Question about Jenn-Air JCD2389G Side by Side Refrigerator
The ice maker in my Jenn Air refrigerator stopped working.
The ice maker in my Jenn Air refrigerator stopped making ice after I changed the water filter. Tried activating Speed Ice button but without success. I had plenty of ice before changing the water filter.
    Problem Solver:
  • 13 Answers
Check that there wasn't a clog in the line after replacing the filter. Make sure you get water going to the solenoid, if so, it may either be a clog in the solenoid or a fluke that it's no longer working.
Posted on Sep 10, 2009
Jenn-Air JFC2089HES ice maker
Try letting it thaw out and re start it.
Jun 19, 2014 | Jenn-Air Refrigerators
Ice maker doesn't work. changed filter. light on ice maker door still on.
You need probably to change the dispenser solenoids which swith water on dispenser
Apr 05, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn-Air Side-by-side Refrigeration not making ice and leaks water underneath when ice maker arm is up
With the arm up in the ice tray, the water solenoid valve should be closed. When the arm drops, that tells the ice maker to open the water solenoid valve to fill the ice maker tray. It sound like the leak is at the inlet side of the water solenoid valve. On some models its not easy to get to, but follow the water line to it. Hope this is it for you. Good luck.
Dec 30, 2013 | Refrigerators
Not making ice after changing filter.
Hi and welcome to FixYa I am Kelly.
A new filter can take several cycles of the ice maker to fill the filter up with water before. The average filter is around 30 oz and the average ice maker fill cycle is 3.2 oz. The new filter did not have any water in it. The water in the door has a resercoir so the air in the filter will still make the water work until you get air. Drain abour 3 tall glasses from the water in door. The ice maker should then work properly. The filter filters water for water in door (inside) and the ice maker so if you have water inside the door you should have ice UNLESS one of the inlet water valve solenoids has failed. Also make sure the Freezer door / light switch functions properly. The door switch is supposed to stop water and ice functions with the door open.
I would like to know if it starts making ice.
Thanks for choosing FixYa,
Kelly
Jul 26, 2011 | Jenn-Air JFC2089HE French Door...
Jenn-Air bottom freezer ice maker not working
I took the arm of the ice-making machine out of the slot and put it back in, pushing it snugly inside the slot, then raised and lowered it several times. Then, with the arm in the up (stop making ice) position, I felt inside the ice-making tray, where I noted there were ice cubes as well as a sheet of ice at the base of the ice-making tray. I poured approximately 24 oz. of hot tap water into the tray to melt the sheet of ice. I turned the freezer temp control to "warmer". I think the freezer temp setting was too cold, causing the ice maker to freeze the water before it could make cubes. I have a working ice maker again!
Cynthia
Sep 07, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Jenn-Air refrigerator is not making ice but it's dispensing water
It can take up to 24 hours for a new ice maker to make ice.  Check it tomorrow.
May 31, 2009 | Jenn-Air JCD2295HES Side by Side...
My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
bjones03@comcast.net
Mar 25, 2009 | Jenn-Air JCD2389G Side by Side...
I have a jsd2789ges jenn air water dispenser not working at all
hi there,
sounds like you have an icemaker problem. i would recommend replacing it.
Oct 02, 2008 | Jenn-Air JSD2789GES Side by Side...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
317 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
