Question about HP Photosmart 2610xi All-In-One InkJet Printer
I have just installed two new ink cartridges. Everything seems to snap in well, yet the printer says "Remove and check cartridge on right' and I cannot print anything. I have removed and replaced the cartridge on the right several times, to no avail. I also have turned the printer off and on several times, to no avail.
  • willow0826 Sep 10, 2009
    Since I have an apple computer and an HP printer, HP won't answer any questions.
    Can you find out how to get that printer chute wire back into alignment?
    I also noticed that on one of the cartridges I had mistakenly removed
    the copper cover. Does that ruin my chances of being able to use this
    new cartridge?
    1. I accidentally removed the copper covering from my new print cartridges.
    2. Could that be why my printer reads "Remove and check cartridge on the right" even though two brand new cartridges have just been installed?
    Or could it be stating that for another reason?
    I have an apple computer and an HP Photosmart 2610xi all-in-one.
    President:
  • 1,901 Answers
Hi. Just making sure....
Did you replace the cartridges with the power ON? Power must be on to replace them.
If you did, try replacing the new cartridge with the old one you took out. If the error goes away, you have a bad cartridge. (It happens.) If the error remains, you may have damaged the electrical contacts inside. Is it still under warranty? If so, I would definitely pursue that avenue.
Thanks for using Fixya.
Wayne
Posted on Sep 10, 2009
  • Wayne Mineard
    Wayne Mineard Sep 10, 2009
    If you removed the copper you pretty much ruined the cartridge.
    Sorry.
  • 601 Answers
Probably the metal spring inside the printer chute is out of place .You had to adjust onto the plastic ridges inside - see HP website solution at:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01423559&cc=us&lc=en&dlc=en&product=391189
Hope this helps
Thanks
Smith.
How do i put in ink on 926 dell photo scanner and copier
From the online manual...
1. Turn on your printer.
2.Lift the printer unit, and then position the scanner support between the tabs to hold it open.
3.The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4.Press down on the ink cartridge lever to raise each ink cartridge lid.
5.Remove the old ink cartridges.
6.Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them properly.
7. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
8. Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.
9. Snap each lid closed.
10. Hold the printer unit up, push the scanner support back to unlock it, and then lower the printer unit until it is completely closed.
Manual can be downloaded here.
Oct 30, 2012 | Dell 926 All-In-One InkJet Printer
Tip
How to replace the ink cartridges on a Dell All-In-One 948 Inkjet Printer 1....
1. Turn the printer on.
2. Lift the printer unit.
3. The ink cartridge carrier moves and will stops at the loading point unless the printer is busy.
4. Press down on the ink cartridge lever to raise each ink cartridge lid.
5. Remove the old ink cartridges from the printer.
6. If you are installing new ink cartridges, then remove the sticker and transparent tape from the back and bottom of each ink cartridge.
Note: If you are wanting to print photos you will want to install a photo cartridge along with the color cartridge. Also if you are switching between the photo and black cartridge but they still have ink in them be sure to store then in an air tight container so they do not dry out.
7. Insert the new ink cartridges. Making sure that the black or photo ink cartridge is secure in the left ink cartridge carrier and the color ink cartridge is secure in the right ink cartridge carrier.
8. Snap each lid closed
on Apr 01, 2010 | Dell 948 All-In-One InkJet Printer
HOW DO I CHANGE THE INK CARTRIDGES IN MY CANON PIXMA MP160
Hi
Here's how to replace ink cartridge.
Make sure the printer is turn on. Place your fingers under the LED control panel and lift the scanning unit. The cartridges inside the printer will automatically slide to the left, for easy access. Remove the empty cartridge by pushing the front of the cartridge downward. It will snap out of its cradle. Pull out the cartridge and replace the new ink cartridge. Insert the new cartridge. With the front of the cartridge tilted down, push the back into the cradle. Lift the front upward, and the cartridge will snap into place. Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help. Regards and thank you for using Fixya !
May 21, 2011 | Canon PIXMA MP160 All-In-One Printer
How do I install the printer cartrige? I do not have the booklet...
  2. Open the front cover.
  1. Press the tabs on the cartridge lids, then lift the lids.
  1. Remove the old ink cartridges.
  1. Store the cartridges in an air-tight container or dispose of them properly.
  2. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
NOTE: You can use your printer with one cartridge (color or black) at a time. To extend the life of your color cartridge and improve printing speed, install both a color cartridge and a black cartridge at the same time.
