Question about Belkin N1 Vision Wireless Router
My Belkin N1 (F5D8232 ver.1.0) reset's randomly
My Belkin N1 (F5D8232 ver.1.0) always reset's it's self from time to time. I try disabling the "UpNp" feature as requested by others Tech help web site's to no avail.
I ruled out every other possible feature that can contribute to the random resets, all but one; "Primary NTP Sever & Back up NTP Server" which I don't know if they are the right settings by default for my country (Puerto Rico)
Please help me!.. this is incredibly annoying...
(the router keeps working, but all the settings are reset to factory settings including set up)
  • omar_g_pr Sep 10, 2009
    Thanks for clarification on NTP servers!...
    The firmware version is : F5D8232-4_WW_1.00.15
    Boot version: 1.02
    Hardware: F5D8232-4 v1000
    I have tried flashing the firmware many times with firmware updates from Belkin which are: "1.3/1.8/1.11/1.15" successfully, but it keeps resetting itself no matter what firmware I try!.
    I also noted that wen it happens the router is very hot!.... Don't know why there is a Belkin N1 router with a hardware "2000" version , myb that's a common problem with hardware on Belkin N1 "1000" version.
    It make sense that there are hardware problems with version "1000" because the version "2000" is the same router.
  • Cliff Hunter May 11, 2010
    What version is the firmware your router is running? You can find this out by opening a web browser and typing in the ip address of your router in the address bar. IEhttp://192.168.1.1 Once you login to the router, the status page will display the firmware version. The primary and secondary NTP servers simply provide your router with the correct time and date so they should not be the cause of the problem.
  • 49 Answers
Try upgrading the firmware. if it doesn;t help, the router is brick.
Posted on Sep 10, 2009
Belkin n1 vision is shutting down
Is the Belkin plugged into a power strip or UPS? Try another AC outlet. Has the AC jack,plug in the rear or the Belkin been damaged due to pulling on the AC cord, causing a lose connection? Is your computer shut down at night? No Hibernate, No Sleep? Are their setting for the Belkin to shut down/timeout after a certain idle time? Here's a user manual: http://cache-www.belkin.com/support/dl/f5d8632-4_usermanual.pdf
Feb 14, 2013 | Belkin N1 Vision Router
How many pc's, laptop's & printer's can i link up to belkin n1 vision wireless router model f5d8232-4
You can uplink a fairly good number of PCs or laptops with Belkin N1 as it supports high bandwidth. Keep in mind that upon adding every new PC, the overall bandwidth for the other PCs is reduced. If the PCs/ laptops do not require much bandwidth, you can connect / add more PCs to the network.
Generally, I have uplinked upto 10-15 clients to one router and the network worked just fine. It all depends upon the network environment and the bandwidth usage by each client PC. If the PCs are using just email and simple internet browsing (and remain idle for most of the time), you can add more clients to your network as not all the systems consume network resources at the same time.
Hope it helps! Good Luck!
CreativeTECH
Apr 01, 2011 | Belkin N1 Vision Wireless Router
On Modern Warfare 2 I have a STRICT N.A.T type. How do I fix this on a BELKIN F5D8232-4?
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Oct 09, 2010 | Belkin N1 Vision Wireless-N Wireless...
I have lost the quick installation guide for this unit can you send me another please ?
http://www.belkin.com/support/article/?lid=en&pid=F5D8232-4&aid=10177&scid=0
May 02, 2010 | Belkin N1 Vision Wireless-N Wireless...
Belkin N1 wireless network not working
It might be an idea to upgrade the firmware which can be downloaded from manufacturers' website
Mar 20, 2009 | Belkin N1 Vision Wireless Router
Belkin n1 F5D8631-4 NAT goes back to strict after been open
Step 1 : Check the IP Addressof the Xbox And take a note of it
Step 2 : Open RSP By typing 192.168.2.1 on the Address bar of the internet explorer
Step 3 : On the left side Click Firewall
Step 4 : Leave the Password blank and click Submit
Step 5 : Disable it And Apply Changes
Step 6 : On the left side Under Firewall Click DMZ
Step 7 : Add the IP Address of the XboX in DMZ
Step 8 : Click Apply Changes
Step 9 : Restart the Router
Step 10 : Test the Connection
Mar 15, 2009 | Belkin F5D8631-4 Router (F5D8631au4A)
How do put the wireless mode on 802.11g mode instead of 802.11n draft mode, on my Belkin N1 Vision wireless router,F5D8232-4
Open your web browser and type the router IP address of the router (by default, the address is http://192.168.2.1.) in the address bar and press Enter, there should be an option there.
Nov 25, 2008 | Belkin Computers & Internet
Installation cd
Dear Stuartmcrae,
Download the software for your N1 Vision Router ,from this URL:
http://www.belkin.com/support/product/?lid=en&pid=F5D8232-4&scid=854
Cheers
Feb 29, 2008 | Belkin N1 Vision Router
Belkin N1 Vision (Part # F5D8232-4) and VPN problem
I hade the same problem with mv Cisco VPN v5.0 and Belkin N1 router (F5D8231-4 v4...). I could only solve the problem with a new firmware (f5d8231-4 ww v4.00.18 at http://www.belkin.com/uk/support/article/?lid=enu&pid=F5D8231uk4&aid=9419&scid=0 ). I think this is a general firmware issue at Belkin. Good luck.
Feb 27, 2008 | Belkin N1 Vision Router
Belkin N1 Vision Wireless Router  Logo
1,258 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
