Question about Playmates My Life Handheld
Screen just went dark
Will not reset or turn on. just brought it home my daughter was setting it up, had it goin for 10 minutes, screen went dark and now will not work
    Problem Solver:
  • 17 Answers
Warranty failure. Take it back to the store with the receipt for a refund or NEW replacement.
Posted on Sep 10, 2009
I have a new tablet, charged and protected but when I was changing contrast settings it went black and I cant get the screen to come back on past startup
Sorry about this.
Well, seeing it is a new tablet, either of two things can be done.
Your tab is booting beyond Startup but you ain't seeing it because of the contrast/black screen setting.
To confirm; step into a dark room/space and hold a flashlight very close to the screen, you'd see your tab is at its home screen already.
Anyway, you will have to default factory reset it as it is or you could attempt to navigate (while in the dark room/space and using/holding the flashlight) Swipe to open/unlock it----Settings----display and brighteness-----brightness----'move cursor up to increase brightness'. Done.
Second option with dark room/space is tedious and strenuous.
Factory/hard reset is an easy option to try.
At the same time, hold/press both the volume up key/button and the power button/key.
Follow the system prompt afterwards.
Or
Press/hold down the volume down button/key and the power button.
Follow the system prompt thereafter to factory/hard reset your tab.
Best of luck.
Oct 10, 2017 | Umi PIPO S1 Android 4.1 Dual Core 7 Inch...
My HTC Hero brought up a notification that said it was running low on storage space. When I tried to get out of the notification page, the phone said it had to force a close. It kept bringing up the...
Resetting the phone deletes all data, including downloaded applications, and resets the phone back to its initial state. Press HOME > MENU, then tap Settings > Security > Factory data reset. On the Factory data reset screen, tap Reset phone and then tap Erase everything. To reset the phone using phone buttons, with the phone turned off, press and hold the HOME, END CALL/POWER, and BACK buttons. The reset process will start after a few seconds
Feb 26, 2011 | HTC Hero Smartphone
Intermitently, my screen goes dark, but the
1.)It could be your video card
2.) Yes it is expensive for a laptop
3.)I would first check your screen setting for turning off display...
If you are using vista:
-Right click on your desktop then choose personalize
-Then click screensaver
-On bottom click on "change power settings..."
- On the left click on "choose when to turn off the display"
Your monitor can turn off without your computer being in sleep mode.
Dec 26, 2009 | Toshiba Satellite A105-S4334 Notebook
Dark screen even after setting is at its brightest. Just happened mid game.
did you try restarting it?
hold down the home button and the button at the top until it restarts
May 15, 2009 | Apple iPod touch
Turns on But No Picture and No Sound
sounds like it could be a cabling issue, try replacing the cabling (if you have another tv, you can borrow the cabling before purchasing new set of cabling)
Apr 04, 2009 | LG 50PC5D Television
Palm Zire 71 works when it is on the sync but not off
You are right
there is a component on the main board of your PDA
that is most likely fried
power from the PC chord will go to the PDA
but when you unplug it the machine will look to the battery for power
and the electricity will convert to heat at the point of that fried component
on the more thin Palm models you can feel it without taking the case off
and it will "forget" any new information you input due to the type of memory it uses
Feb 20, 2009 | Palm Zire 71 Handheld
Iphone reset instructions don't work
u can try jailbreaking on ZIPHONE download will work as new
Mar 09, 2008 | Apple iPhone Smartphone
Change router locaation
do factory reset of configuration settings then log in with the routers default credentials. then change settings to your liking with one exception: DO NOT USE WEP!!!!! At a minimum use WPA 1 personal (with MAC filtering if you know how.) WEP can be hacked in less than 5 minutes.
Dec 13, 2007 | NetGear WGR614 Wireless Router
In AUTO mode, pictures are all dark!
Yes you definitely can,
Turn on the camera.
The mode dial can be turned to any setting.
2. Press the button for longer than 5
seconds.
The message “Reset settings to default?” appears on the
LCD monitor.
3. Select [OK] using the left and right
buttons, then press the button.
The normal screen resumes when resetting is complete.
To cancel resetting, select [Cancel] instead of [OK].
Dec 09, 2007 | Canon PowerShot A70 Digital Camera
Rca home theatre big screen tv
# 1 above you have covergence problems ,there is a service flash from rca to fix your fault,ask your tv shop. fault # 2 above turn off the color and adjust your screen settings for a grey picture,set brightness and contrast to middle settings. # 3 fault read #1 cause if your auto focus will not correct you require service there is a harness connector that looses connection and causes several fualts on the 52" rca's you can repair the fault but if you miss the harness replacement you will do it again.
Dec 01, 2007 | RCA 32F531T 32" TV
Playmates My Life Handheld Logo
109 people viewed this question
Top Playmates Toys Experts
Matt Smolinski
Matt Smolinski
Level 1 Expert
Max Scott
Max Scott
Level 1 Expert
DarrenCollins
DarrenCollins
Level 1 Expert
Are you a Playmates Toy Expert? Answer questions, earn points and help others
