Question about Maytag Neptune MAH5500B Front Load Washer
WHAT DOES "OE" MEAN
What does "OE' mean. My washer continues to run water.
    Sniper:
  • 68 Answers
If it is running water, even if the washer is off, then the solenoid is stuck open on the valve. the best solution is to replace the fill valve. but sometimes you can take the valve apart and find sand or a small pebble causing the solenoid not to close, and fix the problem that way. let me know if you have any further questions. good luck, shane.
Posted on Sep 10, 2009
  • Shane Moore
    Shane Moore Sep 10, 2009
    if it is running water, even if the washer is off, then the solenoid is stuck open on the valve. the best solution is to replace the fill valve. but sometimes you can take the valve apart and find sand or a small pebble causing the solenoid not to close, and fix the problem that way. let me know if you have any further questions. good luck, shane.
Lg washER AND DRYER. What does OE mean
AN OE code means that the Front Load Washer was unable to drain water.
Jan 11, 2017 | LG Washing Machines
WHAT DOES OE MEAN ON DISPLAY ?
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Oct 06, 2011 | LG WM-2277HW Front Load Washer
What does oe mean
Kevin
Aug 10, 2011 | LG WM-2277HW Front Load Washer
Bell is ringing, 'OE' flashes on display; washer continues running
The error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
CLICK HERE
Thanks for using FixYa
Dec 28, 2010 | Washing Machines
What does oe mean on my washing machine display
"OE" code in your washer indicates a Drain error. This is because the washer is not fully drained within 10 minutes. You have to check whether there is a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge.
Thank you !!
May 23, 2010 | LG WM2487H Front Load Washer
Hello there, what does OE mean in the display?
OE is a water drain error.
Please clean the filter.
front lower left hand corner behind little door.
If after cleaning the filter the washer still will not drain the drain pump may be defective.
Jan 15, 2010 | LG WM-2277HW Front Load Washer
What does it mean when the washer says oe or ie
The "IE" code indicates a water inlet problem. This code is generated if the correct water level isn't reached within 8 minutes after water is supplied or it does not reach the preset water level within 25 minutes. I would look at the water inlet valve first regarding this code. Unplug the machine, shut off the water and remove the supply hoses. Check the small metal screens inside the valve and make sure they are clear of rust or debris and check the solenoids using a multimeter or ohmmeter. Check for continuity. A lack of continuity will mean a bad solenoid. I'll attach a photo for reference.
The "OE" code indicates a drain problem. This code is generated if the water is not fully drained within 10 minutes. Check the drain hose for kinks or obstructions. Sometimes running a hot wash cycle with about a 1/2 cup of vinegar will clean out any sludge buildup in the drain hose. If this doesn't correct the problem, then the next thing to check would be the pump. I sure hope this helped and best wishes.
Sep 29, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
MAYTAG NEPTUNE ERROR CODE OE
The "oe" code indicates a water pressure problem. Remove the water supply hoses and check the small metal screens inside the water inlet valve. Make sure they are clear of rust or debris. Check the water inlet valve solenoids. They can can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad solenoid I will attach a photo for reference. Hope this helped and best wishes.
Sep 11, 2009 | Maytag Neptune MAH9700 Front Load Washer
What does OE mean on a Hitachi washer??
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 31, 2009 | Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
111 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
