Question about Apple iPhone Smartphone
Same thing - roll appears at bottom, shutter doesn't open
Camera not working.. can't find a solution on net anywhere. I've hard reset and restored factory settings (backup and restore, not "new iPhone") - any help?
When i am shooting 1/250 or faster, i get a large black space across the bottom of the picture. i can't remember this happening before, i've had the camera for close to two years i think.
Something is obviously out of sync. When you snap the pic, the mirror must flip up out of the way and the shutter curtain must open (actually one part opens and the other part closes). If any of these is out of sync, you will get the problem you describe. The reason it doesn't happen at 1/250 or slower is that the shutter open long enough for everything to be open and out of the way. Sounds like you may need service.
Oct 28, 2011 | Nikon D3000 Digital Camera
Old Program A camera -mirror jammed in open position and shutter will; not open when the shutter release butten is pressed
From what you've given, it sounds like the shutter is fried, or the mechanism jammed - or both. If you're wanting to keep the camera, and use it, you'll need to contact a repair technician and have them take a look at it for a repair estimate - assuming it's able to be repaired. Estimates will run you around $35 most places, if there's no shop near you KEH Camera which has a website is quite good.
The same thing just happened to my Nikon FE, and my estimates have been ranging anywhere from $105-145 to get it fixed, so the decision of whether to repair or replace if really left up to you.
Aug 29, 2011 | Pentax Program A 35mm Film Camera
The schutter dosnt appear to open when i take a photo
hi,it is mainly wrong with your camera shutter button and shutter flex. it is very vital for you to replace them immeditaly,or it will effect their normal working.the following is something related to canon g11, there is some shutter flex and shutter button.
cindy
http://www.digitalcamera-parts.net/
www.skiliwah
MSN:e-8090team@hotmail.com
Aug 17, 2011 | Canon PowerShot G11 Digital Camera
Shutter remains closed on apple iphone 3GS
1. Sync phone with iTunes to back up your data. 2. Choose Restore option from iTunes window (first screen when you plug the phone into iTunes) 3. Before you restore from backup, test the camera again. If it works, then it was a software related issue. If it doesn't, the camera module is not working and needs to be replaced. 4. Restore from backup, or take the phone in for repair if the shutter is still not opening.
Jun 13, 2011 | Apple iPhone Smartphone
I have a Cannon PowerShot S2 IS digital camera, about 5 years old. The LCD Monitor and Viewfinder both only show a black screen with some of the Dispay Icons across the top and bottom, and after a few...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 06, 2011 | Canon Cameras
I have an lg cosmos touch. When I turn my camera on it loads for like two or three seconds then this thing pops up it says camera start error. I've tried turning it off then back on again that...
RESET YOUR MOBILE TO FACTORY DEFUALT BY TYPING THE CODE BELOW ON YOUR MAIN SCREEN:
2945#*#
AFTER YOU TYPE IT ,MANY OPTIONS WILL APPEAR ON SCREEN,CHOOSE FACTORY RESET
Jun 03, 2011 | Cell Phones
My Canon PowerShot SD 1000 has this problem: when i turn on the camera, the display is black and i can`t see any image through.Same problem on the video mode. it doesn`t appear any error mesage. i tried to...
A stuck shutter is another common failure mode for digital cameras (including my wife's SD1000, which I have to fix every once in a while with the following easy technique).. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. By the way, for your camera model, I've found it best to just alternate back and forth between opening the battery door while taking a picture, and gently flicking the lens barrel with the tip of my finger. Usually, it only requires a few tries for my wife's camera, then it's good for another couple months.
Jun 02, 2011 | Canon PowerShot SD1000 Digital Camera
What do i do if my camera is taking blurry?
try this steps
-make sure that the mode dial is in AUTO
-half press the shutter button and let the camera do an auto focus thing
-then full press the shutter button
if that does not work reset the unit press MENU > SET UP 2 . RESET this will restore the unit to factory settings and will not erase your pictures
then try this steps again
Jul 01, 2009 | Samsung S860 Digital Cameras. 8-megapixel...
The D-link di524 router was almost intalled but it never finished intalling
hard reset the box>turn on and press and hold the reset button about 40 sec>And restart the pc and check the pc dont have any static ip>and delete all temp files cookies,clear history>and do restore default
to clear all temp thing open inter net explorer-click-tools-click inter net option- >click-general-and do >and for restoring default click-advance in the top and in the bottom click restore default and apply and ok and try to login and change the ether net cord
Oct 13, 2007 | D-Link AirPlus DI-524 Wireless Router
Apple iPhone Smartphone Logo
47 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
