Question about Canon LaserClass 2060P Plain Paper Fax
How to program a number into the one-touch dialing buttons
I would like directions on how to input fax numbers into the speed dial feature on the Cannon Laser Class 2050 super G
  • 318 Answers
Press the dataregistration key.dataregistration will apear on the screen press the arrow down untill Tellregistration will be displayed.Press set or ok or start.! Toutch speed dails will be displayed.Press set or ok or start.It will show the available one touvh numer.Enter and insert name and fax of the sender.
Posted on Sep 10, 2009
How do I set and save a fax number as a speed dial
You can download the User Manual from here (temporary link): http://dl.dropbox.com/u/1322442/CANON%20CFX-L4000.pdf
Here is a transcript:
Storing Numbers for One-Touch Speed Dialing
Your Canon fax can store up to 120 phone numbers: up to 20 of your most frequently used numbers can be stored for One-Touch Speed dialing, and an additional 100 numbers can be stored for Coded Speed Dialing.
1. Press SET and DATA REGISTRATION
The display will show:
DATA REGISTRATION
1. SPEED DIAL SETUP
2. Press SET twice.
1-TOUCH SPD DIAL
01
3. Use the search buttons (up and down symbols) to select a One-Touch Speed Dialing button between 01 and 20.
1-TOUCH SPD DIAL
[1...7]
??¢ You can also do this by pressing FUNCTION, then pressing the One-Touch Speed Dialing button, then pressing FUNCTION again.
??¢ If a number is already stored at the button you select, that number appears.
??¢ If the button you select is registered for Group Dialing, GROUP DIAL appears.
4. Press SET twice. Use the numeric buttons to enter the fax number you want to store.
TELEPHONE NUMBER
TEL =
??¢ Press SPACE to enter spaces between numbers. (Spaces are optional and are ignored during dialing.)
??¢ If you want to clear a number or a mistaken entry, press CLEAR.
??¢ To enter a pause in the number, press PAUSE one or more times
Sep 22, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
How do i store numbers? there is no manual.
DATA REGISTRATION
1 .SPEED DIAL SETUP
2. Press SET twice.
1-TOUCH SPD DIAL
01
1-TOUCH SPD DIAL
[1...7]
TELEPHONE NUMBER
TEL =
Sep 17, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
How do I save a number
You can download the User Manual from here (temporary link): http://dl.dropbox.com/u/1322442/CANON CFX-L4000.pdf
DATA REGISTRATION
1 .SPEED DIAL SETUP
2. Press SET twice.
1-TOUCH SPD DIAL
01
1-TOUCH SPD DIAL
[1...7]
• You can also do this by pressing FUNCTION, then pressing the One-Touch Speed Dialing button, then pressing FUNCTION again.
• If a number is already stored at the button you select, that number appears.
• If the button you select is registered for Group Dialing, GROUP DIAL appears.
TELEPHONE NUMBER
TEL =
• Press SPACE to enter spaces between numbers. (Spaces are optional and are ignored during dialing.)
• If you want to clear a number or a mistaken entry, press CLEAR.
• To enter a pause in the number, press PAUSE one or more times
Aug 19, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
I don't understand the one touch dialing on the HP 2140
Hi Suzeo. Many HP fax machines have the function you are requesting. It is called the broadcast fax feature. Look in your owner manual for this feature. If I knew which model you have I would have researched it for you. IF by chance, your machine does not have this feature, it would be money well spent to replace your current machine with one that does. Depending on how many pages the daily fax is, I am estimating that you are spending an hour or more each day on this task. J.
Jul 03, 2010 | HP Office Equipment & Supplies
I push the feature button it turns red as soon as i enter the phone number the light goes out press feature and does not program
Why are you pressing the feature button?
Press feature then answer. You envoked ringing line pick up.
Press feature then speed dial button, dial a number like your dialing out, then feature again. You've just set a speed dial button.
Press feature, then 3 and you've changed your ringtone on a series i phone.
