Question about Epson Stylus CX5400 All-In-One InkJet Printer
I have installed drivers for my epson stylus cx5400 it does evey comand but no ink is coming on paper
    Scholar:
  • 108 Answers
This is brand new is it?? there might be a cap on the printer head to keep it from being damaged during shipment. or it has not been installed onto the printer correctley. if all of the above is not the problem...do a maintenance clean on the printer...wait..have you put in the ink cartridges?? there is also a plastic tapelike cover on the cartridges..you have to remove those before you install the cartridges. folowing the amanual word for word will help you better than anything.
i hope this helps..
Posted on Sep 10, 2009
I lost my installation software for my epson stylus cx5400 scanner/printer. is there a download site foir this software. i am a student and need to finish research papers and need the device tonight
Please find the driver from the below mentioned link
http://drivers.softpedia.com/get/PRINTER/OTHERS/Epson-Stylus-CX5400-Printer-Driver-54aA.shtml
A positve feedback is expected along with your 4 thumbs
pp
Nov 11, 2009 | Epson Stylus CX5400 All-In-One InkJet...
How do i install my new ink cartridges in my printer epsom
Be sure you have a new ink cartridge before you begin. Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
  1. Make sure the EPSON Stylus CX5400 is turned on and not printing. The LCD screen tells you which ink cartridge is low or empty.
  2. If your EPSON Stylus CX5400 is low on ink, press the left Menu button until you see Change Cartridge, then press the Color Copy button.
    If your EPSON Stylus CX5400 is out of ink, press the Color Copy button.
    The ink cartridges move to the replacement position.
  4. Lift up the scanner.
  6. Pinch the tabs on the front and back of the cartridge, lift it out of the printer, and dispose of it carefully.
  8. Before you remove the new cartridge from its package, shake it four or five times.
  10. Unwrap the new ink cartridge and lower it into its holder, then press down on the top of the cartridge until it clicks in place.
  11. Caution: Don't touch the green circuit board on the back of the cartridge; you may inhibit normal operation and printing.
    If you need to replace other ink cartridges, repeat steps 4 through 6 before continuing with step 7.
  12. Carefully lower the scanner and press it down until it clicks into place. The EPSON Stylus CX5400 begins charging the ink delivery system.
  13. The On light flashes and the EPSON Stylus CX5400 makes noise. Charging takes about 30 seconds. When it's finished, the On light stops flashing and stays on.
    Caution: Never turn off the EPSON Stylus CX5400 while the On light is flashing, unless the Stylus CX hasn't moved or made noise for more than 5 minutes.
Oct 27, 2009 | Epson Stylus CX5400 All-In-One InkJet...
No power but ink & error/paper button blinking red
maybe need to replace a new cartridge or chick you ink if not empty
and din check inside your printer possible have a paper jump inside,,
or try to remove completely the printer driver using the (ad and remover program) how to this go to the start menu din control panel you can see the ad and remove program,, and click uninstall your printer driver and din restart your pc to take effect and din install gain,,
thank you i hope i can help you.. have a good day!!!!!!!!!
Jul 06, 2009 | Epson Stylus CX5400 All-In-One InkJet...
My Epson Stylus CX5400 won't print.
hii,
u printhead block..that why cannot ink cant not get trough from the print head..or try clean the print head using printer properties under maintenain .for informations epson print head are sensetif..
Oct 25, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Epson CX5400 - use as scanner only?
imy cx5400 prints only part of the page.it also prints so light i can barley read it.When Iprint pictures there are lines all down the picture.
Aug 30, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Epson stylus cx5400 reset???
try doing this :
Reclamping the Ink Cartridges
Once you start the ink cartridge reclamp procedure, you must complete all the steps in one session.
2. Press a MENU button until you see CHANGE CARTRIDGE, then press the COLOR COPY BUTTON. The ink cartridges will move to the replacement position.
3. Lift up the unit's cover, to access the ink cartridges.
4. Pinch the tabs on the front and back of the cartridge, and lift it out of the printer.
5. Lower the cartridge back into its holder, then press down on the top of the cartridge until it clicks in place.
Caution: Don't touch the green circuit board on the back of the cartridge, as you may inhibit normal operation and printing.
6. Carefully lower the scanner and press it down until it clicks into place. The EPSON Stylus CX5400 begins charging the ink delivery system.
The On light flashes and the EPSON Stylus CX5400 makes noise. Charging takes about 30 seconds. When it's finished, the On light stops flashing and stays on steady.
Caution: Never turn off the EPSON Stylus CX5400 while the On light is flashing, unless the Stylus CX5400 hasn't moved or made noise for more than 5 minutes.
if the issue still persists - you need to call the vendor - it´s a hardware issue
Dec 30, 2007 | Epson Stylus CX5400 All-In-One InkJet...
Cx5400 printer will not access the magenta color
Sorry. You have a clogged printhead. A new printhead from Epson cost 114.00. Plus labor.
Aug 08, 2007 | Epson Stylus CX5400 All-In-One InkJet...
Epson Stylus CX5400 All-In-One InkJet Printer Logo
46 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
