Question about Garden
Engine will not turn over
I have a Poulan Pro riding lawn mower model PPR1742STA. I was cutting the lawn and the engine died. The only fuse on the engine harness blew. I replaced it with a new one, and now when the key is turned, the engine will not turn over. I replaced the ignition switch with a new one, and it still has the same problem. I was able to get the mower started by jumping the starter directly from the battery. That worked until the fuse blew again shortly after.
  • ant4886 Sep 10, 2009
    Replaced ignition switch with new one, still doesn't turn over. Wiring is fine too. I think it is the solenoid, but I want to be sure before buying another part. I am also able to start it by touching two of the terminals on the ignition switch with a paper clip.
  • 11,896 Answers
If you can jump and start it, then ignition switch or circuit is faulty
Posted on Sep 10, 2009
  • Nate Stansfield
    Nate Stansfield Sep 10, 2009
    If you can jump solenoid terminals and it starts, then it's the switch. If it starts by jumping ignition terminals but not key, then it is a bad switch.
Popular Pro 625 series. starts and runs but why does it die while cutting?
Poulan PR625Y22SHP Lawn Mower User Manual
homeappliance.manualsonline.com > ... > Poulan Lawn Mower
Poulan PR625Y22SHP Lawn Mower User Manual ... Briggs & Stratton 850Professional-Series Commercial Replacement Push Lawn Mower Engine (190cc, 7/8
Sep 11, 2015 | Garden
Poulan pro engine dies when blades are engaged
Something may be wrapped around the blade shaft under the mower deck or maybe the shaft bearings are bad.
Aug 10, 2014 | Poulan Garden
I have a Poulan 550 158cc Push Mower. Two Model #'s 96132004200 and PR0550N21RH3. Two Serial #'s 0901075421770 and 011309M001762. The mower will run if primed then dies. The carb. is on the tank. I...
does it have fresh gas in it, If so time to rebuild the carb, even though you blew through all holes there is a diaphram inside the carb that pumps gas to it, so I suggest you take the carb apart and clean inside out and replace the diaphram, the way you describe it only runs on primer, tells me the carb is not getting fuel. Good Luck
May 14, 2011 | Poulan Pro PR550N21R 21Inch Briggs ...
Poulan Pro riding mower jerks in forward and the blades engaged
This is a lawn mower catagorized as a chainsaw. We don't answer lawn mower questions ands you don't cut down trees.
Mar 23, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Gas/ oil mixture
If it is a riding lawn mower it is probably not a two cycle engine so there would not be a gas oil mixture. It must be a 5 horse power or higher so it would use straight gas. I hope this will help you. donnyb60
Mar 20, 2009 | Poulan Garden
Poulan Pro Lawnmower
i have a 950 zx poulan pro lawn tractor. it will start but when i release the brake it cut off . i can start it up with out sitting in the seat.
Jun 14, 2008 | Dryers
Garden Logo
279 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
