lost connection after use about 10mins. to 20 minutes
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arid welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply)
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Nov 16, 2009 | D-Link DI-624 Air Plus XtremeG Wireless...
Spare Di-624
Well, if you run a LAN cable from your existing router to the DI-624 in a remote location you could use it as an AP, but this router does not support repeater of bridge modes.
May 24, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Ok i do all the set up right when i turn off my dsl modem the turn it back on it says i dont have internet and wen i plug it in normaly it works i have the d-link di-624 air extreme ....i dont kno why does...
You need to power cycle your devices. Make sure the modem is connected to the WAN port of your router and your PC to port 1. Unplug the power to the router and modem. Wait for 30 seconds. Turn on the modem first, wait for the lights to be solid, then turn on the router. That should do it.
Apr 02, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Lights are solid green: WAN, local network 1,2,3,4
If that is status of the lights on your router there's a big possibility that its already bad and needs a replacement, but you can first try to reset it and check if that will correct the problem
, To reset the router just press and hold the reset button for 30 seconds while the power is ON then after that check if the lights are back to normal if still the same light router is already bad...
Dec 01, 2008 | D-Link AirPlus Xtreme Super-G DI-624...
Communicating my laptop with my Dlink 624 router
first, you need to make access by cable (rj45), may be has the router adreses 192.168.1.254 0r 192.168.1.1, & make configurations for the wi fi from the router
Jul 20, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
D-Link DI-624 won't work!
hi thanatos
try resetting the router back to default settings by holding in the reset button for 30 seconds this is found on the back of the router you will need a small pointed pencil or paperclip to do this
Feb 08, 2008 | D-Link DI-624 Air Plus XtremeG Wireless...
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
227 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
