Question about Sony KP-46WT510 46" Rear Projection HDTV
Focus issue after replacing convergence IC's
Hi Everyone. I relpaced the Convergence IC's in my Sony KP-46WT510 and the 5 amp pico fuses. One of the 5 amp pico's was blown but I replaced both. I left the 3.15 picos alone as they all tested ok. The convergence issue is resolved however the picture is somewhat blurry. Print and lettering is especially difficult to read. The 3D effect is all gone now, but I've been unable to get the focus to a good point using the flash focus or the manual convergence methods in the main menu.
Any suggestions? Thanks
  • 2 more comments
  • gordon773 Sep 12, 2009
    The grill from the front of the set? Or do you mean the rear grill?
    Ok, I figured out how to get the front off. I'll let you know how it all goes. Hoping for the best.
    I tried the focus but it only helped a little. I'm starting to think I need to replace the convergence resistors as well. Any thoughts?
  • gordon773 Sep 17, 2009
    at a glance I don't see any burned ones. I ordered some replacements so I will switch them out for good measure.
  • 556 Answers
Pull the fron grill off the set then remove the cardboard covering the hole that is in the front of the set you will find a square box that has 6 controls on it adjust the focus for the red, blue and green crts, do not adjust the three marked screen control.
Posted on Sep 11, 2009
  • tvtechlady Sep 17, 2009
    are there any that look burned? If so then yes replace them.
I change the convergence IC and still defective
Check PS8001 to PS8006 Pico fuses all 3.15amp on the D board,
also check PS5001 and PS5002 on the G board 5 amp Pico fuse
May 17, 2014 | Sony KP-51WS500 51" Rear Projection...
Replaced Convergence chips, same problem
This set has pico fuses on convergence board and also on G power board, there should be 2 5 amp pico fuses on power board.
If convergence is bad exactly as before double check the power board fuses and check to see if voltage (it is marked!) is there with power board disconnected from chassis..
Steve
Mar 01, 2012 | Sony KP-61HS30 TV
I have a sony kp-51ws510 projection tv, i replaced the convergence ic's and a pico fuse and then reset the convergence. The tv looks good except for a green shadow on lettering, also on the convergence...
Did you check the two pico fuses on the G board? Usually at least one will blow when the original ICs failed. I am attaching a pic that shows the 2 pico fuses on the G board.
Jul 08, 2011 | Sony KP-51WS510 51" Rear Projection...
I have a similar problem as described as a convergence problem with my Sony KP-53HS30 TV. Can you elaborate further on the solution to repair. Which IC and protector fuses do I replace? Thank you.
Your model uses two STK392-560 Convergence ICs. also there are 6 pico fuses on the D board and two pico fuses on the G board which may need replacement also. The Sony type 1 convergence repair kit from www.tvrepairworld.com contains the IC's pico fuses and a few resistors plus instructions on CD of how to do the repair.
Aug 08, 2010 | Sony KP-53HS30 53" Rear Projection...
I suddenly have color separation (blue, yellow,white). Flash focus won't work. Any suggestions.
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Note: there are also pico fuses (on the same convergence board) that need to be checked/replaced
Oct 20, 2009 | Sony KP-51WS500 51" Rear Projection...
Green projection light not alligning with red and blue. Flash focus will not bring them back. Sony Rear Projection KP-48S70
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
Note:The convergence/defletion/power board (the one the IC's are on) of this model is on the left hand side (when facing the back of set) also check for blown pico fuses when replacing the convergence IC's The best way to replace the IC's resistors and possibly fuses is to remove the entire board.
Oct 19, 2009 | Sony KP-48S70 48" Rear Projection...
Red's are out of alignment and I can't fix them
Replace the convergence ICs and the pico fuses you can get a convergence repair kit at the following link which is for the KP46WT510 But its the same one for your model. The kit contains the two convergence Ics all six pico fuses and four resistors. Plus free step by step instructions with pictures that show how to do the repair. Heres the link to the kit.
http://servicemanuals.vstore.ca/product_info.php/pName/sony-kp46wt510-convergence-repair-kit/cName/convergence-repair-kits
Jan 24, 2009 | Sony KP-51WS510 51" Rear Projection...
Sony projection tv convergence issue
You will need two STK392-560 Convergence ICs and you will also need two of the 3.5 amp pico fuses as Sonys will always blow at least two of the Pico fuses. You can get replacement ICs and Pico fuses at the fiollowing link and they provide free instalation instructions. Heres the link.
Aug 10, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-46WT510 46" Rear Projection HDTV Logo
342 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