Mar 16, 2010 | NEC Dterm DTP 16D-1 Corded Phone
I have a Brother IntelliFax-4100e fax that speed dial button 04 needed to be changed when we changed our phone system to include a 9 at the beginning of the number. Did that, it was 'accepted', but still...
go into menu, then to fax (hit set) then one touch speed dials (hit set) then hit the 04 one touch button and it should show you what is programmed. You can hit number 1 to change, type the number with a 9 in front of it(ie. 9+1+area code+7 digit number) then hit set and program a name for the number, hit set until the fax beeps to accept the change. You can test it with a blank cover sheet. That's how I have mine at work set up and it works fine. Hope this helps.
Jan 29, 2010 | Brother IntelliFax-4100e Fax
How do you set and delete speed dials on minolta 2800 fax
Speed Dial Keys
The fax number and other data for a particular destination can be programmed using a 3-
digit Speed Dial Number. This feature allows you to transmit a document to the
particular destination by pressing the Speed Dial Key, entering the 3-digit number and
pressing the START Key. You can program a fax number in any of the 100 Speed Dial
locations, number 001 to 100.
Entering
1 Press the PROGRAM Key and scroll through the
menus until you reach the DIAL REGISTRATION
Menu. Press YES to begin programming.
2 Press 2 or scroll down to the Speed Dial menu and
press YES.
3 Enter the number of the location you want to
program and press YES.
4 Enter the Telephone number you wish to transmit
to and press YES after checking to see its OK. If
you want to enter the sub-address, press the Down
Arrow Key.
5 You can press sub-address up to 10-digit.
REGISTERED! KEEP?
OK=YES (EDIT/DEL=NO)
EDIT *DELETE
-SELECT&PUSH”YES”-
DIAL REGISTRATION?
YES / or 1-6
2 SPEED DIAL?
OK=YES
SPEED DIAL =_
OK=YES
OK=YES (SUB= )
SUB=_
OK=YES
Edit/Deleting
1 If you wish to change any entry, a screen allows you to accept or change.
2 If you wish to change a Key that was previously
programmed, this message appears. Press YES to
keep this location as is, or NO if you wish to edit it.
3 If you choose NO, use the arrow keys to select
either EDIT or DELETE and then proceed with the
needed changes.
Group Dial Keys
Instead of their regular functions, any of the One-Touch Keys can be used as Group Dial
Keys. Destinations already stored for One-Touch, Speed Dial can be entered in a Group
Dial Key. Each Group can contain up to 50 locations.
Entering
2 Press 3 or scroll down to the Group Dial menu and
press YES.
3 Press the One-Touch Key you wish to use.
4 Press YES to accept your selection.
NAME=_
OK=YES
REGISTERED! KEEP?
EDIT *DELETE
-SELECT&PUSH”YES”-
Nov 28, 2009 | Minolta MF1600E Plain Paper Laser Fax
Canon LaserCLASS 710 Fax Owner's Manual
Set Speed Dial / One-Touch Feature
  1. Open One-Touch Speed Dialing Panel and press “Data Registration.”
  2. Under “Additional Functions” scroll to find “4. ADD. Registration” and then press “Set.”
  3. Scroll to find “1. 1-One-Touch Speed Dial” and then press “Set.”
  4. Under “Tel # Registration” scroll until the desired “One-Touch” number is displayed. Press “Set.”
  5. Under “Tel # Registration” scroll to find “1. Tel Number Entry” and then press “Set.”
  6. Under “Tel Number Entry” enter fax number (with “9” and the area code – ex. 913104454200) and then press “Set.” Screen will display “Data Entry OK.”
  7. Under “Tel # Registration” scroll to find “2. Name” and then press “Set.”
  8. Under “Name” enter the company name and press “Set.” Screen will display “Data Entry OK.”
  9. Press the red “Stop” key on the main control panel.
  10. The “One-Touch” feature is now set.
Label corresponding “One-Touch” button with company name.
Jan 30, 2008 | Canon LaserCLASS Fax 710 Printer
Memory dial
Press the Menu button
Then go 2.Fax, then press Set
Scroll through to 3.Set Quick Dial and press Set
You will then have the option of One Touch or Speed Dials
Once you have selected the one touch. Simply hit the one touch button you which to program. Then program in the name and number.
Jan 25, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Canon LaserClass 2060P Plain Paper Fax Logo
228 people viewed this question
old marine
old marine
