Question about Sony Playstation 3 (PS3) Console
Not reading discs of any type
Was crashing now and again and thought it was just the lasers. tried a laser cleaning disc and now it won't even read that! no warranty as was bought off ebay plus its 3 yr old model now anyway. i am soooooooo bored so please if you can help i would be truly grateful!!!
  • 148 Answers
You will need to disassemble your Ps3 and see if you can adjust the blu-ray laser focus...or try to buy a new bly-ray optical lens:
http://www.diytrade.com/china/4/products/4913589/PS3_KES410AAA_Lens.html
Good Luck !!!
Posted on Sep 10, 2009
Keeps telling me bad disk...the dvd works in another machine. What does this error mean?
Some players are better then others, try a different disc, if it plays then, player is fine, it's just not got a good enough laser eye to read the disc you want to play or laser eye is dirty. You might try cleaning laser ,player to see if that's problem. If it won't play other disks even after cleaning then it's time to replace player. Not sure what type disk your trying, dvd or blu ray, but I've noticed that dvd's play better in blu ray players, they have better laser eye for reading disc.
Mar 05, 2016 | Televison & Video
Panasonic bluray SC-BT207 won't read disc
Depending upon the age of the equipment and the fact that a laser cleaning disc was used the drive may be failing and only able to read a disc intermittently..
Jan 09, 2014 | Panasonic Audio Players & Recorders
Will not play
Hello Brandon
The fault is with its Laser Picku Unit itself. The sled motor, the motor that spins the disc inside the DVD player, should wok like this as you details here. Just see, when we put in a disc inside any disc player, it will sart spins, after it has been loaded properly into the mechanism. The the laser pickup unit will start scan the recording on the disc, reads it; recogonize its contents, then starts to play from the first track. This is an automatic process ot all disc players, and suring this reading process, the spin speed of the disc will vary, may stop, or rewind to a little and then spins again. This is a common process to all the playeres.
Here, with your DVD player, the laser pickup unit tries to read the tracks, but fails, the again it starts to readit, fails and finally show a 'No Disc' display, as it hasn't got any details about the recoding at the inserted disc.
There are three main causes for this fault. The first one is with a faulty strip wire. This wire is one, that connects the laser pickup unit with main board. You can see a flat ribbon type cable that connectes to laser pickup unit at the mechanism, to the main circuit board of the player. Replace this cable fist. This cable can be purchased from most of the electronic spare part shops at your town, and won't cost more.
The second chance is with dirty or dusty laser pickup unit lens. To cclean this lens, the easisest way is to put in a lens cleaning disc into the unit, play it for at least three times, by ejecting it out and get it into. This process will clean up any dirt or dust accululated on the lens, and will help you. The cleaning disc also can be bought from most of the electronic spare part selling shops at your town.
The third chance is with a faulty Laser Pickup Unit istsef. If so, there is no repair to this unit other than replacing it with same type and number. It is a skilled work, and you have to disassemeble and reassemble the deck mechanism. If you have experience to dothis, you can do it by yourself at home Ok
Please do rate this solution, if it found helpfull to you.
Dec 29, 2011 | Durabrand PDV-709
Won't read d d keeps saying bad disk
Hello, welcome to Fixya!
Was this player playing previously? And how long have you been using this player? I suspect the lens of the player. Once the lens of the player becomes weak, it won't play discs any longer.
The first thing my mind goes to, is the lens. The lens id responsible for reading/loading data on discs. So if the lens is unable to read the disc, there is no way the player is going to play the disc.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or probably, a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
Oct 05, 2011 | Curtis DVD1041 Player
Disc in system but it is reading no disc?"???
I suggest to try with another disc. If that happens again, then try to clean lens with special disc. And if then won't help, then you'll need to change laser that reads discs. Usually it's not worth trying
Aug 30, 2011 | Insignia NS-8PDVD
Xbox 360 will not read disc
You need to either clean the laser or replace the dvd-rom drive.
Both of these cases involve opening up the console and voiding any warranty Microsoft offer.
First you need to determine if its not reading a certain type of disc, or not reading any disc at all, if iys not reading any disc at all, it may have grime or dirt on the laser causing the problem.
You can clean the laser with a clean cue-tip or cotton swab, by opening the console, removing the dvd-rom drive and then opening the dvd-rom drive case to expose the laser.
If after cleaning the laser it still does not read discs, you need to replace the dvd-rom drive. I hope this helps. Good luck.
Sep 03, 2010 | Microsoft Xbox 360 Console
Ps2 doesnt read disc
You can clean the laser, although that isn't necessarily the problem. You can pick up a laser cleaning disk at any retail electronics store, such as Best Buy, RadioShack, and sometimes even Walmart. You can also open your Playstation 2 and use a Q-tip and rubbing alchohol to clean the laser. The problem is likely though that when you first loaded FIFA the data was corrupted on your memory card. Try deleting any FIFA data off of your card and then starting the game.
Feb 22, 2010 | Sony PlayStation 2 (PS2) Console
"No Disc"
"No Disc" also means "I can't read the Disc". The laser must be able to read the disc or you'll get that. There are several reasons:
Bad or noncompatible Disc: Some units won't play certain types of recorded discs. Try a rental or bought DVD.
Dirty laser lens: Either try a cleaning disc, or GENTLY clean the lens with a moistened Q-Tip.
Defective components like laser, spin motor, tracking motor, etc. Usually requires professional servicing.
Hope that helps...
Geno
Mar 25, 2008 | Televison & Video
Disc won't spin. Disc doesn't show up in browser
You got a problem with the lasers data getting back to the Motherboard.
One of these could be your problem
  1. Laser lens is melted. Look at the lens with a magnifying glass to see if it or its supporting frame is melted. REplace the laser in this case.
  2. The ribbon Cable going from the Laser to the motherboard is damaged or loose.
  3. Your laser is burned out. Press the two interlock to override the door being open, to see if the laser even lights up. 2 switches, one at rear left corner, one behind the On/reset switch.
  4. Your Laser is dirty and needs cleaning look at it with a magnifying Glass to make sure you got it clean. Use Q-tip and window glass cleaner, not alcohol.
Nov 25, 2007 | Sony PlayStation 2 (PS2) Console
Sony Playstation 3 (PS3) Console Logo
118 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
