Question about HP Compaq Presario V2000 Notebook
When i unplug charger computer switches off
After i'm through charging my battery, when ever i unplug the charger while the laptop is on it switches off the laptop
  • HP Master
  • 4,924 Answers
Yeah sometimes they do that ...cause during the charging ...they actually run on the ac ....and when removed it is does not switch right the way on the accumulators....so ...dont make a big deal ....always turn it off when do that , better check if the other way is working ...I mean when your battery its almost empty and you plug the ac cord...if it get the juice right the way without any other issues...cause if you are on ac and have something going on ...you can wait and finnish and than unplug ...but if you are on batteries ...and running out of power and just work on something ....and it does not accept the ac cord...this is tricky ...:d so good luck ...
Posted on Sep 10, 2009
  • 674 Answers
Som problem for the hardware.. did you check the programs.. try to re instal the os then connect again the charger into laptop then unplug it.. if the same problem.. check your hardware.. plug in another divice like another charger then unplug it.. to check your charger..
  • 36 Answers
You may have a short in your power jack or male jack (on the plug) that's shorting out the computer and causing it to turn off. Does it turn off if you're plugging it in while the comp is on? if so then that would be your answer. Watch for sparks when plugging it in ir unplugging it on the jack site.
If this is not the case, your battery may be damaged. Does the computer run without the AC adapter? If not, you've got a bad battery. The real compatibility tests is reflected in the CONTROL PANEL under POWER OPTIONS, then cIick on POWER METER and you will see a battery with the charging percentage %. If the battery is dead or incompatible then this power meter will sadly reflect zero (0%).
Lg g500 battery
This could be one of 4 problems, all of which are relatively common
1. Your laptop's battery is broken or defective
2. Your battery charging cable is broken or defective
3. Your laptop's AC port is broken or defective
4. Your battery charging cable is unplugged
I'm not joking on the 4th one by the way, it's more common than you'd think. In any case, the best way to ascertain the problem is to check each of the components individually. First, make sure the computer is off. Plug the charger into the computer. If the charging cable has a charging light, is it on? Make note of this. Unplug the charger, unplug the battery, then plug the charger back in. Try to turn the laptop on. Does it turn on? Make note of the result. If nothing happens during any of these tests, the AC port is faulty.
If the charging cable has a light and it's on, the charging cable is most likely not faulty. If the computer turns on when the battery is not plugged in, then the cable is definitely not faulty. Generally, this means you should replace the battery. Depending on the battery design, fixing it yourself is sometimes possible, but it's nonetheless never recommended. I'm going to suggest that you either buy or obtain a new battery through the warranty if you have one.
If you have any questions, feel free to ask. ;-)
Sep 25, 2013 | Lenovo Computers & Internet
Nc6000 multibay battery does not recharge
Perhaps remove the multi-bay battery, and let main battery charge all the way. Then reattach multi-bay battery, and see if it's recognized.
(Will charge)
That is AC adapter (Charger) removed, then remove multi-bay battery.
Plug AC adapter back into laptop, THEN plug AC adapter into power.
[You do Not want to unplug an AC adapter from a laptop, with the AC adapter plugged into power. Could be a power surge/voltage spike. Unplug AC adapter from power, when plugging into laptop, or unplugging from laptop ]
Main battery charged, unplug power to AC adapter, unplug AC adapter from laptop. Plug multi-bay battery in, then AC adapter.
(Then plug AC adapter into power)
Post back in a Comment.
Regards,
joecoolvette
Feb 28, 2013 | HP Computers & Internet
My laptop is completely dead, fine yesterday. Today no lights, sounds nothing. I tried removing the battery , unplugging no response. Thanks,
Remove the battery for at least 3 minutes... Then put it back and then plug in the charger and switch on the charger. If the battery is completely drained, it would take a while for the charging to initiate. Please have patience and leave it on charging even though without the charging indication for at least an hour. After that still if the charging indicator doesn't lit, then its definitely your charger or laptop. You will need to take it to a service centre in that case.
Nov 03, 2011 | Compaq Presario 2170US Notebook
My laptop wont charge when charger is plugged in it will turn on but the computer will stay at 0% battery what is the problem?
HI there, IS it a new Laptop. If yes what you can try is removing the battery and then switching it on.. Once its started just reseat the battery while its on power. You might have to try it 2-3 times if that doesnt help then your battery is broken..
Kind regards
Jul 23, 2011 | Toshiba Satellite L305-S5908 Notebook
Battery will not charge.plugged in not charging
Does the computer start anyway, but it's just that the battery won't charge? If that's the case, it's probably a bad battery.
A procedure to do before assuming a bad battery is to (1) remove the battery, (2) disconnect the power supply from the computer, and (3) press and hold the power button for about 30 seconds. This resets the logic circuits in the internal power handling section. If that doesn't help either, then the battery is probably bad.
If the computer isn't starting, however, it could be that the power supply has failed. Check the voltage output on the power supply.
Hope that's helpful.
Jan 12, 2011 | IBM ThinkPad T30 2366 Notebook
Hello my laptop isn't charging properly. It is plugged in and all of the cables are connected. There is power in the plug socket but it doesn't seem to be charging. Help!
Hi! Drain the power charges of the laptop by shutting it down and by unplugging both ac adapter (charger) and battery from the computer.
Press the power button for like 10 times while the battery and charger is disconnected to drain the power of the board.
connect back the battery first then connect the charger to the computer. Make sure that the charger is connected to a stable power outlet while charging the system.
Please leave a comment if you have any other questions.
Cheers!
Jun 10, 2010 | Computers & Internet
How do you get this notebook to run on just the battery please?
to use or running Notebook in a battery, simply unplug the battery charger ( power chord) and your battery should be fully charged.
by the way, if ou having the problem of a laptop shutting off when you unplug the charger when your battery is fully charged, there is nothing wrong with the laptop, battery, or computer, it is a power management setting. What you need to do is:
  1. Go to display properties
  2. select the screen saver ta and click the "power" button
  3. In the power schemes tab there iss a drop down window, click it and select "Portable/Laptop" (it is a power switching utility that quickly switches between AC and Battery when the power cable/charger is plugged in or unplugged while the laptop is on)
hope this help a little, ask me if you need more assisst.
regards
Apr 17, 2010 | Acer Aspire One Netbook 8.9" Notebook
Bought a new battery (larger one) and it will only charge for 1 second?
Check if the battery is already fully charged. If it is, the charger will stop charging when battery is 100% charged.
You can check this by unplugging the charger cord from the laptop. If the battery is not fully charged, plug in the charger cord into the laptop again, start the computer and enter the BIOS. In the BIOS, look to see if you have a "battery check" and start it. This will test the charging and discharging cycles of the battery.
Mar 22, 2010 | IBM ThinkPad R50e Notebook
Laptop turns off intantly, when I unplug the charging cord
For those of you having the problem of a HP laptop shutting off when you unplug the charger and your battery is fully charged, I can help you. There is nothing wrong with the laptop, battery, or computer, it is a power management setting. If you go to display properties, select the screen saver tab, then click the "power" button, in the power schemes field is a drop down window, click on it and select "Rixane Power Scheme", it is a power switching utility that quickly switches between AC and Battery when the power cable/charger is plugged in or unplugged while the laptop is on. If you have it set to "always on" it will shut off when you pull the power cord, even if the battery is charged. This will also happen on many non-HP laptops, if you don't have a HP laptop or there is not a "Rixane" option available, select the "Portable/Laptop" power scheme. Hope this helps!
Dec 27, 2008 | HP Pavilion dv9000z Notebook
HP Compaq Presario V2000 Notebook Logo
373 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
