Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Intek 25hp came in with less than half a quart, would not start. I drained, replaced oil, cleaned plugs, it started but about the time I turned the choke off 5 seconds of running the engine started making a horrible noise. I turned it off. Valve springs are dry there is a little bit of oil in bottom of heads, should the springs be soaked? Should oil have poured out when I took the cover off? What should I check next? Any feedback greatly appreciated
  • 115 Answers
Does this engine have an oil filter? some of the smaller hp models do not and use a flipper system to throw oil on valves if you have a filter , then your oil pump may have run dry and burnt out
Posted on Sep 10, 2009
Testimonial: "I think that is correct. I checked compression, (just used my finger in spark plug hole), absolutely none on one cylinder and very little on other! "
+how to change engine motor oil
let engine cool down. that way all the oil will drain to the pan. leave engine off until new oil is added. it is a good idea to also change the oil filter at this time. you can ask the guy's at the place where you bout the oil, how many quarts your car will take. autozone is a good source. they can also recoment the right oil as far as viscosity. now it's time to crawl under your vehicle and remove the drain plug. don't forget to put the drain pan directly under the drain plug and oil filter that's why i always use a container that i buy from the dollar store, it's big enough to get under the drain plug and the filter(carefull, the oil filter will still have oil in it). i think they mostly use them for doing dishes. let it set and drain for 10 minutes to get the most old oil out..................now it's time to add the new oil and filter. in this order.....add new oil filter(wet the seal of the filter with oil), add new oil except for last quart. (last quart add only half of it as there are lots of cars that require for example.........(5 1/2 quarts) now start engine and look for leaks around filter and oil plug. now remove drain pan or you'll probably run over it. lol take it for a short drive and while engine is still running, check for leaks again. if you have followed these instructions, your done. congratulations !!!.
Oct 04, 2014 | 2014 Nissan Pathfinder - All Pathfinder...
How do you change transmission fluid on a 2007 explorer with no dipstick
WRONG! At least CHANGE the FLTER and 6.75 quarts of MERCON V transmission fluid, not anything less!! $ 5.50/quart at Advance Auto. Get a Haynes manual or similar - it's NOT clear, what to do either! AT LEAST do what's being described for this "life-time sealed A05 Automatic transmission! Now if you have the BMW car A06 speed (so-called) transmission - YOU"VE got a REAL PROBLEM + use MERCON SP fluid ($ 10 per quart).
NOTE car MUST be SAFELY, up at least 18" from the ground and LEVEL. Parking Brake ON and BLOCK front and rear of ALL tires! To CHECK fluid level Trans must be at least 80 degrees F and ENGINE RUNNING = DANGEROUS !
The problem is you need a screw in fitting to properly fill and check the A05 speed Automatic transmission ADAPTER (up to 100 dealer) 9 at Amazon worked for me. A small pump with hose (similar, but larger than what hand soap uses) (from $ 6 Amazon to $ 32 - $ +9 at the car stores). A new filter ($ 18 to $ 100). WARNING some filters say they come with a Gasket, the don't! The gasket is special metal and silicone should be reusable IF you don't tear or over torque (tighten). REMOVE Drain plug, the trans pan 15 small bolts, take off pan CLEAN WELL, remove magnet CLEAN, remove two small bolts on filter, LET DRAIN 20 plus minutes. Wipe with clean, lint free cloth ALL of the bottom of trans - then LIGHTLY clean the gasket surface. bolt up the new filter. Lightly install all bolts. Then LIGHTLY with a short 1/4" ratchet tighten all of them.- NOT TOO TIGHT!
Remove the Torx screw/plug from the middle of the Drain Plug - screw in the Adapter, put pump hose onto it - pump 5 quarts into pan. Start engine, pump the next 1.75 quarts into transmission. Using another CLEAN transmission bottle, remove the hose AT the top of the pump - put into the bottle, when about a 1/4 th of a quart drain out on its own - remove the Fill adapter - reinstall the Torx Plug. WIPE all off evidence of oil - drive! Check for leaks the next day!
While doing this, why not protect your investment AND SAVE MONEY? Change the Oil, Oil Filter, Fuel Filter? Use Purolator or Ford Brand Filters ONLY! Use 15-40 Chevron Delo Diesel Grade Oil or Shell Rotundunda . In 500 miles or less I would suggest replacing oil and filter - NEVER MIX OILS. (or use WD40 (designed for arthritis - it's fish oil with water IN it! Destroys engines! Factual Opinions' count, feelings base on LIES, don't!
Larry LEHenson@msn.com put on Subject: line, your comment!
Jul 01, 2014 | 2007 Ford Explorer Eddie Bauer
2005 fat boy oil change
Stand the bike upright. Remove the dipstick from the oil tank. Remove the drain plug on the bottom right side of the frame. While the oil is draining, replace the oring on the drain plug. Remove and replace the oil filter, after filling the new filter half full of oil. Replace the drain plug. Put 3 quarts of oil in the oil tank. Replace the dipstick. Start the bike and check for leaks. No leaks, you're done! I use HD Syn 3 synthetic oil in my '04 Fatboy, but you can also use a conventional 20w50, as long as it's made for use in and air cooled motorcycle. Don't use car oil!
