Garden Logo
Anonymous Posted on Sep 10, 2009
My lawn tractor won't start no spark an I have aready replaced the electrical control circuit board. It is a LX277 lawn tractor year 2000 I think. After I replaced the circuit board It still did't start I check wiring from coils to curcit board tested ok. I checked conection again and while probing with test light at curcit board white wire from coils while cranking it started and then it started everytime then on about a month later it started not starting again and has no spark again at either coil.
  • Anonymous Sep 11, 2009
    john deere lawn tractor LX277 I checked for spark with a inline spark tester and has a very very faint spark then I checked for spark
    with a spark plug type tester and has no spark
    The coil only has 1 wire going to them and I don't think it has any points to check I think it is electronic ign. As I said before I replaced the electronic module part and ign. switch and it still didn't start for a long time then it just started and run thereafter until about a month later when this happen no start again.
  • Anonymous Mar 19, 2014
    I went to start my tractor and when I turned the key on the radio worked and everything seem normal but when you turn the key to start it everything quite working. I have checked the conections on the battery and cleaned them but it still does it . You can let it sit for a few minutes and it will kick back on until you turn the key. It acts like it's loosing ground. What could cause this.
Anonymous
Level 3:
President:
  • Master 1,884 Answers
  • Posted on Sep 11, 2009
Anonymous
Master
Level 3:
President:
Answers
1884
Questions
Helped
476315
Points
5973
May be the coil is bad. have you checked the spark plug? If there is gas and spark then it will have to start.check the circuit breaker points. is there current in the cb points?
2answers
Craftsman DLT 3000 lawn tractor. It won't turn over with a new battery.
Question edited for clarity, 'make model (what it is)'.
Question moved from Cars and Trucks.
Batteries can be new and not be fully charged. Lots of ideas in the link, but test the starter solenoid first.
https://www.google.com/search?q=Craftsman+DLT+3000+lawn+tractor.+It+won%27t+turn+over+with+a+new+battery
This battery tells you how to load test a battery, about connection being clean. Also that new batteries aren't always fully charged. He explains the solenoid function
And another good electrical testing video.
John Deere LX277. Engine won't stay running when
I would check the air filter, but I doubt that is the general problem. I would think that would have started the problem, but, You most likely tried to start it "right after you washed it",,,and you might have sucked, (for lack of a better word),,some condensation, "water", into the carb....in which case,,,,best scenio,,,,Spray a bit of carb cleaner into the air intake, but only after you clean",air filter" that before. And if that doesn't work,,,,then you would have to clean and drain the water out of the gas,,,,,and carb...............Check the spark plug too, and clean it,,with ethanol in our gas now,,,,,,,,,,,It can really mess with just about anything.....my car and my lawn mower....are a constant "mess"
Sep 13, 2013 • Garden
Jon Deere mower LX277 won't crank
Try replacing the starter solenoid. If that doesn't do it, try replacing the whole starter.
Tractor wont start
For a small gas engine than won't start, think FAST -- Fuel, Air, Spark, Timing. You've replaced the filters and spark plugs and squirted in some starter fluid, eliminating the simple common fuel, air, and spark problems -- but I because of the backfiring I think your problem is in the timing -- like a sticking valve. Probably more than you want to tackle at home, but might not be as expensive as an engine replacement. Take it to a good small engine mechanic -- best bet is a lawn equipment shop that has been around many years. Drive a little farther to get to one if necessary.
Craftsman Lawn Tractor - Electrical
make sure you mower deck is not still engaged. that might make it not start with that safety switch.
Top John Deere Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a John Deere Garden Expert? Answer questions, earn points and help others
