Question about Toro Lawn Mower With Toro Power Tools
Battery draw down
Hello, I have a Toro ZTR that sucks down the battery between mowings. The battery becomes weak and makes it hard to start. So I charged up the battery, turn the key, there is a slight hesitation, but it pops off and starts. Same thing when it's warm. I am suspecting a short or maybe a bad starter solenoid? What do I check first and how? Thanks
  • wi_nikekid Sep 10, 2009
    The battery is brand new, so I know that is not the problem. I had the old battery checked when I traded it in, and the guy at Batteries Plus said it was still a good battery. I upgraded simply because of age of the battery. I think the solenoid is bad, but I'm not sure how to test it?
  • 33 Answers
Disconnect the battery. Charge the battery. Then let it sit idle for whatever period of time that it has been taking for it to go dead. Reconnect the battery & try to start it. If it is dead then the battery is bad, If it cranks OK then you have something drawing the current from the battery.
Posted on Sep 10, 2009
Toro ztr no drive power on 1 side Makes whine when engaging
Many mowers of this type have two transmissions. One may be bad, or is low on fluid.
Jun 30, 2016 | Toro Garden
My parents have a self propelled...front drive...walk behind 22in cut mower purchased at Home Depot 3 seasons ago.....I do the maintance on the mower....sharpen blade....change the oic/plug &...
Does the mower die right away (cuts out) or does it sputter to a halt. Sputtering out would indicate a fuel problem. If it just cuts out when hot, then more likely an ignition problem. Your coil may need replacing. Take a close look at the coil wire (spark plug wire) and its routing. Make sure it's not touching part of the engine where it's heating up and has caused a "leak" to ground it out when it gets hot. If all is well then check your spark when the engine is hot and cuts out. Make sure you have a very good blue spark and not a weak one (check it cold first and then compare!). Again, indicating a possible ignition coil problem. Hope this helps and best of luck to you.
James
Sep 14, 2011 | Toro Power Lawn Mower
How to adjust the mowing deck
Click on this link from Toro. Then click on Operator Manual (English). Wait for the PDF file to load and then go to page 21. That page has detailed instructions and drawings for what you need to do.
https://homeownersolutions.toro.com/portal/server.pt/community/product_center/225#manualsResultPage
Aug 14, 2011 | Toro LX466 22HP Lawn Tractor 13RT61RH244
I have a 05 Toro 44in ZTR with a 19HP Kawasaki engine with under 300 hours the main 30amp fuse keeps blowing when I turn on the ignition switch on. I noticed when I disconect the PTO switch the fuse dousnt...
sounds like your electric clutch is prob bad check to make sure wires are not bare touching something, the clutches do go bad eventually like any other electrical part, disc the pigtail and try fuse, if it blows then I would consider a clutch
Jul 27, 2011 | Toro Zero Turn Rider 74833 Lawn Mower...
Less than a year old, just clicks, battery fully charged
Check your starter solinoid, it probably needs replacment.
When they are defective they will make the noise you described
Free Answer...Please Rate Me
Apr 16, 2011 | Toro Zero Turn Rider 74366 Lawn Mower...
Toro lawn tractor
There is a switch on the seat and one on the brake pedal
May 31, 2009 | Toro Lawn Mower With Toro Power Tools
Dual blade mower leaves uncut strips between blades.
Had same uneven mowing problem with new Toro Z4200 XTR mower. Problem was one side of the U-shaped rear deck hanger rod had popped out of its chassis mount (did hit something with mowing deck). Removed hanger chassis mount & its bolt. Put end of U-shaped rear deck hanger rod back in the chassis mount and remounted hanger chassis mount & its bolt. Z4200 now cuts lawn evenly again.
Jan 05, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
152 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