Nov 04, 2012 | 2003 Harley Davidson FLSTF Fat boy
How to change oil on 1997 chevy venture
there is a drain plug on the bottom of the oil pan you remove to drain the oil its ether a 15mm or 14mm wrench while the oil pan is draining out unscrew the filter apply a thin coating of oil on the gasket of the new filter make sure the gasket from the old filter didn't stick to the engine install the drain plug and new filter add 4 quarts of new oil and run the car recheck for leaks and oil level that one holds 4 quarts or 4 and half not sure but 4 will be safe to start the engine
Mar 31, 2012 | 1997 Chevrolet Venture
Oil change 1994 Cadillac Eldorado
well let me see you have 4.6L engine you need 7.5 quarts of oil with new oil filter.to do the oil change you need large drain pan and oil filter wrench and a metric wrench to remove oil drain plug you need a funnel also.you need first start engine let it run for 5 minutes to warm up thin out the oil so it will flow better.once engine warm up.turn off the engine.open you hood.now safely raise support vechicle on jack stands make sure vechicle parked on solid level ground.place large drain pan under oil pan remove oil drain plug you need a 15m wrench remove drain plug let all old oil drain out until you see slow drip then reinstall oil drain plug dont over tighten drain bolt.then place drain pan under the oil filter then remove oil filter using oil filter wrench or large channel lock pliers.once you remove oil filter wipe oil filter seal surface with clean paper towel.take new oil filter add oil to new filter then install new oil filter hand tight take filter wrench turn oil filter one half more turn dont over tighten will damage oil filter seal.make sure oil pan drain plug is in place. then lower vechicle. remove oil filler cap on the valve cover add new oil to the engine using a funnel to keep from spilling oil all over the valve cover and exhaust manifold.add all 7.5 quarts to oil crank case wait until oil settle down in crank case check oil dip stick oil level should be at the full mark on oil dip stick.dont over fill crank case.once you finished oil level correct crank engine check for oil leaks at oil filter and oil drain plug. if engine running okay you see no oil warning lights you ready wheel and deal.
Nov 20, 2011 | 1994 Cadillac Eldorado
How many quarts of oil does a Corolla Dx hold at oil change?
4 quarts, 5 with filter change according to the book. Rule of thumb, buy 5 and once you drain and replace the filter, start by putting 3 and a half quarts in and check the level. If it's between the marks start the motor and run for 5 minutes then let it sit for 5 minutes and recheck the level. Top off half a quart at a time till you get the oil level between the full and add marks.
Jul 08, 2010 | 1993 Toyota Corolla
My Polaris Sportsman 90 ATV has 70lbs of compression on the engine is that enough ? It does not start .
70lbs for a 90cc should be good, but 80-85 is better. Compression drops from piston rings wearing out, most of the time. Piston rings wear out from old oil...every time. Rule of Thumb: 5 tanks of gas, change your oil !!! It's not a car !!! A car has 5 quarts of oil which takes about 3 months to break down (2,000 miles or so), 90 cc engine has a half a quart, which takes about 3 weeks to break down (based on everyday use) SO...5 tanks of gas, change your oil..
as for the not starting thing, check for spark (should be a blue spark ONLY, any other, replace plug, orange won't ignite gas) if you haven't been riding for a while, open the drain screw on the bottom the carburetor and drain the water out. Ethanol turns to water when the gas sits too long...
Apr 09, 2010 | Polaris ATV
Wheres the transmission fluid plug located
I'm assuming this is an automatic transmission for which there will be no drain plug. If you're wishing to drain and refill the trans. you need to remove the trans oil pan and replace the filter and gasket(kit is about $20-30) and then get a funnel and refill through the trans dipstick tube. Start with 2 quarts, run and shift through all the gears and then check your lavel and fill as necesary by half quarts at a time.
Feb 22, 2010 | 1996 Ford Contour
How to change oil filter on a 1994 honda accord
Just turn the filter counterclockwise until you remove it. You may need a filter wrench if it was put on too tight. Once you remove it wipe the mounting surface with a clean rag. Now apply a light coating of oil to the new filter gasket. Install the filter tightening clockwise until it makes contact with the mounting surface. Turn it 3/4 turn after it makes contact. No more and no less. Now drain out all the oil, replace the drain plug, tightening to 20 lb/ft of torque, and then pour in 4.5 quarts of 10w30 premium oil of your choice. Start the engine, check for leaks, and you have saved some money. Be sure to set the parking brake, put the trans in park or reverse if manual, and use jack stands when you jack up the car to remove the filter and drain the oil.
Sep 15, 2009 | 1994 Honda Accord
How do I change the oil and filter on my car?
under the vehicle you will see a plastic cover under the engine, remove the 4 13 mm bolts and drop the cover (they give you an access port but its cleaner and easier to just take the cover off) the bolt to drain the oil is also a 13mm on the bottom of the oil pan facing the ground. drain the oil, put the drain plug bolt back in and tighten, don't over tighten! the filter is located up the front of the oil pan on the passenger side, only accessible from the bottom, remove the filter let the oil drain, put some fresh oil on the rubber seal of the new filter and install, make sure to follow the directions on the filter because it will tell you how many turns to put on the filter, overtightening will make it extremely difficult to take off next time! after that, clean up any oil left on the frame and oil pan and install the plastic cover with the 4 13 mm bolts, locate the oil fill cap, remove and refill the engine with the right oil (i believe its 5w30) untill it reads full on the dipstick, put the cap back on and start the engine and let it run for about 10 seconds, shut the engine off and recheck the oil level and fill as necessary. (if you have the 4.2 i think it takes 7 quarts, check your owners manual for the oil type and capacity to be sure) remember to turn the key on with the engine off and pump the gas pedal 3 times to reset the oil life indicator after the oil change is done, hope this helps!
Jun 29, 2009 | 2004 Chevrolet TrailBlazer
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
154 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
