Question about Frigidaire FMV156DC Microwave Oven
Where is the fuse on a Frigidaire microwave located?
  • William Miller
    William Miller May 11, 2010
    It depends on the model number, but usually behind the grille, on the floor of the oven behind the control panel, between the door switches, or on the filter board near where the cord comes into the unit. If your fuse is blown, the oven will be totally dead. Idf you have other symptoms, please let me know them, along with your model number. Otherwise, you can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here. NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly for FREE help & do-it-yourself advice. William E. Miller prototech@usa.nethttp://www.microwavedisplay.com We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
  • Deborah Fraser Apr 22, 2013
    Model number is CFMV156DS. The oven is totally dead but the fan and timer still work
    Problem Solver:
  • 5 Answers
The fuse is inside the control panel. In order to get ot it you would have to be knowledgable on how to take the control panel off.
Posted on Sep 12, 2009
Fuse location
Good Afternoon Friend, that's a great question!
Depending on the model of your Frigidaire microwave, the fuses are typically on located behind the control console, on the magnetron or on the oven capacity. However, if your microwave does not heat, you may possibly have a faulty control panel, magnetron, or experiencing an issue with the power supply. Please confirm that your microwave is plug into its own outlet and that you are not using a GFI outlet. Hope this helps! - Z
Sep 01, 2014 | Frigidaire FGMV174KF Microwave Ovens
Where frigidaire microwave fuse located?
Depending on the model of your Frigidaire microwave, the fuses are typically on located behind the control console, on the magnetron or on the oven capacity. Hope this helps! - Z
Aug 03, 2014 | Frigidaire Microwave Ovens
Where is the fuse located in a frigidaire microwave
The same as all microwaves 2 inches inside from the cord
Nov 29, 2013 | Frigidaire FMV156DC Microwave Oven
Where is the fuse located at on Where is the fuse located at on a Frigidaire...
The main fuse is on the power board. Right where your AC cord is.
Apr 26, 2012 | Frigidaire Microwave Ovens
Where is the fuse on my microwave Electrolux PLMV169DCD located?
We have three service manuals covering the PLMV169 series, which you can download free:
http://www.microwavedisplay.com/plmv169dcc_sm.pdf
http://www.microwavedisplay.com/glmv169_plmv169_sm.pdf
http://www.microwavedisplay.com/glmv169_plmv169_late_prod_sm.pdf
They're all pretty similar.
You can usually find parts from the Pros here.
If not, contact Electrolux at the phone number on the front of the service manual.
It may be the C/T fuse (thermal fuse located above the magnetron) or the oven cavity thermal cutout, located on the top of the cavity.
Accessing these two parts for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Electrolux / Frigidaire owner's manuals and installation instructions
here.
It may also be that there was a power surge which damaged the control circuit board, activating the built-in surge protection.
This is not resettable. The circuit board has to be repaired. We do that for $39.95, details here.
Dec 03, 2011 | Frigidaire PLMV169DC Microwave Oven
Fuse location for fan motor/lights??
Unplug microwave, remove the top cover "several screws" fuse location under keypad and near the high voltage capacitor "silver and rectangle in shape" fuse is a ceramic type, must be replaced with identical fuse and rating, and don't forget to discharge capacitor with "long handle screwdriver"
Feb 06, 2011 | Frigidaire GLMV168K Microwave Oven
Microwave just stopped cooking!
The simplies is the fuse, which is located inside the unit, you need a screwdriver to open it
Aug 18, 2009 | Frigidaire FMV156DC Microwave Oven
No power I checked the power outlet and I have 115V there Is there a fuse some ware??
If everything is ok, the fuse of microwave oven is located inside the unit, if you have a screwdriver, unplug the power cord and open it, you'll find the fuse
Aug 09, 2009 | Frigidaire PLMV169DC Microwave Oven
Where is the fuse on a Frigidaire GLMV169D
This problem is almost certainly caused by the thermistor failing. The thermistor is located at the
air outlet of the unit. This is a thermal resistor that cuts off the electricity to the unit if it overheats. Sometimes it can fail from age.
Go to;
http://www.appliancepartspros.com/
and enter your unit number. You can even get diagrams in the left-hand corner screen.
Replace with same value thermistor.
Also see if a mini manual in hidden behind the control panel.
Mar 20, 2009 | Frigidaire GLMV169D Microwave Oven
Frigidaire FMV158FM over the range microwave 1000 watts
everything works on microwave but does not heat
Sep 18, 2008 | Microwave Ovens
Frigidaire FMV156DC Microwave Oven Logo
1,140 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
