Question about Photography
I have a professional tripod and the attachment that hooks onto the legs has been stripped so will not screw onto the leg base. Is there anyway that it can be repaired?
  • gjtarnasky Sep 10, 2009
    Yes, now I just need someone around here that can do it. Thanks for your help,
    Gloria
    President:
  • 1,714 Answers
The way I understand it, the leg base is threaded and the attachment screws on, right. Well then if the attachment is stripped, you have to use a 'Tap and Die' set to re thread it. First you need to know the size tap for that specific thread. Then screw the tap into the attachment thread and re cut the existing threads. Then the threads will match up and it will screw on again. ( use a nut that is the same size as the attachment to find the thread size , for example , a 1/2" nut if it fit, would use a 1/2" inch tap to re thread it)
Posted on Sep 10, 2009
Where are the batteries located in a Stanley Tripod flashlight
You'll need to remove the base of each leg by unscrewing the black cap at the bottom. Insert the batteries into the tripod leg. Each leg holds one to three AA batteries depending on the flashlight size.
Aug 24, 2012 | GE Photography
What is the purpose of the screw at the base of the 95155 stanley 3 in 1 tripod flashlight
The pin has 2 magnets on it. When you hit the open button it pushes the pin down and releases the legs.
Aug 23, 2012 | Stanley 3in1 Tripod LED Flashlight 95155
I need a one bolt and screw for my Vivitar model #1100 tripod. How do I get it ? It attaches any one leg to the body of the tripod.
That means the other two legs are connected with the very hardware you're looking for. Why not remove them and take a trip to the hardware store for a match?
Aug 20, 2011 | Vivitar Cameras
Hi, I have just bought the 190CXPRO3 carbon fibre
Little confused here. Is the head the part you want to detach from an older set of legs? Do you want to remove center post from new legs or old legs. The base plate remains on the center post/ Aftre removing 3 set screws, and you want to remove the head from the baseplate and it will not turn, grap slip joint pliers or a pipe wrench, wrap the jaws with cloth ( to prevent marring of head or legs) and while holding head with wrench, have someone else turn legs
Apr 26, 2011 | Manfrotto (190XB,128RC) Tripod
I can't get the ball head off my tripod. I've loosened the set screws at the base, but the head won't budge.
You can try this:
spray lubricant between ball head and base, wrap the ball head with a heavy rag( to help prevent scratches, use a pip wrench on ball head while someone else holds legs ( or also wrap legs in cloth and hold in vise). DO THIS AT OWN RISK
Dec 04, 2010 | Manfrotto (Distributed by Bogen) 055XB...
I have a Manfrotto 058 tripod. One leg wont hold weight & retracts under load. This model uses a quick release lever at the top of the leg to control the telescopic height of each leg. How can I repair...
If you notice, the legs locks are attached to bothe the upper part of the leg and the sloghtly smaller diameter lower. Take a socket (8mm I believe) and tighten the lower 2 nuts to the bottom of the leg lock.
Feb 12, 2010 | Bogen Communication Bogen Manfrotto 3030G...
Want specifications for titan ii ii-950
Call Ritz Camera at 877-999-RITZ (7489). They "might" be able to assist you. Ritz's generic lenses are Quantaray made by Sigma. I don't know who makes the tripod. They are able to provide documentation for you, but I don't know if they will. Ritz has an online help form that you can fill out on their web site also
The little 'hooks' on the bottom of the legs 'snap' into each other to secure the legs together. Each leg has a 'hook snap' which clicks into place with the other legs. It is merely a way to secure the legs from flopping open. I bought the same tripod, a good solid piece of equipment. No instructions but its easy enough to figure out. Hope this helps.
Feb 26, 2009 | Quantaray QSX-DigiPro 8500 Tripod
With what can I lubricate the legs onmy aluminum Mafrotto tripod?
Dear Winnieg,
I would avoid using a lubricant on your tripod legs, because you run the risk of the legs not tightening down anymore. I would try cleaning the tripod thoroughly first, because most of the time this is caused by dirt. If that dosen't work I would try rubbing on a small amount of candle wax onto the legs, and then wipe the legs down with a clothe.
Sincerely,
Allan
Go Ahead. Use Us.
Mar 14, 2008 | Photography
Dead Legs on Tripod
I have no ideas, but if you buy another tripod, I owuld like to buy your old handles from your 8500.
Thanx
Rick
817.846.8464
Oct 02, 2006 | Quantaray QSX-DigiPro 8500 Tripod
VGB3 leg lock broke
On the velbon vgb 3, the leg locks consist of a lever, one or two pieces of metal and a plastic piece. The metal and plastic pieces rest in a depression against the lever. When the lever is pulled out, pressure against the smaller leg section is released. When the lever is pushed in, pressure against the smaller leg section is exerted, locking the legs in place. On the back side of each joint, there is a phillips head screw which acts as a stop to keep the leg section from coming all the way out. When the screw is backed out, the leg section can be removed, exposing the latching mechanism. If the only problem is that the latch mechanism came apart, it can simply be reassembled. If, however, something broke and allowed the latch assemby to come apart, that will have to be dealt with as well. My guess is that the phillips screw may have become loose, and the latch came apart.
Aug 14, 2006 | Velbon Chaser EFL-4 (A) Tripod
Photography Logo
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
