Can not get the channel set to leave screen while watching t.v
I Can not get the channel se or the channel # to leave the
top of the t.v (EMERSON )
the original remote for this t.v that was given to us was misplaced
the gave us and one for all Universal remote control
(URC 3021)
  • 47 Answers
I doubt that you will be able to change this with a universal remote. There is usually a button on the remote that says "display" that turns that feature on and off. You could look on ebay for a remote or contact the manufacturer to buy a new remote. If it is a new enough Tv that is still sold in stores you can tell them that you just bought it and the remote doesn't work and they will send you a free one. I bought a DVD burner and the remote wasn't working and they sent me a remote for free.
Posted on Dec 10, 2007
How do I get channels on my Emerson tv with dvd? I have tried everything I could think of and I only get channel 23 and that is kinda grainy looking.
I don't understand the question. Why do you need channel settings for the DVD? Are you asking what channel to play the DVD on? It won't be a TV channel, it will be a separate video input source setting, usually found on the remote. The TV may show Video 1 or HDMI for the source in order to watch an external source like DVD.
Sep 27, 2014 | Emerson Televison & Video
The ATV1 channel dissapeared on my emerson flat screen tv so now we can not watch movies or play games. How do I get that channel back?
if you have an old vcr you can attach that through cable and go through av hook up that way try going into menu settings into programing alot of times they start channel 2 you can go down a channel it will auto switch to av channel hook up also hope this helps
Jul 24, 2014 | Televison & Video
What channel does the tv need to be set to to watch a VCR?
Hi. It is usually channel 3 or 4. Just try setting your TV to 3 and see what happens. Make sure your TV is set to VCR.
Jul 05, 2014 | Emerson EWV603 VHS VCR
I have just connected my Viera to power & antenna. The screen said "New channels found" so I selected that. It said it would take 3 minutes. It found the channels and stated on the top yellow...
Run through the set-up again and after it says channels found, at the top YOU MUST hit the SELECT on the screen in order for the set to log them into memory, otherwise there will be nothing. So high-light the select after it all done and your ready to go.
Jan 18, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
I need to connect my vcr/dvd combo unit to an Emerson HD TV so that I can record shows. Can you help me?
Most TVs only have audio out and several audio/video in connections. Unless you have an unusual tv, there is no option for a coax connection from the TV to a recorder.
Since this DVD recorder only has an analog tuner, you need to connect it to a set top box to record signals unless you are looking only at analog channel sources. If you are getting OTA, then a OTA digital-to-analog tuner is needed for most channels. (Only low power stations are still broadcasting in analog.) The cheaper ones that were available with the government coupon were SD tuners. HD content will need a separate tuner. If you have cable or satellite, check the signal (QAM is digital cable).
Next connect the coax from your analog source to the DVD recorder coax in and another coax cable to the coax out and the TVs coax in (if you want to - the pass through doesn't work with a set-top box for non-analog signals). Set the channel to the appropriate one (3 or 4 for the OTA d-t-a boxes; desired channel to watch for analog OTA or cable). Set the TV to channel 2, 3 or 4. Alternatively, use composite A/V cables from the set top box to the A/V Input of the DVD recorder and set the recording channel to Input 1.
Next connect A/V cables (composite or S-video) to the recorder's matching out to the TV A/V or S-video In. Set the TV to A/V 1 or Video 1 depending on the Emerson TV. You can watch tapes or DVDs. For better video quality on DVD playback, also connect component video cables from the DVD recorder Out to the TV's component in (if it is available). Then set the TV to the appropriate component video input when watching DVDs.
I hope this helps.
Dec 05, 2010 | RCA DRC8300N DVD Recorder/VCR
I can't find my manual. I need to hook it up so that I can record tv shows I like to watch when I am not home. But I didn't do it right and I am having trouble with the remote also.
You can download a manual from http://www.funai-corp.com/support/manuals.aspx . Click on Customer Support and then Owner's Manual. Remote problems - first try new batteries then try a universal or other replacement remote, http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=EWD2203+&uuid=12828737757670 .
For problems with timed recording, make sure the clock is correctly set. If power goes out for more than 30 seconds, the clock will be incorrect and the timer information will be off. Insert a blank tape (or one you want to record over). Then press Menu and then go to Timer Programming. (Use the up/down arrows and then hit the right arrow button.) Set the frequency of recording followed by the day and start time of the programmed recording. Then set the end time of the recording. Next set the channel number. (with some set top boxes and TV connections, choose 3 or 4 depending on the way the setting of the RF output. Then set the channel on the set top box and leave the box on.) Then set the recording speed. Press T-set to lock in the program. If you want to watch a tape before the program starts, press T-set (turning off the timer light). Remember to press T-set afterwards to resume programmed recording. You can't record to DVDs.
I hope this helps.
Aug 27, 2010 | Emerson EWD2203 DVD Player/VCR
Watching football and can't see the yards, downs, etc on top/bottom of screen
Maybe you should check your screen settings, (widescreen, full, cinema, etc.) if the picture is too big for your screen, you won't be able to see the top or bottom of the picture.
Sep 08, 2009 | Emerson LC320EM9 32 in. LCD HDTV
How do i do a channel set-up on my emerson 25" tv
I have a On top of that I have Direct. All of a sudden the direct comes on but no tv??? help
barbra_ron@qwest.net
Jun 15, 2009 | Emerson TS2587D 25" TV
Emerson VCR/DVD player - can't get tv (cable tv) to play anymore
I have the same problem with my Emerson VCR. When the ADD button is flashing, just press the menu button to exit the menu. It will add. That's the only thing I know to do. Sometimes it works, sometimes it doesn't.
Feb 01, 2009 | Emerson EWD2203 DVD Player/VCR
Sylvania 27" derailed by Emerson universal remote
CHECK YOUR TV MANUAL FOR REMOTE INSTRUCTIONS IF STILL HAVING PROBLEMS CALL EMERSON AND TALK TO THEM ABOUT YOUR PROBLEM
Aug 25, 2008 | Orion STV2763 27" TV
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
