Question about KitchenAid KESK901SSS Electric Kitchen Range
Kenmore oven blows hot air out at top
A lot of hot air is coming out what appears to be a vent. The oven seems to be having trouble staying at temperature, and the amount of air coming out seems to be more than should be necessary for a simple vent.
  • 11,896 Answers
The hot air is supposed to come out so you can heat other things. If the oven is loosing heat, try to see if vent has flap, or test the temp sensor
Posted on Sep 10, 2009
New Kenmore elite range blows cold air from oven vent when top burners are on. Is this normal
That sounds a bit unusual.... Does the fan come on when you turn on the oven on bake? How about on broil? How about on self-clean. If it comes on in all those settings, then it may be working as designed. If NOT, they there may be a crossed wire, or you may have a malfunctioning control.
Nov 11, 2014 | Kenmore Kitchen Ranges
When baking lots of hot air blowing from top vent
It is a good thing that the heat blows out. Electric oven didnt have anywhere to vent so the cpu boards got hot and burned up. So to correct this problem there is a little fan that blow out the heat so the cpu board doesnt over heat. thats all.. no worries mate
Mar 25, 2010 | KitchenAid Architect Series KEMC308KSS...
I have a Kenmore series 90 gas dryer that has been converted to propane, model 110.74912200. the burner will light and stay hot for about 3 minutes and then will cycle off and only blow cool air. I have...
I would suspect faulty gas valve solenoids. These electrical coils are right above the gas valves and when energized, these solenoids open the valves to permit gas flow. It's recommended that if any are suspected of being faulty that both (all) be replaced at the same time. They will most likely come as a set from the parts supplier. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 24, 2009 | Kenmore 73952 Gas Dryer
MY DRYER GETS HOT ON TOP OF THE DRYER (KENMORE) COULD IT BE THE VENT?
start dryer, go outside and see if vent is blowing hot air. If not then vent is clogged with lint, esp if vent has a curve or elbow in it. unhook vent at dryer or os vent and run a vacumn hose in as far as you can. easy way to determine if vent is to unhook at dryer and see if dryer blows air, could be just inside at vent opening
Jul 11, 2009 | Kenmore Dryers
Exhaust fan doesn't work and blows air from top vent
Some microwaves have a adjustable fan. We have one that you can vent out the back, the back top or through the front top filters. The latter is what it sounds like you have. If you take the small back panel off and lift out the fan motor you'll see that you can place it in the direction you like.\\
KK
Jul 04, 2009 | Kenmore 60654 Microwave Oven
Kenmore dryer model 41780042990
sounde like you have a clogged vent line be shure the vent hose is not cinked in any waty that would restrict the air flow. Next turn the dryer on and make sure you and a good flow of air out side the house if the air is not blowing out the vent out side you will need to clean this out or have it cleaned.
Jan 20, 2009 | Frigidaire FEQ332E Electric Dryer
Heat coming out
that is when your vent is...it is normal....does it cook right? if so, it is good
Jun 19, 2008 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
How does the vent work?
Under cabinet microwaves generally have two configurations for venting.
1) There is a vent cover plate on the top or rear (sometimes both) of the unit that can be removed and connected to a duct that vents up to the roof. If you do not have such a duct installed then that cover plate should be left on the unit so that it vents in configuration 2.
2) With the external venting ports sealed with the cover plate(s) the microwave simple draws air from the bottom (usually through 1 or 2 grease capture screens) and vents it out thought the front/top of the unit. This configuration isn't very useful as it just blows the air back into the kitchen. Many people don't both using the microwaves blower in this configuration.
Feb 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Hole underneath back left burner?
It is your oven vent. It needs to be left open. There could be a calibration issue with your cooking times. Check the accuracy of your thermostat with an oven thermometer.
Aug 23, 2007 | Kenmore 40192 / 40199 Electric Single Oven
KitchenAid KESK901SSS Electric Kitchen Range Logo
597 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
