Question about Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune top load. I am getting an od code
I own a Maytag Neptune top load. I am getting an ''od'' code on the control panel followed by three beeps. It will not operate. I've tried unplugging & plugging back in, but not having any luck. Any suggestions?
    President:
  • 1,776 Answers
Be sure to unplug the washer before attempting any troubleshooting. On the Maytag Neptune the "OP" code indicates a problem at the door switch. These washers have a common problem associated with this code. The door isn't completely waterproof and allows water to get into the area where the lid switch is, corroding the electrical contacts and wires. Use a putty knife or screwdriver to open the top of the machine to access the door locks. Look for any broken or corroded wiring connections and reseat and clean as necessary. Test the switch using a multimeter or ohmmeter. Check for continuity. A lack of continuity will indicate a faulty switch. Sure hope this helped and best wishes.
Posted on Sep 10, 2009
What does the code od mean?
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Read more: Maytag Neptune Washer Error Codes ' eHow.com http://www.ehow.com/list_7170826_maytag-neptune-washer-error-codes.html#ixzz2GZKry68n
Dec 30, 2012 | Maytag Neptune MAH5500B Front Load Washer
Washer will not start , od code is showing on the panel
You have lost signaling from the Left Hand Lid lock.
The OD code is sent out from the Console main control board when a lid open is not sensed via the signaling from the Left Hand Lid lock for three completed wash cycles.
Google this sticky for help with your issue ""Neptune TL Washer FAV6800AWW"" start at the 5th post down. You will find a link to the service manual and help on troubleshooting your issue.
Sep 03, 2011 | Maytag Neptune FAV6800AW Top Load Washer
OD signal goes on w/ neptune washer w/ lid closed. Technician said it needed control latch assembly ($105) and control board($221). Plus labor ($155). Are these easy to get and replace? Is all this...
OD error code is associated with the Left Hand Lid Lock.
If you want to troubleshoot and repair yourself Google this""
That is a repair sticky where I have DIY support for FAV6800A or FAV9800A Maytag TL's.
You do not need a lot of mechanical experience just some guidance if you wan to save your 1$K machine.
Aug 04, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I get OD code
od meaning from the Service Manual for the FAV6800A/FAV9800A;
Open the Lid: The lid has not been opened for the last three completed cycles.
The OD and OP error codes are trouble shot the same way. See if this link will help.
Left Hand Lid Lock Troubleshooting
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference
If you need additional help let me know.........D*ick
D*ick
Aug 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune top loader model fav6800aww has an error code od
See if this post http://www.fixya.com/support/t4757262-i_have_a_letter_showing_and_it_say_o_d_w will get you started.
You have lost signaling from the Left Hand Lid Lock. If you want to DIY I will try to help........Rich
May 15, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I posted a problem with a Neptune top load washer
The lid lock is bad part # is left side  25001048 runs around $80,the problem tends to stem from the dispensers water and bleach work their way into the switch and I have never had much luck cleaning them out and getting them to work.. and that is left hand side as you are facing the machine.
Sep 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My maytag neptune washing machine displays OD and does nothing
See if this post will help you clear the OD error code on your machine.
Sep 02, 2009 | Maytag Neptune FAV6800AW Top Load Washer
"od" = Door Open. Most likely a relay or wax motor in the door latch assy.
Jan 09, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
317 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
