No print My canon iR300-400 PCL copier do not take prints.its data light simply blinks for long time ie. for waiting for a print. there will be no documents seen in the system or in the copiers monitor. please help me
How to fix the problem on the canon ir3225 that display NG #853 in the result section after commanding from pc.Even after installing ufr driver still is not working.
#853
Cause
-Using the wrong printer driver.
-The machine does not have the proper printer kit installed (e.g.
UFR, PCL, PS kit(s)).
-The print job did not print because due to lack of
resources on the printer (e.g. memory, HD space, etc).
-Print spooler on the machine is full.
-The number of secure print jobs have exceeded the
maximum limit that can be reserved at this time.
Remedy
-Make sure that the printer driver that you're using is the correct
one for the operating system on the computer that you are
printing from and specific to the printer model that you're printing
to.
-Check and verify that the correct and the required printer kit is
Installed (e.g. UFR, PCL, PS kit(s)).
-Reduce the number of pages to print.
-Erase unnecessary jobs that are stuck or in reserve.
-Turn off spooler on the printer, ADDITIONAL FUNCTION >
SYSTEM SETTINGS > NETWORK SETTINGS > USER
SPOOLER, set this value to OFF.
-Print out or erase secured print jobs that are stored or waiting to
be printed on the machine.
May 27, 2014 | Canon imageRUNNER 3225 Black and White...
Flashing orange light
Cannon pixma 3500 Flashing orange light count the blinks for the error,
Mar 17, 2014 | Canon PIXMA iP3500 Printer
Canon inkjet PIXMA ip3000 wont print and has 5 blinking yellow lights
Canceled the jobs on PC and verify the inks.If you use the refill inks perform the head cleaning in the mantenance mode.
Feb 13, 2013 | Canon PIXMA iP3000 InkJet Photo Printer
After giving the print to immage runner 400s copier the print sends to the copier. The data button blinks once. but print out automatically cancels. why?
Windows Server 2003/Thin N Computing thin client L300 Printer Epson FX2175 installed with thin client when dos base print command is given 1st page is printed but when 2nd print command is given printer gets offline either switch off printer before giving comman or print from printer properties. Again third page print command is taken by printer (For alternate pages print command printer gets offline automatically)
Aug 29, 2012 | Canon imageRUNNER 400S Copier
I have a canon i960 printer and it just started blinking 5 orange lights then a green light and won't print. Any ideas?
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Aug 21, 2010 | Canon Office Equipment & Supplies
I have Windows 7, I have a 5p (was just given) and the test page will not print. The green light at the bottom is continuously blinking. Suggestions?
bottom light blinking means it is receiving data try to unhook cable power cycle and try test print with data cable unhooked if you wait should error out if does not print
Jul 29, 2010 | HP LaserJet 5p Printer
Similar problem with a 6020
use pcl 5c L1 (please note it's very fast driver but only for single set print because this driver have some fault if you select 2 copies for print it print 4 copies so for single set it is the best and for many set try pcl 6 driver)
Jun 15, 2009 | Canon imageRUNNER 5020 Copier
Canon ir2200: data light comes on, nothing prints We have a Canon ir2200 installed as a local printer; no test page will print nor will a page sent from a program print, although the data light comes on,...
I would first try to see that your paper trays are set correctly. Meanning that the paper size are set to the same paper size in the tray. The knobs that input the paper size Magicly they move. Also, make sure that you clear out all the print jobs in the print "Q". Some body may have a odd paper size tring to print. Also, has anyone chaged anything on your network or the setting in the copier?
Mar 19, 2009 | Canon Office Equipment & Supplies
73 people viewed this question
k24674
jasbo
jasbo
