Question about GE Dishwashers
Water standing in the botttom of dishwasher. not draining
  • Anonymous Mar 26, 2014
    water gathers and goes stagnent in botttom of dishwasher
    Problem Solver:
  • 17 Answers
Outlet drain may be plugged. Pump may be clogged or defective.
Posted on Sep 10, 2009
Standing water in dishwasher
Good Afternoon friend, thank you for your post!
I understand that you have some standing water inside of your Frigidaire dishwasher. It is a normal operation to have anywhere from 2 to 3 inches of water inside of the tub of your dishwasher. If it is anything more than that you could have an issue with the drain pump or drain line.
You may want to check the drain line for any restrictions or clogs that could cause improper siphoning from your dishwasher. You should also make sure that the filter located in the bottom of your tub is clean, that could cause water to stand within your dishwasher. I hope this information is helpful. -Matt
Mar 11, 2015 | Frigidaire Dishwashers
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Jul 30, 2012 | Frigidaire Dishwashers
Water standing in tub,already removed cleaned screens,also drain hose is not plugged,can feel spindle spinning on pump out motor.Would impeller be shot??....thanks
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 07, 2010 | Kenmore 17252 Free-standing Dishwasher
I have standing water in my dishwasher. How do I unclog the drain?
It will be smelly water and if you have access to a shop vac that will help you remove the standing water if not use a bowl or turkey blaster listed below.
Use a small bowl to remove standing water from washer to access screen to remove and check for blockage. Once you have removed all the water that you can with a bowl or cup. You can use a turkey blaster to sucton remaining water from dishwasher.
Then you remove screen and clean out drain and also check drain line for blockage from dishwasher to under sink.
Clean out drain to unclog in bottom of dishwasher and you may have to remove drain line to clean it.
Aug 10, 2010 | Frigidaire Dishwashers
Dble sink, one with the garbage disp. won't drain standing water
It's a drain clog within the disposal. Try a drain cleaner, if no luck, you will likely need to replace it.
Feb 18, 2009 | GE 24 in. Profile PDW7800 Built-in...
My dishwasher won't drain
was it loose? I don't think it goes in there.
Nov 02, 2008 | Danby 22 in. DDW396 Free-standing...
Dishwasher not draining
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Feb 22, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
if its new call your dealer its a warranty call
Dec 22, 2007 | Dishwashers
Kitchenaid dishwasher - water standing at end of cycle
less than 2 cups of water in left after cycle complete
Dec 02, 2007 | Siemens 24 in. SE25A266 ExtraKlasse...
Dishwashers Logo
221 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
