Question about Garden
I have a DeVilbiss pressure washer, Serial# 2251136878, Model# WVRH2421, Radial Pump# D28703, with a 5.5hp honda motor. It has no pressure. If the pump can't be fixed, is there another brand of pump that will fit this model pressure washer?
    President:
  • 583 Answers
THE PUMP FITS THE MOTOR and the pump i always use is a ROYALPUMP made in Italy and they are long lasting and easily serviced ,any of the Italian pumps are good
Posted on Sep 10, 2009
Excell pressure washer
What is your model #
http://www.ppe-pressure-washer-parts.com/excell-devilbiss-pressure-washer-replacement-pump-parts
Nov 03, 2013 | Homelite For Excell - Pressure Washer Pump...
Motor runs but no water pumps through
It's possible that the 'unloader' in the pump is plugged. A local small engine repair shop can replace it (generally under 50 bucks). Of coarse you have the hose hooked up to it and the water on.
Mar 19, 2013 | Devilbliss DeVILBISS Devap DVH2600...
I need a owners manual for a pressure wahser GCV 160 from honda
MiTM will have that. See mitm.com Honda makes the motor but not the pressure washer. Honda does have manuals if you need one for that GCV160 motor.
Oct 20, 2012 | Mi T M Chore Master Pressure Washer - 5.5...
Motor turns over but seems to be a lot of pressure on it . it kicks back hard
Make sure you are holding the trigger and water is spraying while you are trying to start it, otherwise pressure will build up in the pump and it will kick back.
Jun 06, 2011 | Devilbliss DeVILBISS Devap DVH2600...
Have a Honda Gc series 2.0 Gpm 4.0 hp gas powered pressure washer model 01195-0 that the pump has went out in and am having problems finding parts ( seals and unloader valve ) I have googled but no luck...
Honda has nothing to do with this pressure washer, other than it has a Honda motor. It is made by Generac. The pump is a cheap pile that can be replaced with a horizontal mount AR Pump for a decent price. The pump that came on the unit is not worth rebuilding. Try looking for an AR Pump RMV2G25 as a replacement.
Apr 01, 2011 | Honda Garden
Have a honda 5.0 hp engine on a pressure washer model belive is a de 1504 not sure of make, starts if you use starting fluid but then dies, getting gas to the bowl at botttom of carb but not to carburator
Hi there mburns44 i believe your problem is either that either the Air/Fuel mixture is too rich and causing it to flood or you have clogged jets. carburators are tricky and often times need to be cleaned or adjusted by a professional. I hope that this helps :)
Mar 30, 2011 | Devilbliss DeVILBISS Devap DVH2600...
I have a 3000 PSI Honda pressure washer. The motor
May have sediment buildup in the pump housing, ???
Jun 04, 2009 | Honda Pressure Washer PSI 3000
What kind of oil do i use in pump for devilbiss exwgc3240-1 pressure whasher
Dear jim_5,
Most domestic pressure washers use normal multi-grade engine oil. 15/50 wil be good. Industrial and high pressure washers usualy use gear oil (90 sae).
Regards,
fulltech.
Apr 11, 2009 | Honda Garden
I'm trying to find out how much oil should be in the water pump of a honda pressure washer model xr2750-1
it's an ex-cell pressure washer with a honda motor.
engine oil capicity: 0.61 qts(.58L)
view owner manual here:
http://www.excellpressurewasher.com/documents/pdf/a12338-e.pdf
Mar 10, 2009 | Honda Garden
Garden Logo
268 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
