Question about Black & Decker D2030 Iron
Black and decker iron D2000 won't heat. reads "standby"
Turned the iron on, but it won't heat. It reads "standby" in the display
SOURCE: iron D2000C type 1 black decker
the folowing reason for not working 1. the connection may be lose 2. the heating coil is gone 3. inside connection may be lose.
Posted on Sep 30, 2007
electrodynam
  • 35 Answers
SOURCE: the black and decker iron wont heat up
It probably has a high temp overload opened up inside or the thermostat control has gone bad.You can only tell for sure by taking the unit apart and testing the circuit for continuity.The steam feature on the iron is heated by the same element that heats the iron so it wont work.the element itself could also be bad,but I have never seen one go bad.You will have to check each component seperately to find the damaged part.or you can test the whole circuit at the plugs end,and use a jumper across each part until you have continuity through the unit.Make sure the thermostat is turned all the way up.the part that you are bypassing when you get continuity is the bad part.
You can buy a cheap continuity checker at any lowes,or even wallmart for that matter.
Posted on Mar 16, 2009
romsky79
  • 822 Answers
SOURCE: Same Issues with my Black/Decker 2030
change the thermal fuse inside iron that's why not getting hot. thermal fuse blown up due to overheat inside.
Posted on Aug 19, 2009
heatman101
  • 43501 Answers
SOURCE: Black and Decker AS775 Iron won't reset to heat up.
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
heatman101
  • 43501 Answers
SOURCE: Black & Decker Steam Xpress AS250 Iron with Auto Shut-off: my iron won't heat up. the green light comes on b...
heatman101
MY BLACK & DECKER D2030 DOES NOT POWER ON?
my black nd decker iron lights up but will not heat.
Jan 01, 2013 | Black & Decker D2030 Iron
Black and decker all temp steam iron stopped working while ironing and now it won't turn on.
please see the cause and fix it:
a) tank or ports clogged. Dissasembly and inspect replace tank and seal if badly clogged. Emptying iron after each use allow heats to evaporate remaining water and helps prevent clooging. Inspect valve and linkage: clean or replace as necessary
GOD BLESS YOU
Jul 22, 2012 | Applica Black And Decker All Temp Steam...
Iron shuts off when ironing
heatman101
Oct 25, 2009 | Black & Decker D2000 Iron
How do I clean my Black N Decker Advantage Iron
I work for Black & Decker customer service. Our number is 800-231-9786.
You can obtain a new manual for free by visiting www.useandcaremanuals.com. Below is the section from the manual on care and cleaning of your iron.
Care and Cleaning
This product contains no user serviceable parts. Refer
service to qualified service personnel.
It is not necessary to empty the water reservoir after each
use of the iron, if you iron frequently.
To empty the iron, hold the iron over the sink with the tip
pointing down. Water will stream out of the water fill
opening.
TO CLEAN THE OUTSIDE SURFACES
• Unplug and allow iron to cool completely. Wipe the
soleplate and outer surfaces with a soft cloth
dampened in water and a mild household detergent.
Never use abrasives, heavy duty cleansers, vinegar, or
scouring pads that may scratch or discolor the iron.
• After cleaning, iron with steam over an old cloth to
remove any residue from the steam vents.
ABOUT THE SELF-CLEANING SYSTEM
• Use the self-cleaning system to flush out minerals and
lint. If lint is allowed to accumulate in the vents, it can
scorch and cause brown spotting.
For Models D2000 and D2020: Clean about once a
month.
For Models D2010, D2030 and D2035: A "CLEAN"
indicator will appear in the digital display to notify you
when your iron needs cleaning (A).
• Fill the iron as described in "How to Use" but keep the
water level below the MAX line. Plug in the iron, set
the temperature to 6, and stand the iron on its heel
rest. Allow to heat about 3 minutes.
• Unplug the iron and take it to a sink. Holding it
horizontally over a sink, move and HOLD the variable
steam dial in the CLEAN position ( ). There may be
some hissing and spitting while self-cleaning. This is
normal.
• Stay clear of HOT steam and boiling water as it comes
out of the vents while lint, scale, and minerals flush
through! Continue to hold the variable steam dial in
the CLEAN position until all the water has emptied.
If necessary, rock the iron side to side and front to back
to empty it.
• When finished, release the variable steam dial, stand
the iron on its heel rest, and plug it in. Heat for about
2 minutes to dry out any remaining water then unplug.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Jul 03, 2009 | Black & Decker D2030 Iron
F2000 iron won't heat up
heatman101
Apr 10, 2009 | Black & Decker D2030 Iron
Iron reads error
I work for Black and Decker customer support. Our customer service phone number is 1-800-231-9786.
If the iron is not heating anymore, it needs to be replaced. Unfortunately, the unit can't be repaired. The unit comes with a one year warranty from the date of purchase. Please call the number above so that we can determine your warranty eligibility and help you any way we can.
Mar 29, 2009 | Black & Decker D2010 Iron with Auto...
The black and decker iron wont heat up
Mar 16, 2009 | Black & Decker ICR200 Iron with Auto...
Black and Decker steam iron won't heat. It has a green stand-by light and a yellow on light. When plugged in and the dial turned all the way up, the stand-by light is the only light on. The yellow light...
If the unit isn't heating, it needs to be replaced. Unfortunately, the unit can't be repaired. The unit comes with a one year warranty from the date of purchase. Please call the number above so that we can determine your warranty eligibility and help you in any way that we can.
While this doesn't actually solve your problem, I hope the information allows you to make an informed decision as to how to proceed from here. Please let me know if I can be of further assistance.
Aug 22, 2008 | Black & Decker Steam Xpress AS250 Iron...
First time use instructions
You can download the manual from the link below: http://www.blackanddeckerappliances.com/dyn/prod/user-guide/104/D2000%20D2010%20D2020%20D2030.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 18, 2007 | Black & Decker D2030 Iron
Black & Decker D2030 Iron Logo
158 people viewed this question
Top Black & Decker Irons Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