  1. Insert the new ink cartridges. Make sure the color ink cartridge is secure in the left ink cartridge carrier and the black ink cartridge is secure in the right ink cartridge carrier.
  1. Snap each lid closed.
  1. Close the front cover. The front cover must be closed to start a print job.
  1. Open the Dell Printer Solution Center by clicking Start® Programs or All Programs® Dell Printers® Dell Photo Printer 720® Dell Printer Solution Center.
  2. Click the Maintenance tab.
  3. Click Install a new print cartridge.
  4. Click Next.
  5. Select the type of cartridge you installed.
NOTE: Specify whether the cartridge is a new cartridge or an old cartridge (one that has been used before). If an old cartridge is incorrectly identified as New Cartridge in the Dell Printer Solution Center, ink levels may be incorrect.
  1. Click Next.
Dec 17, 2010 | Dell Inkjet 720 Printer
How to instal a new printer ink cartridge
Lift the printer unit, and position the scanner support between the tabs to hold it open.
Press down on the ink cartridge lever to raise the ink cartridge lid.
Remove the old ink cartridge.
Dispose of the old cartridge properly.
If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
Insert the new ink cartridge.
Snap the lid closed.
Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
DON'T FORGET TO RATE THE SOLUTION, THUMBS UP!
Nov 22, 2010 | Dell 810 All-In-One InkJet Printer
How to open printer to change cartridge?
In order to replace the cartriage, please follow the steps below:
1 Keep the printer on.
2 Lift the printer (scanner unit) until the scanner support keeps it open.
busy.
3 Squeeze the tabs on the cartridge lids, and then lift the lids.
4 Remove the old cartridges.
5 If you are installing new cartridges, remove the stickers and tape from the bottom of
the cartridges.
6 Insert the new cartridges. Make sure the color ink cartridge is secure in the left carrier
and the black cartridge is secure in the right carrier, and then snap the lids closed.
7 Lift the printer (scanner unit) and push the scanner support back while lowering the
printer (scanner unit) until it is closed.
Sep 15, 2010 | Dell A920 InkJet Printer
Canon ip1600 ink cartridges are not recognized?
First make sure you are placing the right
color cartridge into the right slot.
Most Printers are touchy about the
installation of ink cartridges. If the
instructions say to press the cartridge
into the slot until you hear a loud click,
that's what they mean. If at first you
don't succeed, remove the cartridge and
reinsert it into the slot again and press
on it hard till it clicks.
Then your printer should work properly.
Hope this is of some help. Bud
Nov 01, 2009 | Canon PIXMA iP1600 Printer
Show me how to install new ink cartridge onv305
hi eileenoreill,
you can try these steps:
  2. Lift the scanner base unit.
  3. Press down on the ink cartridge lever to raise each ink cartridge lid.
  4. Remove the old ink cartridge.
  5. Store the cartridge in an airtight container, such as the storage unit you received with your photo cartridge, or dispose it appropriately.
  6. Remove the sticker and transparent tape from the back and bottom of the new ink cartridge.
  7. Insert the new ink cartridge. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.
  8. Snap each lid closed.
  9. Lower the scanner base unit until it is completely closed
  10. Snap each lid closed.
just update me if the issue is not yet resolved.
Oct 18, 2009 | Dell V305w All-In-One R840635AU InkJet...
Hi there
Replacing Ink Cartridges 1. Turn on your printer. 2. Lift the printer unit. 3. The ink cartridge carrier moves and stops at the loading position unless the printer is busy. 4. Press down on the ink cartridge lever to raise each ink cartridge lid. 5. Remove the old ink cartridges. 6. Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them. 7. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge. 8. Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier and the color ink cartridge is secure in the right ink cartridge carrier. 9. Snap each lid closed. 10. Close the printer unit. 11. An alignment page automatically prints.
Mar 01, 2009 | Dell 926 All-In-One InkJet Printer
Installing new ink cartridges
Be sure you have snap the ink cartridge tight, and check the expiration date of the ink cartridge.
Nov 12, 2008 | Dell Office Equipment & Supplies
HP Photosmart 2610xi All-In-One InkJet Printer Logo
22 people viewed this question
Seeker5211
Seeker5211
