Question about Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966
Weed eater runs slower
My weed eater runs slower then usual, why ?
  • 11,896 Answers
Your air filter may be plugged, your pug may be fouled, or your carb may be gummed up.
Posted on Sep 10, 2009
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Ss30 ryobi weed eater fuel ratio
    I work with weed eaters and mowers. Weed eater fuel ratio is normally a 40:1 ratio. That usually all weed eaters fuel ratio.
    Sep 11, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
    My weed eater starts but won't stay running. what
    Try a new spark plug.Thanks for asking and I hope it helps
    Jul 19, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
    Powerpro 17" McCollich weed eater
    hey harry the float inside the carb is stuck i would suggest rebuilding the carb
    Jun 27, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
    I have weed eater model FX26SC it starts and when I put it to run the weed eater doesn't spin but is running
    Either the clutch is worn out or the flexible drive shaft is broken. Either repair is likely to cost almost as much as a new unit.
    May 16, 2010 | Garden
    Ryobi weed eater head won't spin
    Sounds like the clutch has taken a long trip south. If the clutch pads are not wore out, try some wd40 on the pad hinges.
    Apr 27, 2010 | Ryobi Garden
    Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966 Logo
    424 people viewed this question
    Top Troy Garden Experts
    Jim Parker
    Jim Parker
    Matt Olenzek
    Matt Olenzek
    DROPNDEAL
    DROPNDEAL
    Are you a Troy Garden Expert? Answer questions, earn points and help others
