Question about Sharp Viewcam VL-AH160U Hi-8 Analog Camcorder
Ihave a view cam made by sharp and the model #vl-ah160 and it does not hold its charge even wih new batteries.i had drop it and i was wondering if this can cause it fo not holding a charge
  • Sharp Master
  • 4,924 Answers
If it still works ..I dont think this should have cause any problems ....I guess the power issues came from poor quality of the accumulators or better from a not that great formating of them when they were brand new....another cause may be the age ...after all even in mobile phones , those rechargeable ones have a limited life time ...and his is the way they behave .....I mean they begin to last less and less.. a solution might be new ones...or even try to never let them inside the camera even when the power is off...cause all cameras empty them batteries when they aren;t even on ...
Posted on Sep 10, 2009
Battery will not charge
Dear Lisa
Check may be that battery is faulty ,
or new charge is not compatible with the model
Cheers
Apr 13, 2014 | Sharp Camcorder Battery for VL-E39U
Hello. I used to own a SHARP VIEWCAM Camcorder (model# VL-E650U). I lent it to someone & never received back. I would like to know if there is any other product/device that I can use to play/view the...
Want to buy my VL-E650U Sharp Viewcam? Selling bag, camcorder, 3 tapes, manual, remote, and two batteries. Although the batteries don't hold juice very long any more, all the other items are in great shape without blemishes. Liz
Jun 17, 2011 | Sharp VL-E650U 8mm Analog Camcorder
I have sharp VL E630 the battery is charged I put it in the camcorder the screnn fickered a couple times the went black and now nothing? Allan
Many times the contacts that hold the battery in place become compressed and they no longer make good contact. This results in not only the battery no charging often, but the camera not working. Make sure that the metal tabs are holding the battery securely.
The other possibility is a short. This is much harder to troubleshoot and may require you take the camera in for repair. But if the device has a short, it will shut the camera down.
May 05, 2010 | Sharp VL-E630U Camcorder
Battery or Charger bad?
If you persistently leave the batteries discharged, it is unlikely that they will be able to hold a full charge. You should re-charge your batteries at least once a month, even if unused. Put it on your calendar. BTW 2 years old is hardly 'brand new'.
May 26, 2017 | Sharp VL-E630U Camcorder
Sharp view cam vl a10
my view cam is blury when you try to play any movies on it.
May 31, 2008 | Sharp Viewcam VL-A10U Camcorder
Sharp view cam
This style camcorder has an adapter that feeds off of the battery charger...the charger plugs into the wall on top of the charger you place the battery and if you look on the front of the charger you will/should have an outlet that looks like two holes. This charger should have come with an adapter that looks like the battery only it is attached to a cord. You should than be able to open the battery compartment and insert the corded (battery) and presto it works...if you do not have one you can contact Sharpusa.com
May 29, 2008 | Video Cameras
Dew
Model: VL-Z800 Sharp ViewcamZ
I was in Shanghai in Dec 2008 over Christmas and I experienced the 'DEW' problem. The cassette tape door would not close either. I did not experience this before even after 2 years. I suppose the cold & the rain water causes the dew to accumulate in the CAM.
Solution.
I did the reset by taking out the small tiny battery situated just above the big battery. The small battery has a cover. Pull it up & Get the small battery out and the whole camera resets. Re-entering the date & time is the only inconvenience. After reseting, I could use it again, but not for long as the problem comes back. When I came back to Malaysia (Temp 32-34 degrees celsius), the DEW problem disappappers.
You could also try this method to get rid of the dew. Buy a small sack of rice. Yes rice, the uncooked ones. Cut open a small opening just big enough to put your CamCorder into the sack. If you do not want to get your CAM dirty, wrap the CAM with tissue paper. Close the opening with a musking tape and leave it a few days. The dew should disappear from the CAM. It works for mobile phones too when it is accidentally drop into water. Of cause you should not switch on the mobile when it is still wet. It will self distruct if you do. Try the rice solution for a week before you on your mobile.
Rgds/ T.S
Dec 17, 2007 | Sharp Viewcam VL-Z1U Mini DV Digital...
Sharp vl-nz50
i need the software and the driver for my video camera
Nov 25, 2007 | Sharp Viewcam VL-NZ50U Mini DV Digital...
Sharp Camcorder VL-NZ100E battery doesn't seem to charge
2.7 volts is too low. Usually camcorders use battery at least 6 volts. Problems with rechargeables especially NiCds and NiMH, a cell will be shorted. for 6 volts pack, there are 5 cells in series (5 pcs x 1.2 volts with load , 1.35 no load). If you are measuring only 2.7 volts, it is highly possible that 3 cells are dead. As for the charger, if the same charger is used to power the camcorder and you said the the camcorder operates using the adaptor, this means that the charger is OK. You can ZAP the battery back to life but I will not recommend. It can be dangerous. If you can buy the battery, I suggest you do it since the old battery, even when zapped, will not provide enough juice anymore.
May 22, 2007 | Sharp Viewcam VL-NZ100U Mini DV Digital...
Sharp Viewcam VL-AH160U Hi-8 Analog Camcorder Logo
78 people viewed this question
Top Sharp Video Cameras Experts
NOEL
NOEL
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
