Question about Dell Spacesaver USB Keyboard J4624 SK-8115 RT7D50
Keyboard very slow
I held the keys down too long & now the keyboard isn't working right. It takes me forever to type. How can I fix this?
  • c_pallante08 Sep 10, 2009
    I got it working. I rebooted and that solved the problem. Thanks for your response.
  • Dell Master
  • 7,993 Answers
In control panel (classic view) Click the kyboard icon. and configure repeat delay and speed
Hope it helps.
Posted on Sep 10, 2009
Keyboard problem & it doesn't work prefect
If the keyboard has a round purple connector, power down the computer then unplug and then plug in the keyboard. Power on the computer. If it works your done if it doesn't replace the keyboard. If this is a USB keyboard, with the computer on, unplug and plug in the keyboard if it works great, if it still isn't working replace the keyboard. NOTE if this is a multi functional keyboard (special keys at the top) make sure you install the driver and any software associated with the keyboard.
Jun 11, 2012 | Computers & Internet
Some key of key pad isn't working
If some of the keyboard is working and some is not, you may need to replace your keyboard. Keys can sometimes fail if there has been a fluid spillage, or if the keyboard has been removed at some point and the connector cable fractured. Or it could just have failed from general use, nothing lasts forever.
New keyboards should be available fairly readily on sites such as eBay.
Jul 24, 2011 | Toshiba Satellite Pro L300 Notebook
My nb100 laptop. keyboard some keys not working.
There are various ways of solving this issue. Some of them has these broad explanation.
Problem #1 - My Laptop Keyboard Keys Not Working
Sometimes you may find certain keys of your laptop keyboard not working properly. You type those keys but there is no output on the screen or you need to press these keys firmly to get a result. You face this problem if you accidentally spill any liquid substance on your keyboard, or due to dust accumulating on the inside of the keys, pressing certain keys really hard while playing games or even due to absence of lubrication. Therefore you are suppose to maintain your laptop keyboard by cleaning and lubricating it regularly.
Troubleshooting Steps
  1. To start with, take out each key out from the laptop keyboard. Use a small screwdriver to carefully pry each key by making it loose. As they become loose, keys will simply pop off. Also, take out the rubber piece present under every key. Keep the keys and rubber pieces in different containers.
  2. Once you have removed all keys from the keyboard, you will have to clean the keyboard from the inside. Use cotton swabs or ear bubs and slightly dip them in water. Avoid getting them too moist, as excess water can damage the keyboard. Meticulously clean the whole keyboard using moist cotton swabs, laying extra emphasis on key spaces.
  3. Now, start cleaning keys you had earlier removed and kept in the container. Use foam rubber and lighter fluid to clean each key alone. This will help in removing any sticky substance present on keys. Apply any household cleaner on these keys and let them stay for about 15 minutes. After this, wash all the keys properly using hot water and let the keys dry completely.
  4. The small rubber pieces which you took out earlier and kept in the container have to be thoroughly rinsed in warm water, after you have sprayed a household cleaner on them. Soak these rubber pieces up in paper napkins so that they dry quickly.
  5. To lubricate the keys, place all keys (facing top-down) on a flat surface. Apply mild lubricant from all sides, on all keys and leave them to dry. Avoid applying too much lubricant instead go for a light coat.
  6. Similar to the manner in which you lubricated the keys, apply mild lubricant on the keyboard surface and let it dry.
  7. Once you have cleaned and lubricated all the parts, carefully reassemble the laptop keyboard. Begin with placing all rubber components on the keyboard. Next, fix all keys in their respective positions cautiously securing the wire in these keys. Use your finger and press down all keys, one at a time, firmly so that they fit properly in the slots. That is it.
The complete process will take you a maximum of 2 hours. Cleaning and lubricating the laptop keyboard in the above prescribed manner once a year, can prevent many 'laptop keyboard not working' situations.
Problem#2 - My Laptop Keyboard Types Wrong Characters
When your laptop keyboard types wrong characters, it is because of a software problem and not a hardware one. If you accidentally press specific keys on your keyboard, it can activate a particular function responsible for the problem.
  1. Select the control panel option
  2. Click on ? 'Regional and Language Services' ? 'Languages' ? 'Details' ? 'Key Settings'
  3. Choose the option 'Switch Between Input Languages' and click on 'Change Key Sequence'
  4. Make sure that all the check boxes in the window are unchecked and repeat the same for 'Switch to..... (Keyboard Type)'
  5. Click ?'Ok' ? 'Ok' ? 'Apply' ? 'Ok'.
Problem#3 - My Laptop Keyboard Types Numbers Instead of Letters
This is another laptop keyboard problem due to some software issue. It is possible you may have enabled a digital lock unknowingly.
Pressing the 'Function' key along with the 'Num lock' key (Fn + Numlock) or press the 'Function' Key along with the 'Shift' and 'Num Lock' key (Fn +Shift + NumLock). This will disable the lock and consequently solve your problem
Dec 20, 2010 | Computers & Internet
I have a CDP-100 and need disassembly instructions for access to internal keyboard assembly. Unit was dropped while unloading from car. Now some keys are akimbo and won't play as though they are off their...
I just fixed my CDP 100 which had a similar problem - dropped and two keys not working up one end.
1. Lay keyboard upside down on soft surface. Under keyboard is plastic cover held on by 17 screws. Remove all these and lift cover away. The metal key ends are all revealed.
2. Locate the disloged keys. Carefully press them back into position - they will "click" into place. Make sure the corresponding key on the keyboard isn't stuck in an "up" position - you may have to remove the metal key part and replace it again while making sure the key is correctly seated.
3. Replace cover and screws.
Feb 22, 2010 | Casio Music
Hi I was reading the screen and held down the
There would be an Icon in the system tray where you see your time and date (refer the image)51386ea.jpg
double click on that icon and you will get
uncheck the use filter keys box and the keyboard would start working
Sep 30, 2009 | Acer Aspire 2930-4661 Notebook
Keyboard Problem
Holding down the right-side SHIFT key has activated the "Sticky Keys" feature in Windows -- designed for physically-handicapped people who cannot press more than one key at a time.
Access CONTROL PANEL and disable this "Accessibility Option".
May 31, 2009 | Logitech Wireless Access Duo Optical...
Keyboard problems
Go to Control Panel --- then System -- then device manager -- under keyboard right click and go to update driver.
If that doesn't work, go into control panel and there should be an Icon for KEYBOARD. Check the "Key settings" and make sure it set to "Standard" and not custom or gaming.
Hope this helps!
May 27, 2009 | Dell Spacesaver USB Keyboard J4624 SK-8115...
Need to disable a key on my keyboard
check your keyboard in
Start/settings/control panel/keyboard right click open check what options available you may be able to stop key working
Jul 24, 2008 | Computers & Internet
Green keys on bilingual (EN FR) keyboard
Finally I figured it out. Hold the shift control function keys at the same time. This will turn the green key function on and off.
Feb 18, 2008 | Acer NSK8458AN Keyboard
Non working keys on laptop
You should just need to replace the keyboard.
However finding a keyboard for a packard bell in the US can be hard. That brand hasnt been sold here in years.
If you are in europe it should be less of a problem though.
Made sure to get the exact model of the laptop to get the right keyboard.
Dec 20, 2007 | Packard Bell Easy One Silver 2101 Notebook
Computers & Internet Logo
126 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
