Question about Brother MFC 8500 All-In-One Laser Printer
I cannot find where the piece of letterhead is inside the copier
How to write a letterhead to apply for an internship?
Normally a letterhead is a professionally printed blank sheet of paper with your name/address/logo/etc. pre-printed on the top. You could design your own letterhead using a word processing program to print as a header on your application letter. It seems pretty unusual to require a letterhead, especially for an internship. Perhaps they mean a letterhead from your university?
Aug 30, 2016 | Miscellaneous
When printing on letterhead, my documents have a slight "copy" of the letterhead in various locations throughout my document.
Your preprinted letterhead is sluffing off during the fusing process. Have your service tech adjust the fusing temperature.
Aug 12, 2014 | Brother MFC-8860DN Printer
SOMEBODY CAN WE HELP US? WE HAVE A PROBLEM WITH DUPLEX LEXMARK X644.
If you mean that you are getting a ghost image of the letterhead on the page this is caused by not setting the paper type to letter head which caused the temperature to be wrong and print does not bond. Or you may have a bad fuser or bad toner cartridge. Try setting the paper type to letterhead or bond first to see if that helps.
Aug 07, 2014 | Lexmark X644e All-In-One Laser Printer
Cannot print on regular letter size paper on my HP Officejet 6500A Plus printer. Gives me an error message saying Paper Size Mismatch, but it is the right paper for the print job.
I had same problem. Try this: When you go to print, change your ink quality to "draft". For some reason, I was able to print after trying everything. Hope this works for you!
Jan 26, 2011 | HP Officejet 6500 Wireless All-in-One...
HP Laserjet 4250tn - cant print a letterhead invoice
Do a paper path test from each tray in diagnostics on the control paneland check Printer Properties for PAPER HANDLING
Feb 17, 2009 | Office Equipment & Supplies
Extra paper pulled
Some rubber lining or rollers is out of line, if you can fix that it may work properly.
Oct 24, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Missing edge of scanned object
position the document on the corner of the flatbed scanner that has arrow signs.
Sep 29, 2008 | Lexmark X5470 All-In-One InkJet Printer
Won't print all of the letter on top of page
Hi afoot, that sounds like you need to adjust your printer by moving or adding more margian between the letterhead & the edge of the paper.
Best of luck to you!
Mike
Mar 25, 2008 | HP PSC 1610 All-In-One InkJet Printer
Brother MFC 8500 All-In-One Laser Printer Logo
20 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
