Question about Yamaha Rx-v465/rxv465 Home Theater Receiver
I need to use my TV as the speakers for my system..what is the setting on the Yamaha RX-V465 to do this?
    Scholar:
  • 127 Answers
For what do you need receiver if you don't want to use its speakers?
As far as I know this is only possible for HDMI connections (when you have your DVD player connected to HDMI-in of receiver, and HDMI-out to the TV). Go to Setup menu / Func. setup / HDMI / Audio. You can choose there if audio from HDMI should be output on receiver's speakers, or TV speakers, or both.
Posted on Mar 12, 2010
The Yamaha Reciever RX-V465 is connected to my digital TV by fibre optic cabel. I have sound when I connect my MP3 to the V-Aux and the speakers are displayed on the display window of the Reciever same as...
Please check your TV settings and the optical cable.
The speaker icons disapper from LCD display when the receiver does not detect any input signal throught the optical/coax/hdmi cable.
Dec 13, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
Can I hook up my yamaha receiver to soundbar
can I hook my yamaha rx-V465 to my vizio soundbar? When I soldered the rca plugs on to the speaker wire and connected my center channel on the receiver now ther receiver randomly shuts itself off.
Nov 21, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
Yamaha av Receiver RX-V465 picture but no sound. Can switch between PS3 and sat tv all via hdmi connections. Good picture yet still no sound. Trying to run left right and center Bose speakers. Read the...
Check the settings on receiver in the SETUP menu / HDMI / Audio. Here you can choose Amp (sound goes from the speakers connected to receiver), TV (receiver is muted and sound is routed via HDMI to TV) and Amp+TV (sound goes from speakers and also to TV).
Also check in OPTION menu / Signal Info that receiver is receiving sound in recognized format.
Jul 04, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
Yamaha RX-V465 switches off when increasing volume beyond -21.0dB
What speakers you have connected? This receiver supports only 6 and 8 ohm speakers (not 4 ohm). Also check if the ohm settings are correctly set in Advanced Setup (in standby press on the front panel STANDBY while holding STRAIGHT button). In this menu check the setting SP IMP. (speaker impedance) if it maches your speakers (6 or 8 ohm).
Disconnect all inputs and also all speakers. With nothing connected, try to increase the volume. If it still will power off, the unit is probably faulty and should be repaired.
If it does turn off only with speakers connected, check the speaker wires and the speakers, the problem will be there.
Mar 14, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
Haveing trouble syncing the sound with lips is there a trick to do this? also whats the best setting to get the best true surround sound by the way i have Rx-v465 with klipsch 300 home theater speakers.
RX-V465 has auto-sync feature over HDMI. So if you have your DVD and TV connected over HDMI, receiver will communicate with your TV and set the delay automatically based on TV processing speed.
You can turn auto-sync on in Setup menu / Sound Setup / Lipsync / HDMI Auto.
Or if that doesn't work for you, you can set a value in milliseconds manually in the same submenu.
Jan 13, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
Hdmi connection from receiver to hdtv, with set top cable box and no sound from speakers
Check your HDMI sound settings. You can choose it HDMI sound should go to receiver+speakers or to TV.
It is in menu: Setup / Func. setup / HDMI Audio. Options are: Amp / TV / Amp+TV.
Dec 25, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
Home cinema
Yes, these speakers need an amplifier. So unless your DVD player features an amplifier, then you will need separate 5.1 receiver, for example Yamaha RX-V365 or RX-V465 (which supports audio via HDMI input).
Apr 06, 2009 | Jamo A102HCS5 BLK Compact Designed 5.1...
Open Questions:
See all Yamaha Rx-v465/rxv465 Home Theater Receiver Questions
Yamaha Rx-v465/rxv465 Home Theater Receiver Logo
166 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
