Sony KDS-60A2020 60" HDTV Logo
Posted on Sep 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony kds-60a2020 lamp problem
I HAVE ASONY PROJECTION TV 1080 MODLE #KDS-60A 2020. WHEN I TURN IT ON THE GREEN POWER BUTTON BLINKS, THEN THE RED LAMP BUTTON BLINKS, AND NOTHING ON THE SCREEN. I HEAR THE FAN BUT NO PICTURE. I THINK I NEED TO REPLACE THE LAMP MODLE # XL5200. DO I NEED TO CHANGE THE HOUSING AS WELL OR DO I JUST CHANGE THE BULB. ALSO DO YOU HAVE A DIAGRAM ON HOW TO CHANGE THE BULB. THANKS, HOSS
Anonymous
Level 2:
  • Expert 68 Answers
  • Posted on Sep 10, 2009
Anonymous
Expert
Level 2:
Answers
68
Questions
Helped
19292
Points
118
I would change the whole LAMP ASSEMBLY because if you touch the lamp while changing it out of the housing the oils on your hands will cause premature failure.Most of the time the lamp assembly's come with replacement instructions but yours is not too bad it is located on the left hand side if looking from behind set.
2helpful
I have a sony kds 60a 2020 the red light blinks 3 times. What does that mean?
This is a lamp issue. Reseat the lamp and if that does not fix, replace.
1helpful
Sony kds-r60xbr2 power wont come on and hte power led is blinking red 5 times
The 5 blinks is indicating the lamp ballast needs replacement your model uses the Sony lamp Ballast 147401211 for sony models KDF42E2000, KDS-50A2000, KDS-50A2010, KDS-55A200, KDS-60A2000, KDS-60A2010, & KDS-60XBR2 amd LDS-R60XBR2
Which is available at the bottom of the page at the following link. The ballast comes with installation instructions,
http://www.tvrepairworld.com/sony_circuit_boards/sony_dlp_circuit_boards
Sony TV kds60a2020 replaced lamp and power lights blinks three times. Checked to make sure lamp was secure. Would light still blink if defective bulb?
have you tried making sure the lamp door is closed ... generally 3 blinks means the lamp door is not closed the door pushes a switch closed
1helpful
The tv went blank @ the red led is flashing continuosly sony kds-60a2020
If its lamp light on tv front that is blinking red then lamp is dead/ broken and need to be replaced. Lamp replacement procedure is easy and written in user mnaual of tv.
If it is standby/ power light that is blinking then please count how many times it is blinking after three seconds pause and let me know to diagnose tv problem because it is an error code that has info in its blinking.
Thanks.
9helpful
2answers
1helpful
Replace bulb tv wont turn on
make sure the lamp and lamp door are seated properly. does it blink any codes. 3 blinks is lamp or lamp door not seated properly
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
