Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Thread Mess! when I try to embroider the thread ends up tying knots and making a big mess under the plate. I have no idea what to do, I have changed the bobbin,the needle, the top thread, cleaned it...what else is there to do!?
    Scholar:
  • 110 Answers
The symtoms you describe are typical to insufficient top tension.
First check the dension dial is on S for normal sewing and E for embroidery. If this is the case, re thread your machine with the pressure foot up and make sure the thread goes over the take up lever.
Posted on Dec 10, 2007
Thread bunches up into a knotted mess on bottom. Bobbin doesn't sit flat inside the bobbin case but spins with a tilt, lower on the left and higher on the right. Bobbin touches plastic cover plate.
Usually, thread bunching under the fabric is an upper tension issue. Be sure to ALWAYS RAISE the presser foot when threading the upper thread.
With the bobbin case operating at a tilt, there is something mechanically wrong with the machine. It may be best to take it for service.
Aug 30, 2016 | Singer 4411 Heavy Duty Sewing Machine
Birds nests embroidering husqvarna viking designer se
it would be a good idea to have the machine serviced
Try these suggestions for bird nesting
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case
& make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
6. Check to make sure the bobbin is not warped or damaged
7. Make sure the bobbin case is correctly in the machine,, if it's a top loading bobbin you may need to have the bobbin case checked to see if it's damaged or see if the hook and hook race has a problem
8. Also could be a timing problem, and the machine would need to be checked.
Feb 19, 2014 | Sewing Machines
Cant get my bobbin in right position it keeps knotting up on inside of fabric
Top thread problem, Not enough tension on top=loops on the bottom of the fabric; too little tension on the bottom = loops on top of the fabric. Yes, I know it seems backwards. See: http://www.picturetrail.com/sfx/album/view/22521551
Dollars to donut holes, you either threaded the top of the machine with the presser foot down (it has to be UP to let the thread into the top tension), or you're trying to sew with the presser foot still up (which is an issue common to people trying to sew bulky seams).
Take the thread off the top of the machine, take out the bobbin case and give the machine a cleaning, rethread the machine, fetch up the bobbin thread and hold the bobbin and top thread ends together under and behind the presser foot for the first 2-3 stitches of each seam.
Jan 26, 2014 | Brother LS-2125 Mechanical Sewing Machine
I have my grans Elna Contessa305, I am no expert sewer but know how to thread a machine correctly. However, the stitching at the bottom keeps getting knotted and making a big mess. I've re-thread
try changing the needle --one that is correct for the fabric being sewed
try a different thread
make sure the bobbin is inserted correctly into the bobbin case
and turned the right way.
make sure the top thread has not come off the thread take up lever
Feb 12, 2013 | Elna Sewing Machines
While embroidering the top thread gets wound around the bobbin and makes a nest on the bottom
have you tried changing the needle
rethread the machine top & bobbin
when embroidering make sure it good quality thread
clean under the needle plate & in the bobbin area for loose threads & lint
make sure the thread your using it not knotty
make sure the tension is set for the thread & needle & fabric your using
Mar 17, 2012 | Brother Sewing Machines
When I embroider, the back of the material gets enormous knots in the thread. What can I do to fix it?? Thank you!!
change the needle
check to make sure the thread has not come off the thread take up lever
change the thread on top & bobbin area
clean under the needle plate & bobbin area for loose threads or lint
check to make sure the bobbin is not warped
check to make sure there are no burrs on needle plate
make sure the bobbin is wound correctly & inserted correctly
Aug 11, 2011 | Brother Sewing Machines
When I start to stitch it just makes a big mess of knots
It is usually your top threading. Try this test, with the presser foot up, pull your top thread, it should pull smoothly, now put the presser foot down, pull top thread, it should barely move. Sometimes, just doing that seats the thread into the tension discs. Hopefully, it will help you. Another thing, make sure that you use good thread, and try a new needle also.
Nov 05, 2010 | Singer 7422
Top thread will not pick up bobbin thread makes a big loopy mess
This is sometimes caused by the upper thread not threaded correctly. You need to thread it first with the pressure foot in the up position. You need to "floss" the thread into the clear plastic guide as this is where the tension is. The tension should be set to E for embroidering. Also make sure you get the bobbin thread in the slot on the bobbin case. Also, lower your pressure foot before you begin embroidering. Hope this helps!
Sep 20, 2009 | Singer CE-100 Futura Computerized Sewing...
Bobbin thread bunches up creating a tangled mess under the plate
This could either be due to the bobbin being wound too loosely, or the tension on the top thread is too loose. This just happened to me the other day, and I thought it was the bobbin thread, but then I put another bobbin in with a different color than the top thread (this is a huge help in diagnosing thread issues), and I was surprised to find that it was actually the top thread that was a big loopy mess on the underside of the fabric. I fixed it by tightening the tension on the top thread (quite a bit), and everything was fine.
Jan 23, 2009 | Husqvarna Viking 1
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
109 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
