Question about Apex Digital LD1919 19 in. LCD TV
I replaced the capacitors today, and have the white screen also..
I NOW HAVE A SOLID GREEN LIGHT, SOUND AND FULL CONTROL WITH REMOTE.....SAME PROBLEM. I DID NOTICE THAT THE NEW CAPACITORS ARE BIGGER AND I WONDER IF THE CAPACITOR TOUCHING THE COPPER COIL, HEAT SYNC OR THE OTHER LITTLE BUTTON COULD CAUSE THIS???? DO WE NEED TO PUT MORE OF THE WHITE SUBSTANCE IN BETWEEN? IT ALSO COULD BE TOUCHING THE SCREEN. ANY HELP WOULD BE BENEFICIAL. THANKS!
  • mrjosephtorr May 11, 2010
    so how long does it last befor the caps blow?
I had the same problem. Had two of these TV's which needed the capacitors replaced. After verifying it wasn't my work on the power board with teh capacitors (it worked in the other TV) I checked the connections. Turns out that I had loosened the data cable ON THE BACK OF THE LCD. Peeled back the foil tape that covers the connection carefully so it would go back in place. Saw immediately where it was coming loose. Reseated the connection and pushed the foil tape back in place. When I fixed the 2nd power board and hooked it all up, no more white screen. I'm assuming that all of the jostling of the screen during repair of the power board is how it came loose. Good luck!
Posted on Dec 26, 2009
  • m56545 Jun 15, 2011
    Thank you, I replaced the capacitors and had a white screen thought I did something wrong but when I look at the lcd cable it was unplug.
I have the same problem. Any more solutions?
Posted on May 20, 2010
  • cman6146 May 20, 2010
    Based on further research could it also be the 150uF 400V cap? If so would ordering one from Ebay be in my best interest?
How do I program the jamo torsten sound bar to my remote control?
Great product, horrible instructions that focused on every language known to man rather than clear steps. Hope this helps....for the JAMO TORSTEN 2 WAY SOUNDBAR W/ WIRELESS 10" SUB 360 Series, as well as other Klipsch soundbars.
If the SoundBar is in STANDBY mode (solid RED status light), push the <SOURCE> button on the SoundBar until the status light is solid GREEN.
STEP ONE (Place the unit in learning mode): With the status light showing solid GREEN, press and hold the <SOURCE> and <MUTE> buttons on the front of the SoundBar at the same time (approximately 3 seconds) until the status light flashes RED and GREEN.
STEP TWO (Select the function to learn): Press the <MUTE> button once on the SoundBar (the status light changes to solid ORANGE).
STEP THREE (Learn the function): Hold your remote control within one foot and pointed at the front of the SoundBar. Slowly press the <MUTE> button on your remote control four times. On the first three presses, the status indicator light will flicker ORANGE with each press. If the unit has successfully learned the function, on the fourth press of the button, the light will flash GREEN several times and then turn to solid GREEN.
To program the remaining functions, simply repeat all steps, substituting <MUTE> with the new function and button presses (VOLUME UP, and VOLUME DOWN) on steps TWO and THREE.
Apr 28, 2014 | Jamo Torsten Soundbar with 10" Wireless...
My Proscan led TV (PLDED3273A) is switching color from red, blue, green, white, and black.
hi first you will need the proper remote control once you have this press the menu button on the remote, retune the tv hope it helps
regards
shaun
Apr 01, 2014 | Proscan Televison & Video
Screen went completely white but still have sound
Try with the Mitsubishi remote the soft restart, set on Menu,1,2,3, and enter.
Dec 07, 2012 | Mitsubishi WD-65734 65" HDTV
Turn tv on. green light solid display, no picture or sound
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
Jul 28, 2012 | LG 50PG60UD 50 in. HD-Ready Plasma TV
My LG 50PC3D was manuf in June 2006. Just today the screen is black and flickering 1 wide band of dimlit grey slightly off to the left. The indicator light stays solid green. Any idea what may be causing...
I would first check for swollen capacitors on the power supply board. This model has about 9 under rated capacitors that usually go bad. The original caps are 3300 uF rated at 10 Vdc., and they should be replaced with 3300 uF capacitors rated at 16 Volts DC, 105 degree types. A failure on this board could also affect the other boards in the set so correcting this problem may not remove the symptoms.
Jan 29, 2011 | LG 50PC3D 50 in. Plasma Television
I have an lg 32lb9d that wont turn on. the green light flashes 19 times then goes solid.when it goes solid green the screen lights up ever so slightly and u can hear a slight humming sound???
You need to replace some bad capacitors on your power supply. Easy fix and you can do it yourself for less than $15 parts. I order mine from Digi-Key. Check out some videos on youtube for plasma and lcd repair.
You will need to identify which capacitors are bad on your power supply and order ones with same same ratings (micorfarads, volts, temp and actual size).
Good luck
Feb 23, 2010 | LG 32LB9D TV
Plasma Hyundai 42'' TV ,NO SOUND OR PICTURE
most times then not it's the capacitors on your power board that blew there for not supplying the tv with enough power if you open it up and check the capacitors it should be leaking some kind of liquid or the tops have bubbled up. its an easy fix cost>>2 dollars each
May 21, 2009 | Televison & Video
Remote control
Do not replaced anithing .filter cover needs to be turn dow. them press reset boton.......
Sep 10, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Apex Digital LD1919 19 in. LCD TV Logo
738 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
