Air conditioner I have a panasonic air conditioner split system about 10 years old. It has stopped working yesterday.  The fan is not moving.  It seems to be smoking freeze air from the indoor unit.   No cold air coming out.   What should I do.  What can I do.
  • Anonymous Mar 12, 2014
    Indoor unit turns on but outside unit does not
  • Anonymous Mar 28, 2014
    try and start indoor unit with remote and just comes up with e6 code, was working perfectly.
Faulty main control board or wiring loop may be a problem?
Posted on Dec 31, 2007
  • 236 Answers
Turn off unit supply and check the blower wheel inside the indoor unit by rotating it manually by your finger if the blower wheel rotates freely then there is something wrong with your fan motor or fan motor capacitor. But if the blower wheel is not rotating freely try to check the fan motor for lubrication or some bushing dried of and no oil
One year old Panasonic Split system only blowing air
The compressor may possibly still be working but has no more freon. Ths may be caused by a leak.
Nov 16, 2013 | Panasonic Single Split Wall Mounted Air...
I have a Panasonic 1200 BTU air conditioner, that ...
The ball bearings in the fan motor is toast. Options: 1. Contact your dealer or Panasonic directly. This is a known problem and Panasonic will send you a new fan motor for free or at a reduced price, depending on the age of your unit. You will probably have to change it yourself, or call a tech to do it for you (about 1 hour of work).
2. Change the ball bearing(s) in the fan motor yourself. 1-2 hours of work if you are somewhat handy. Buy a CERAMIC bearing (Size 608, ZZ, Ceramic - the same size you use for a skateboard) @about 10 USD (7 EUR) in your local hardware store. You probably only have to change one bearing, the one on the "inside".
May 20, 2010 | Panasonic Room Air Conditioner CWXC104HU
Air Conditioner just stopped working
verify that the fan is free to spin and not binded, window units are bad for this due to close tolerances in the small cases
Aug 10, 2009 | LG Electronic Window Air Conditioner
LG split system cooler/ heater heater not working
This could be a problem with the interconnecting wiring or a control board problem with either the indoor or outdoor unit. I would have these issues looked out.
Hope this helps
Mat
May 28, 2009 | LG LSC091PMA Split System Air Conditioner
Have a near new panasonic cs-e28hkr split system air conditioner and the outside condensor fan continously runs even with inside unit is turned off? Thanks
Sir/madam,
If the inside unit (evaporator) is turned off absolutely.
The condensing unit must be turn off outside because the power
are derived comes from the evaporator.
Possible it seems on the cut out stage inside and remain the power still on
Otherwise theres somebody tamper the connection?
Fan cable consist of 3 wires
1 Common line
2 Start /stop line***Change the connection of this wire where it located, To On/ Off switch of the
evaporator inside unit
3 Ground green line/Earth
note: you can get all that wires inside the power supply in evaporator area.
If still under warranty inform the manufacturer
r_ic7
Nov 29, 2008 | Panasonic Heating & Cooling
Panasonic Split System Air Conditioning.
we have a old national air con cassette model cu-5chv11p , works for three days , then controller comes on e4 error ,and then switches off , and will not reset .
Dec 28, 2007 | Heating & Cooling
"high" vs "low" dual control
could be problem with either switch of fan. try continuity across both legs of the switch then try continuity across the fan windings.
May 25, 2007 | Fedders X Chassis A3X05F2B Air Conditioner
Heating & Cooling Logo
325 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
