Question about Frigidaire ATF6000ES Front Load Washer
Frontload washer, affinity
The plastic pin that goes into the machine thats attached to the door broke off inside the machine. does anyone in gods green earth know how to get this plastic piece out of the machine? it seems to be caught on something.
  • reeta Dec 19, 2007
    Thank you for the information. I was trying to avoid not having to pay for a repairman, but in the end I called one. I didnt want to chance it and now I know why you cant get it out, I thought both the prongs that are on the door that fit into the washer are totally different than the other. Thats why I couldnt get it out. The washer door was broken and the repairman is due back tomorrow to finish fixing it, we had to special order the peice, but i will be one happy camper when its fixed!! If theres clothes anywhere in the house, clean or dirty, Im gonna run them through again. Just goes to show...... you dont know what you got til its gone!!! thanks
    Sergeant:
    Champion:
  • 262 Answers
You have to take the front lower panel off if it is the piece im thing about if not you have to dig the front off be careful on how you take it apart because it has to go back together the same way good luck
Posted on Dec 18, 2007
How can i take the front off the washer to replace the door latch ?
You shouldn't have to take the front door or panel off to fix the door latch. You should have part on the door and part on the inside panel of the machine.
Jul 27, 2012 | Frigidaire Affinity ATF7000E Front Load...
Door sags and is out of alignment. Do I tighten screws?
If there are any screws right where the door connects then they shouldnt be loose. If you can lift the door up and then close it you probally just have a couple of screws loose LOL! If not then you might have broke the pin inside the door. Either way it should be fixed before you have water damage. Hope it helps let me know what happens. Thanks
Dec 22, 2010 | Frigidaire Affinity ATF7000E Front Load...
My washer door is broke a small pin in door is broke
If the pin is broken merely insert a new pin or screw that fits. If the plastic housing is broken you will need to replace the door.
Sep 07, 2010 | Haier XQG50-11 Front Load Washer / Dryer
Hi i have a WMA 50 and my little boy swung on the front loader door and it broke off at the hinge's the plastic part where the hinge goes, i have been told that hotpoint has a parts department that has all...
You can order the parts you require directly from Hotpoint.
Go to ;
WWW.Hotpoint4u.co.uk.
Click on washers, and follow the guide.
The part numbers are as below.
1603448 Hinge bearing.
1604434 Hinge assy.
This should solve your problem
Dec 17, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Can''t get my clothes out... water still inside
does it have a dial that you can manually turn to start the next cycle? You can usually drain the water by pulling the drain hose out from the wall drain behind hte washer....( usually just shoved in the drain not attached) but be aware that when you hold the hose below the water level in your washer it will start to drain. Then perhaps the door will unlatch.
Sep 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
My washer door isnt staying locked
Your probably need to replace the door striker (two pronged plastic prongs) thats attached to the door with two screws, or, the door switch. The door switch can be accessed by taking off the top lid and removing the two screws in front of the machine. The switch is a whole lot more expensive than the striker. Be sure to pay attention on how the switch is wired!
Jun 04, 2009 | Frigidaire Affinity ATF7000E Front Load...
Washer spin cycle
CHECK THE DOOR/LID. THERE IS A SAFETY SWITCH THAT WILL NOT LET THE SPIN CYCLE ACTIVATE UNLESS THE SWITCH IS ACTIVATED. THE SWITCH COULD BE A PLASTICE PIN THAT THE DOOR DEPRESSES WHEN CLOSED OR A PIN (SHAFT_ ATTACHED TO THE DOOR THAT GOES INTO A HOLE TO ACTIVATE.
ONE OTHER CAUSE IS THAT THE SWITCH WIRE MAY HAVE FALLEN OFF OR BEEN PULED OFF. **tHIS REQUIRES YOU TO REMOVE THE BACK OR SEPARATE THE TOP FROM THE OUTER CASE))) IF THE PLASTIC CLIP THAT HOLDS THE WIRE IN PLACE BREAKS ..THE WIRE COULD VIBRATE OFF.
Apr 30, 2009 | Washing Machines
Maytag Neptune Frontloading Washer
5d is actually Sd, which means too many suds. Make sure you're using "he" types of laundry detergent.
Jun 14, 2008 | Maytag MAH6700AWW Neptune Front-Load...
My affinity washer (front load ATF6000ES) is leaking detergent
are you using he detergent?. if what you see on floor is pure detergent then look at dispenser housing for cracks. remove drawer, open, depress lever in back and pull out, to see inside housing. If the screw or mounting for the loose paddle (baffle) broke and slammed housing in some way then you would also have a hole in the tub. You can easily remove top, 3 screws in back to check this. If tub is broke, buy new machine!
baffles are usually attached with screws from outside basket, requiring removal from tub
Mar 13, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire ATF6000ES Front Load Washer Logo
53 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
