Question about Garmin nuvi 200W GPS
Can i use my garmin 200w while it is charging. say i go on a trip
If im on the road and my garmin is plugged in i cant use it it says its charging
Agent Ken
  • 250 Answers
SOURCE: Garmin 200w does not hold charge
Hello Jeffery81,
Sounds like either a bad charger or a bad rechargeable battery pack inside of the GPS. If the unit doesn't remain powered up even when it is plugged into the charger, my guess is that the charger is the problem. Do you have an alternate way to charge the GPS? Like a 12 volt vehicle power cord or a USB cable to connect it to your computer? If so, try charging the GPS using that alternate method. If the item charges and functions normally, you will know for sure that the problem lies with the charger. If not, then the problem is either the battery pack inside the GPS or some other part of the unit's charging circuitry. In that case, you should contact Garmin technical support for additional assistance.
Best Regards,
Ken
"Go Ahead. Use Us."
Posted on Jun 04, 2008
sharcnet
  • 2130 Answers
SOURCE: Garmin NUVI 200W USB Port port pulled loose
The problem with repairing it yourself is that this is a surface mount connector. The solder pads are so small, it would be very difficult to solder with a standard soldering iron. Most likely you would apply too much solder and short out the connector. You really need to use a surface mount soldering/desoldering device and that can be fairly expensive. I have done this before but I have access to the right equipment.
Also, there is a possiblility that the printed circuit board tracks have been pulled up off the main board. If that has happened, there's a lot more work involved in fixing that. You might have to put in a different type of power jack and run wires from it to the main board.
If you're going to try to salvage the USB connector, I would remove it completely and install a new one. Over time, these connectors wear out, so you're better off removing the old one and putting a new one in. Again, this all depends upon whether the tracks on the board have been damaged or not.
Please let me know if I can be of further assistance to you.
Good Luck,
- Jim
You also have to know how to take apart the Nuvi.
Posted on Jul 21, 2008
fidoliedo
  • 162 Answers
SOURCE: Windows XP will not recognize Garmin 200W
1- did you load the USB driver for your garmin unit BEFORE plugging in the unit? Is your USB 1.1 or 2.0 compliant?
Most of the time, you need to install the software first before plugging in any usb device. You can go to GARMIN.COM and download your usb driver and run it, then plug in your garmin unit. If your USB is 1.1, you may experience a problem. Also, what version of XP are you running? have you updated to SP2?
Another thing you can do is reset your USB devices. Click on START, SETTINGS, CONTROL PANEL, SYSTEM. Click on the tab HARDWARE, click on DEVICE MANAGER, go down to UNIVERSAL SERIAL BUS CONTROLER. and delete everything there. Make sure you have the original drivers for your particular system just in case windows can't recognize them. Have you tried plugging in another USB device to see if windows recognizes that? You may have a problem with your USB ports. Some Compaq/HP models, the USB ports just stop working. I had a client go out and purchase a usb card to solve the problem.
Posted on Jul 25, 2008
ginko
  • 19396 Answers
SOURCE: how do i change the battery on a garmin 200w
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Posted on Apr 10, 2009
SOURCE: garmin 200w goes into usb mass storage mode when pluged to charge
Steps:
1) Disconnect the nuvi from the charging cable.
2) Press and hold the battery meter icon for 8 seconds. This puts the nuvi into "system test" mode.
3) Plug in the power cable.
4) Click "Exit." The nuvi will reboot, but remain in GPS mode!
Posted on Jun 17, 2009
I want to start a long trip , am planing to go whit my car from sheffield england to romania and i dot now witch rout she lay sett in my garmin nuvi 205w because i want the feastest one just motorways if...
Set the fastest route. The shortest route will take you off motorways and up narrower roads. Garmin satnavs know the difference between fastest and shortest.
Aug 09, 2010 | Garmin nuvi 200W GPS Receiver
Garmin 200w goes into usb mass storage mode when pluged to charge
Steps:
Jun 08, 2009 | Garmin nuvi 200W GPS
Without plugged in my garmin nuvi 200 will not work
That means that you have to replace the battery.
Jan 21, 2009 | Garmin nuvi 200W GPS Receiver
New Garmin 260 W won't do anything when plugged in.
Your PC may not be able to charge it. If it does it's only a trickle charge. May take a day or two
The Garmin cigarette lighter charger take 4 hours.
Dec 26, 2008 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 260w not operating while plugged in
If you are trying to use your unit in the car via the USB port and not the supplied cable, it will not work. You must use the bracket that came with the unit or the specific charger that came with the unit. The pins in the Garmin USB charger only use two pins whereas a regular charge cable uses 4.
Aug 14, 2008 | Garmin nuvi 200W GPS Receiver
First time use / battery charge
The Nuvi units are short on battery life and therefore Garmin has given you a connector other then USB to power your unit while in a car. You need to carry that. It's just a design flaw. If you try to rely on the battery of your Garmin Nuvi, you have less than 2 hours even on a full charge. And carrying the USB adapter which plugs into the cigarette lighter socket won't allow your unit to run while charging. so you need to take the adapter charger bracket that comes with the unit if you need it for longer trips.
Jul 10, 2008 | Garmin nuvi 200W GPS Receiver
Shortest Route and Fastest Route Garmin Nuvi 200
The problem could be in your avoidance settings. I know when I was in Delaware, a 1/2 hour trip turned out to be a 3 hour detour because I had set to avoid highways.
In Garmin, if it's checked, it means AVOID. I know the documentation isn't clear but I've learned from experience (trial & error).
Sometimes it happens. Garmin isn't perfect but it beats looking at a map most of the time.
Jul 03, 2008 | Garmin nuvi 200W GPS Receiver
Garmin NUVI 200w
the same issue with mine, but mine cut out after one day. Purchased 6-9-08
Jun 09, 2008 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 200W GPS Logo
208 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
