Question about Brother MFC 890 InkJet Printer
Brother Fax Machine " Low in Temperature"
We are having problem in receiving fax due to low in temperature or see page 42 of the manual...can you helps us to fix this problem?
thank you very much
I need to reprint the last inoming fax. HELP!!!
Printing a Fax in Memory If you have Fax Storage ON for remote retrieval, you can still print a fax in the memory when you are at your machine: 1 Press Menu/Set, 8, 4. 2 Press Fax Start. 3 Press Stop/Exit. (See Turning On Fax Storage, page R-2.) Polling For details about the Polling feature, call our Brother fax-back system 1-800-521-2846 (in USA), 1-800-681-9838 (in Canada) and request at the Index. (See Features That Are Not in the Manual, page 6-6 for details.) Polling is the process of retrieving faxes from another fax machine. You can use your fax machine to "poll" other machines, or you can have someone poll your machine. All parties involved in polling need to set up their fax machines to accommodate polling. When someone polls your machine to receive a fax, they pay for the call; if you poll someone's fax machine to receive a fax, you pay for the call. (See Canceling a Scheduled Job, page 6-5.) Some fax machines do not respond to the Polling feature.
Jun 24, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
My mfc fax machine will not ring and will not receive faxes. I can send them out though
It's probably set to manual receive and the ringer volume is low or off.
Nov 20, 2010 | Brother IntelliFax-4100e Fax
Received blank pages. Could this happen if the
Make a copy of something to be sure. It will tell you when you are low on toner
Feb 04, 2010 | Brother IntelliFAX 5750e Laser Fax
Phone rings- not receiving faxes- unit copies- paper feeds fine- new toner and roller installed.
try changing the amount of time the fax machine rings before it answers to a low number... if that doesn't work try a reset... info on this page...
Dec 17, 2009 | Brother IntelliFAX 2800 Laser Fax
How can I delete the memory on a brother mfc-465cn printer fax machine? It will not receive faxes due to this
Review page 65 in your manual. Changing the "Advanced Fax Operations:"
If received faxes are left in your machine's
memory when you change the Advanced Fax
Operations, the LCD will ask you one of the
following questions:
Erase All Fax?
Yes - Press 1
No - Press 2
Print All Fax?
Yes - Press 1
No - Press 2
• If you press 1, faxes in the memory will
be erased or printed before the setting
changes. If a backup copy has already
been printed it will not be printed again.
• If you press 2, faxes in the memory will
not be erased or printed and the setting
will be unchanged.
Dec 11, 2009 | Brother MFC-465CN InkJet Printer
Using MagicJack for faxing; however, Brother MFC 290C is stating poor line condition - why? Also say's low ink Magenta - would that create this problem?
I had the same problem trying to send out faxes out using my Brother MFC 7340. I use a magic jack phone line. Page 106 of the user manual says if sending via VOIP phone line, you should press menu, then 2, 0, 1 to select "Basic (for VOIP) mode. Then press ok. Then press stop/exit. This cuts the modem speed down to 9600 bps and turns ECM off. Then retry to send the fax. I did that and can now send and receive faxes.
Jun 06, 2009 | Brother MFC 420CN All-In-One InkJet...
I have never had a problem with my fax machine until recently. All of a sudden, the machine rings and rings when a fax is trying to come in; it will show call pickup; to receive the fax, I have to pick up...
The machine has probably been taken off of auto-answer. You can download the manual from Brother's website here:
http://www.brother-usa.com/manuals/default.aspx?ProductID=PPF2800&ProductGroupID=2&WT.cg_n=Support&WT.cg_s=Manuals
Then you can verify it's set up properly. If the problem is due to some failure in the fax machine (always possible) you can find service options on Brother's site as well.
Dec 16, 2008 | Brother IntelliFAX 2800 Laser Fax
To recieve fax on brother
Press the 'RECEIVE MODE' button on the right side of the control panel, its next to the large 'FAX START' button. Here are your options :
Select Receive Mode
MANUAL
—You must answer all calls yourself. If you hear fax tones, press
Fax Start
to begin receiving the fax, then hang up. You can use this mode with
Distinctive Ringing. (See
Distinctive Ring
, page 8-1.)
FAX ONLY
—The fax machine automatically answers every call as a fax call. You
cannot receive a voice call, but you can dial out and make a voice call.
FAX/TEL
—The fax machine automatically answers every call. If the call is a fax, it
prints the fax. If the call is not a fax, it signals you with a double-ring (ring-ring),
different from the phone company ringing, to alert you to pick up the call. If you select
this setting, you’ll need to set the Ring Delay and F/T Ring Time features (on the
following pages). If you have extension phones on the same line as the fax machine,
set Ring Delay to 4. (See
For FAX/TEL Mode Only
, page 5-5.)
TAD:ANSWER MACH.
—This is the only setting in which you can use an external
answering machine. Your telephone answering device is connected to your fax
machine, and answers every call. Once the TAD answers, the fax machine listens for
fax tones. If it detects fax tones, it prints the fax.
The TAD setting works
only
with an external telephone answering device (TAD); it
does not work with telephone company Voice Mail. Ring Delay and F/T Ring Time
do
not
work in this setting.
Nov 27, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
Brother MFC 890 InkJet Printer Logo
297 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
