Question about LG WM1812C Front Load Washer
Lettering from my LG Washer & dryer smearing off
I got the LG steam washer & dryer. Letters started smearing off within a few months. Panels were replaced under warranty and immediately did it again. Contacted LG & got the run around. There needs to be a recall.
2 Suggested Answers
SOURCE: LG washer letters smearing!!! WM2487HWMA
is it free
Posted on Jul 18, 2009
How to start and use it
For complete operating instructions for your LG Steam Washer you can go to managemylife.com and download or print an owner's manual for FREE. Just enter your model number under the "Manuals" link. For your convenience, here is a direct link to the owner's manual for your washer:
http://www.managemylife.com/mmh/owner_manuals/72381/LG-Front-Load-Washer-WM2601?brand_name_search=WM2601H
If you still require assistance, please post back and let me know. I hope you find this information helpful.
Apr 18, 2011 | LG SteamWasher WM2601H Front Load Stacked...
LG Wash WM2487H*MA- how to turn the tub clean feature on?
I have had this problem since I bought my washer. Some days the tub clean cycle will work....most days it won't. They have replaced the main board twice and it's still broken. I've had nothing but bad luck with LG appliances. Also bought a lemon fridge that took 4 repairman visits to fix. I will not buy another LG anything!!
Jan 17, 2010 | LG WM2487H Front Load Washer
How do I fix the lg lettering wiping off of my lg washer
you don't, you have to replace the control to correct this wear problem, they don't sell just the lettering overlays/
Sep 02, 2009 | LG WM1812C Front Load Washer
Wm 2487H. My machine is off balance and shake the house terribly bad. It also has a metalic scraping sound sometimes when the drum spins. I just purchased my LG washer and dryer a couple of months ago. I...
Starting in November 2008--LG introduced "square door" model washers.
These washers will (unlike round door models) perform very well on wood floors.
If the WM2487 washer is on a wood floor--even a tiled wood floor--it will be near impossible to get smooth spin performance.
Some homeowners have had success by adding two layers of 3/4 inch wood under the washer AND dryer.
The following steps were taken:
1) Remove washer & dryer
2) Cut & remove any floor covering (bare wood)
3) Locate floor joists with a stud-finder & mark locations at the edge of the flooring--allows finding the joist locations after 3/4 sheet is laid to floor.
4) Add wood glue to floor
5) Place 3/4 inch wood sheet to floor & drive screws thru wood into joists (as many scews as deemed necessary to fully & completely compress wood sheet to existing floor
6) Add wood glue to 1st wood sheet
7) Place 2nd 3/4 inch wood sheet on top of 1st wood layer and drive screws into floor joists.
8) Add molding if desired
9) Re-install washer & dryer and level.
10) Add one heavy towel into washer tub & close door ( this will mimick an off-center load)
11) Press power "on" button
12) Press "Spin Speed" button & select high speed spin option
13) Press "Start" button
14) When * 9 minutes remaining * is displayed--use the flat wrenchette that comes with every LG washer to "tweak" the adjustment of the front leveling legs. This will allow for "fine tuning" adjustment of the front leveling leg(s) to eliminate vibration / noise during the spin cycle. The rear leveling legs DO NOT need further adjustment.
NOTE: Those with pedestals--check the front leveling legs on the washer and on the pedestals (front only) during spin.
Jul 16, 2009 | LG WM2487H Front Load Washer
Lettering smearing on LG panel washer & dryer
This is ridiculous. All appliances with such lettering should get negative reviews. I will be the one to start. Only the squeaky wheel gets the grease
Dec 29, 2008 | LG WM1812C Front Load Washer
L g steam washer front load
The model you have this listed under WM2688H (LG Steam Washer) a E1 Code Correct water level (246) is not reached within 8 minutes
after water is supplied or it does not reach the preset water
level within 25 minutes.
I suggest you
Check the screens in the water inlet valve for blockage
Feb 18, 2008 | LG WM2688H Front Load Washer
LG WM1812C Front Load Washer Logo
60 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
