Question about SanDisk Sansa e260 MP3 Player
Blue scroll wheel
Ok so recently my Sansa e260s blue scroll wheel is sticking, REALLY bad. I think theres somthing stuck inside it (a liquid or somthing) is there anything i can do/buy to get it to stop sticking without totally ruining it?
thanks =]
  • 8,596 Answers
Nope.
Posted on May 23, 2008
  • Corey Knoettgen
    Corey Knoettgen May 30, 2008
    Let me elaborate, since I gave you the only correct answer and you rated me "inappropriate" - the click wheel presses down on a circuit. Using a glue or other adhesive will likely interfere with the correct firing of the circuit and risks interfering with the action of other circuits in the player. There are no Mp3 repair services outside of Philadelphia and other select locations. They all cost more than the cost of replacing your player outright. I'm not making this up - i gave you the only correct answer that there is.
2 Suggested Answers
ThaMp3Doctor
  • 8596 Answers
SOURCE: BLUE SCROLL WHEEL STICKING.
May have been exposed to too much heat. sorry.
How install a driver for Sansa e260
Download the software after you run the link below ....Put check next to converter/firmware update/Manual download...run the programs follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
Also make sure you are connected to a 2.0 usb the back of the computer is best (the motherboard).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter
Feb 17, 2011 | SanDisk Sansa e260 MP3 Player
Black screen, lit up blue wheel ,Cant see screen
try detaching the back by taking off the tiny screws (dont lose them!) taking out the battery + putting it back in.
May 31, 2009 | SanDisk Sansa e260 MP3 Player
Black screen, lit up blue wheel ,won't turn off or on
Goto > http://www.sansa.com/support/sansa_view/faqs
There is a FAQ page here that might help you.
May 29, 2009 | SanDisk Sansa e260 MP3 Player
My PC doesn't read my sansa e 260
i think it is that u need a program like samsung pc suit or somthing like that im not shure try it and it might work
Aug 18, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260 takes 15 mins turning on.
once the blue circle is there, you just need to wait, it'll turn on
if not, take it to a best buy
May 05, 2008 | SanDisk Sansa e260 MP3 Player
Problem with sansa e260
that happens to me too. i think the problem is that your computer can't like, sense that it's plugged in, so your battery's dying out, and the computer wont charge it
Mar 24, 2008 | SanDisk Sansa e260 MP3 Player
No USB mode in settings / Coverter says no available player
First of all. For the video issue. You may not be putting the vidoes in the right spot, where the player searches for them. Or if you are, in the right format. The e260 comes with a CD which contains a PDF manual and a utility for putting vidoes on the e260. If you arent using the utility that came with the e260 you wont get the vidoes to work because they will either be in the wrong format or spot. As the folder which they are supposed to go into is hidden, you must ask windows or your os to show hidden files/folders to manually insert the videos. As for your USB problem, Turn on the player and press the power button breifly to return the the modesd/welcome screen. Scroll through until you see settings and hit the enter button [The button inbetween the scroller] Then use the blue scroller to scroll down through the entire list until you see a setting called USB Mode. Hit enter again and in most cases select MSC. This should fix your problem. If it doesnt, attempt at updating the frimware of the player.
Dec 31, 2007 | SanDisk Sansa e260 MP3 Player
Dec 06, 2007 | SanDisk Sansa e260 MP3 Player
MUSIC JUST WONT PLAY ANYMORE
Renew Rhapsody subscription and resync
May 19, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
221 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
