Question about Hitachi 53UWX10B 53" Rear Projection Television
Convergence settings on hitachi 53uwx10b
How do you get to the convergence settings on hitachi 53uwx10b
  • Gravich Nov 18, 2009
    The TV Repair Kits.com site is a Life Saver. Thank you for the link to that site. If anybody hasn't been there to get parts or Repair, I highly recommend it. Their Step-by-Step instructions are really End User freindly.
  • Hitachi Master
  • 3,459 Answers
Yes - You will need to either remove the circuit board or lift up the tray. If you are not sure how to do it yourself read the link below.
  • This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Sep 19, 2009
Testimonial: "Thank you for the info. It was really helpful. TV is back in business. :)"
3 Suggested Answers
Easyworks
  • 62 Answers
SOURCE: Hitachi 53uwx10b template
Hi, first what exactly are you looking for? the convergence board of the STKs number? If you have convergence problem, you will need to change the STKs for sure and check the resistence to the STKs and generally all of them have same low value. check it out and replace the faulty onces. switch on and adjust convergence and you have a good working picture on the screen. Visit www.fixurtvs.com for more FAQs.
Posted on Mar 22, 2010
  • 254 Answers
SOURCE: Need schematic for Convergence PWB of Hitachi
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
click the link.
Posted on Mar 09, 2009
Hitachi 53uwx10b
thats the sign of failed convergence. You can get the Hitachi DP14G convergence repair kit which also contains instructions from the following link http://www.tvrepairworld.com/hitachi_repair_kits then just scroll down to the DP14G convergence repair kit.
Aug 04, 2012 | Hitachi Televison & Video
I changed the IC chips on my hitachi 53uwx10b tv like you guys said that helped alot but still have wavey lines on both sides of the screen what do I change on the con. board now? Thanks alot Jim
Resistors " RK42 3.3ohms
RK46 1.8ohms RK50 2.7ohms RK54 1.5ohms RK58 3.9ohms RK62 2.2ohms After you replace all of them then enter convergence by pulling OFF bottom front panel there on front of convergence board is a small blue button press it and a convergence pattern will come up now aline each color red then blue.
Sep 24, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Ineed to know what convergence ic's are in this tv
Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Apr 17, 2009 | Hitachi 53UWX10B 53" Rear Projection...
53UWX10B blurred pic and blue/yellow lines
you can try the convergence first
if you cant converge the lines into one to correct this then you would require service for the convergence stage of your set
this is not a uncommon problem and usualy runs around 280 to 350 to repair unless the dcu is at fault
Jan 20, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 53UWX10B Convergence cutting in and out
Good Day, Armenian;
You have poor connections on the convergence IC's , re solder and your TV should be back to normal.
Good Luck, big IRISH.
Aug 04, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Color convergence problem
I'd suggest either replacing the ICs and resistors on the convergence board (requires soldering skill by yourself, someone else or an electronics repair shop) or purchasing a new convergence board from Partstore for $299 and swapping it out yourself.
While it may sound daunting, it really isn't once you find out more regarding this issue and dig into it a bit.  There's a wealth of info at the Digital Home Forum regarding this particular issue and ways to resolve it.
Good luck...  -TD
Apr 30, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Convergence i.c. board
Yes, you need two convergence ICs for your model STK392-110 heres the link to the site.
http://servicemanuals.vstore.ca/
Apr 29, 2008 | Hitachi 53UWX10B 53" Rear Projection...
53uwx10b,hitachi
dactag,
Working backwards now.......The burning smell will be the current limiting resistors near and in the circuit of the IC's
you changed..1 to 2 ohms, 1 or 2 watts.....caused by generic
replacement IC's STK392-110,120 or 150......Here is what to do to FixYa! First,please read some of my solutions for convergence
repairs...any brand,the info is generic,the repair parts are not....
1) REMOVE cheap IC's ! Replace with Hitachi part # CZ 01341
upgrade Mfr by Sanyo STK394-160
2)Replace any / all burnt or changed value resistors
3)Re-test to see any symptom....DO NOT CONVERGE
4)Think about putting the original DCU back,since it was
not the problem .......
5) Now where are we at ?? ............................T.
Feb 05, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Jan 11, 2008 | Hitachi Televison & Video
Hitachi 53uwx10b
Hitachi has created a repair kit part# X480293 for this problem. It includes: (2)STK392-150 convergence ic's,resistors RK42 = 3.3 ohms,RK46 = 1.8 ohms,RK50 = 2.7 ohms,RK54 = 1.5 ohms,RK58 = 3.9 ohms,RK62 = 2.2 ohms,all 1 watt resistors.
Aug 20, 2007 | Hitachi 53UWX10B 53" Rear Projection...
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
729 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
