Question about Alpine CDA-9815 CD Player
Alpine CDA-9815 freezes, loses sound, shuts off intermittently
I have an Alpine CDA-9815 installed in a 2004 Subaru with Alpine amp and Kicker box. Sometimes when I turn on the car, or go to change the radio station the sound goes out, but the power to the radio stays on. I have to take off the face, and usually blow on the connection. I have always eventually gotten it to come back on. More recently if I push on the face, either to chance the channel or volume the radio resets itself altogether. When I go to listen to a cd, it will just freeze, and I have to take the face off repeatedly to get it to reset. All of these problems are intermittent. Is it just dying?
ampman
  • 98 Answers
SOURCE: how to install an alpine cda 9851
you go to a stereo shop..(walmart autozone etc should also do) buy a mounting kit and a wire harness adapter. The wire colors on the adapter match the wire colors of most aftermarket decks. MAtch the wire colors and connect...make sure to tape wires well as if they touch you rick damage to your deck.. install the mount kit plug in your cd player and slide it in and you are good to go..
Posted on Aug 21, 2007
  • 10 Answers
SOURCE: no sound to the in car speakers from my alpine cda-9827 cd player
What kind of car did you install this in? Did it have a factory radio in it? If I had to take a guess I would think that there is a factory amp that you may have hooked the blue wire from the alpine deck to. If this is the case when you switch to CD the alpine deck turns off the power to the power antenna lead(blue wire) and thus your factory amp. If this is the case hook the factory amp turn on to the blue and white wire and you should be good to go.
Posted on Sep 03, 2007
TekTrax
SOURCE: Alpine cd redeiver CDA 7837
Just a guess, I’d say who ever installed it didn’t hook up the connector behind it. But lets say they did. In most cases, the radio’s connector bundle will have a fuse. It’s a good idea to check your car’s fusebox first to see if any fuses are blown there. In either case, if you replace a blown fuse with "the right value", and it blows again, have a tech check it out. Note that if you try to get to the rear of the unit, do a little research into how the radio is accessed through the dashboard. Most car radios aren’t quickies to get at and some folks can do damage trying to get at it, but if you methodically take logical steps, you should be able to pull the radio, check the connectors, locate the fuse if it has one. Of course, there may be a wiring incompatibility, meaning, the OEM radio had it’s own specific wiring harness, the Alpine was installed, but someone didn’t get the adapter harness to fit the car. Who knows. Good luck. TekTrax
Posted on Nov 03, 2007
SOURCE: Alpine CDA-9813 CD Player problem keeping the power stay on
i have that same problem. when i turn the volume up, it shuts off but comes back on right away. the only thing i can think of is i'm not running the constant power directly from the positive terminal on the battery (which is what is recommended). not sure if thats the solution but im gonna try and wire it right anyway...
Posted on Jul 29, 2008
blueextc3221
  • 15935 Answers
SOURCE: connecting mp3 player other than ipod to cda 9851
CLICK HERE for your owners manual in PDF format.
Please see Page 19 on how to toggle ON the AUX IN function on the radio
A KCA-121B (alpine bus to RCA) adapter is required.
-or-
AI-3NPUT (alpine bus to Female 3.5mm) adapter is required.
There is no alternate INPUT on the rear of this radio - an adapter is required... converting the changer port to an input.
Thanks for using FixYA - a FixYa rating is appreciated for answering your FREE question.
Posted on May 12, 2009
I need to remove my head unit in order to install RCA wires & to run a remote wire for my amp. When I had it installed they did not give me the key back. How can I remove the head unit without the key?
Unfortunately you can't without taking the factory trim panel off. I would go to a local shop that sells Alpine. They might have spare keys that they can give you. Or, they might take it out for you. Just tell them what you're doing, and ask them to pull the deck out so that you can wire the RCAs.
Apr 16, 2011 | Alpine CDA-9815 CD Player
I have a alpine cda 9815 cd player. it has an auxillary input, am i able to add a usb port connector to it? Or what parts should i add so i can play music through usb flashdisk. thanks
there is no option to add a USB port on this model. An alternative to use a usb flash drive is to use a MP3 with the auxillary input. Cheap MP3 with works fine too.
Feb 28, 2011 | Alpine CDA-9815 CD Player
Don t have a problem but i need a diagram how to wire a alpine cda-985 reciever to a kenwood kac-x542 amp in a 74 corvette
how to fit an indirect hot water cylinder from off an rayburn royal .and is it possible to use a pressure cylinder . diagrams would be useful please.
curt
Sep 22, 2009 | Alpine Car Audio & Video
Cda 7949 turns off/on by itself
Sounds like a lose wire in the harness either yellow, red or black. Pull radio and shake the wires around untill you find it or the face plate is lose.
Jun 04, 2009 | Alpine CDA-9856 CD Player
What can i use the auxillary cable for
yes you can connect it to an ipod/iphone or anything with an aux outlet. Some require an adapter to the plug but it'll still work.
Feb 21, 2009 | Alpine CDA-9815 CD Player
CDA-9815
dont connect the pink/black wire just trouble these are signal interupt lead wires cap and tape off and the orange wire is the dimmer wire for when you turn your lights on and off
May 06, 2008 | Alpine CDA-9815 CD Player
Understanding what the numbers are for
the numbers are frequency settings that filter unwanted freq.
theres is not wrong setting just play with it till your satisfied with the sound.
Nov 14, 2007 | Alpine CDA-9815 CD Player
Understanding the radio
equalizer highs and lows of sterio there should audio and entertainment buttons these should be your adjustment
you might need to upgrade the speakers for better quality sound sometimes these old speakers dont put out like everyone wants
Alpine CDA-9815 CD Player Logo
201 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
