Question about Marshall MG100HDFX 100-Watt Amplifier Head
Fax's stuck in Memory
How do I print out the Fax's that are stuck in 'Recieved in Memory'?? Would greatly appreciate any help.. Thanks
  • 62 Answers
Unplug from power and phone line and leave off for around 30 minutes then replug it all and do the initial setup. The memory should be clear with having the power off for so long but obviously if it has a backup battery disconnect that too while everything is disconnected.
Good Luck
Posted on Sep 13, 2009
I had Mackie th15a 110vac and it had busted fuse, when i replace it when a new one it got busted again...i plug the power cable to 110vac without a regulator. what would be the possible problem in the...
If fuses keep blowing there clearly is something wrong with the power amplifier. You can start by getting access to it and doing a visual inspection for signs of overheating or short circuits but then it will be necesary to check parts and eventually you will be able to isolate the defective part(s) and repair it.
Dec 26, 2013 | Mackie HD1801 Powered Subwoofer (1600...
Hi, i have a casio privia px-120 and i have a problem with the volume level. it has been stuck in the same volume level and even when i move the volume up it stays the same. ive been wanting to fix it for...
go to halfords and get a can of their eletrical contact cleaner spray, make sure the keyboard has no power spray the volume control liberally, then turn the unit upside down and alow the cleaner to evaporate, you can speed this up with a hair dryer.
Dec 07, 2013 | Music
Hi i have a casio piano px-120 and the volume is not working, like it is stuck in certain volume level and even when i move the volume up it stays the same. ive been wanting to fix it because the volume is...
2 possibilities: Dirty control/cursor...clean with electronic contact cleaner. NOT WD-40 IT IS A CORROSIVE CLEANER.
Or bad control or connection to control. Get access to the "underside" of the control and check. Hope this helps.
Not sure what is wrong with the pedal but no sound is coming from it - the bypass light flicks on and off when i click the bypass but once the pedal is 'activated' it's completely dead! Help...
Common cause is weak battery (the LED is NOT an indication the battery is good as it will still light long after the battery is too weak). The second common problem is the input and output cables are backwards. The unit will pass audio with them backward, but NOT when you activate.
Jun 18, 2011 | ProCo Rat 2 Distortion Pedal For Electric...
I have an I-Onix u42s which worked great up until today when I turned it on and it's not picking up any input sounds. I tried every input and no sound is coming through. I changed nothing on the...
Probably the sound and devices settings in Windows control panel have been clobbered back to the computer audio instead of the Lexicon. Check the device defaults in "Audio" and "voice" tabs in the "sound and devices" in the Windows control panel.
Jun 01, 2011 | Lexicon I ONIX U42S 4x2 USB 2.0 DESKTOP...
Hallo, I have a Korg pa800 and whenevery I want to load DrumKit or a Sound from another set, I get a warning message (Load Sound Fails: not enought memory fro PCM samples). What should I do to load...
you may have to dump somethings from the memory, the memory is finite and if there is no more room there is no more room. as far as I know there is no expansion memory for this keyboard
Mar 17, 2011 | Korg Pa800 Synthesizer
Is it a bad idea to fly with my akai mpc 2000?
Good idea to carry it with you. Fluctuating barometric pressure will not affect it.
May 27, 2009 | Akai Mpc1000 Music Production Center
Roland keyboard
You need to clean the pcb and remove dried spillage residue
you could try wasking the rubber contacts but these may need to b ereaplaced.
Jun 28, 2017 | Music
Marshall MG100HDFX 100-Watt Amplifier Head Logo
Top Marshall Music Experts
matt martin
matt martin
Leonard Jeffrey
Level 1 Expert
rjivaro
Are you a Marshall Music Expert? Answer questions, earn points and help others
