Question about RTO Star Products Deluxe Vacuum and Fuel Pump Tester # TU1P
2002 chevy malibu fuel pump
Fuel pump is not getting power but i've checked all fuses and relays; what else can i do?
  • 115 Answers
Are you getting spark? if not it may be your cam lobe sensor, this tells the engine when to fire and pump fuel
Posted on Sep 10, 2009
3.5l V6 Auto. Why is there no power at the fuel pump?
Just answered a similar question. Does it turn over? Either way, I would look for blown fuse and then check (usually) under the hood for a relay. You can some times test by taking another relay for lights or something not needed to run and switch them IF THEY ARE EXACTLY the same. If the pu,p works you will know.
Oct 20, 2015 | Cars & Trucks
2004 Chevrolet Malibu mix v6 LS engine turns but will not start
Check for fuel, spark, and then compression. Fuel problems can be pump, pump relay, fuse, filter, line, etc. Spark problems can be distributor module, distributor, coil packs, power to distributor or coil packs, plug wires. Compression problems would be piston rings, piston walls, piston rods.
Sep 19, 2013 | 2004 Chevrolet Chevrolet Malibu MAXX LS
Which fuse controls the power windows?
There are few related help links for vehicle fuse box.Go through the list and click the required link:-----
2009 Toyota Corolla: Fuse Box Module Removal? http://howtobyme.blogspot.in/2012/05/2009-toyota-corolla-fuse-box-module.html
1986 Chevrolet Corvette Fuse Box Diagram
http://schematicsdiagram.blogspot.com/2012/11/1986-chevrolet-corvette-fuse-box-diagram.html
1996 Chevy Cavalier Cluster Fuse Box Diagram?
http://schematicsdiagram.blogspot.in/2012/04/1996-chevy-cavalier-cluster-fuse-box.html
2004 Jeep Cherokee Fuse Box? http://whatisbyme.blogspot.in/2012/05/2004-jeep-grand-cherokee-fuse-box.html
2007 Saturn Outlook Fuse Box http://schematicsdiagram.blogspot.com/2012/11/2007-saturn-outlook-fuse-box.html
Lincoln Signature Series Engine Compartment Fuse Box
http://schematicsdiagram.blogspot.com/2012/11/lincoln-signature-series-engine.html
2005 Chevy Impala: Fog light Relay and fuse box diagram?
http://whoisbyme.blogspot.in/2012/06/2005-chevy-impala-fog-light-relay-and.html
Freightliner fl112 fuse box diagram?
http://technoanswers.blogspot.com/2012/01/freightliner-fl112-fuse-box-diagram.html
Where is Fuse box located on 2002 Honda Accord?
http://howtobyme.blogspot.com/2011/12/where-is-fuse-box-located-on-2002-honda.html
Toyota Hilux Surf Fuse Box Diagram? http://technoanswers.blogspot.in/2012/06/toyota-hilux-surf-fuse-box-diagram.html
2006 PT cruiser Fuse Box
http://schematicsdiagram.blogspot.com/2012/11/2006-pt-cruiser-fuse-box.html
Ford inside fuse box diagram showing fuel pump relay?
http://technoanswers.blogspot.in/2012/02/ford-inside-fuse-box-diagram-showing.html
Ford fuel pump fuse layout diagram?
http://technoanswers.blogspot.in/2012/02/ford-fuel-pump-fuse-layout-diagram.html
Saturn Fuse Box Diagram
http://schematicsdiagram.blogspot.com/2012/11/saturn-fuse-box-diagram.html
"Mercedes Benz" Ml 500 "Fuse Box Diagram" http://schematicsdiagram.blogspot.com/2012/11/mercedes-benz-ml-500-fuse-box-diagram.html
2003 Cadillac Deville DTS Underhood Fuse Box Diagram
http://schematicsdiagram.blogspot.com/2012/11/2003-cadillac-deville-dts-underhood.html
Kia Fuse box?
http://technoanswers.blogspot.in/2012/02/kia-fuse-box.html
Which Fuse controls A/C system on 2003 Ford Taurus?
http://howtobyme.blogspot.com/2011/12/which-fuse-controls-ac-system-on-2003.html
1997 Chevy Malibu Cigarette Lighter Fuse?
http://schematicsdiagram.blogspot.com/2011/12/1997-chevy-malibu-cigarette-lighter.html
Where is Instrument cluster Light Fuse located on 1996 Honda Accord?
http://schematicsdiagram.blogspot.com/2011/12/where-is-instrument-cluster-light-fuse.html
These details will help.
Thanks.
Nov 25, 2012 | Cars & Trucks
1998 land cruiser - which fuse controls the power windows?
Kia Fuse box?
Thanks.
Nov 25, 2012 | 1998 Toyota Land Cruiser
Does a 2000 chevy malibu have a fuel reset button and where? it just died while at a stop sign, so we thought it was out of gas. we put gas in and it still will not start.
Hello mellissa, the 2000 malibu does not have a fuel reset switch. Check the fuel pump relay in the fuse box under the hood. Check for fuel pressure. You should be able to hear the fuel pump come on for a few seconds when you turn the key to the run position....Your fuel pump might have failed.
I hope this helps.
Sep 18, 2011 | 2000 Chevrolet Malibu
No power to fuel injectors on my 2002 chevy mailbu ls? replaced cam sensor, checked all fuses, new fuel pump.Had good fuel pressure and will run on starting fluid?
There is a fuse for ther injectors. There should be a constant power to the injectors. the computer is what grounds them out. So it's not the computer. Also check the asd relay. Auto shut down.
Jan 22, 2011 | 2002 Chevrolet Malibu
Does 2001 chevy malibu have a fuel pump fuse
I am not sure if it has a fuse but your owners manual will say. I know it has a relay. If your not getting any fuel a good bet is to check your fuel filter and check to see if the fuel pump turns on for a second when you first turn the key on. Your pump may be bad. I have a 2001 malibu and have had 3 pumps in it since new.
May 03, 2010 | 2001 Chevrolet Malibu
2002 chevy malibu. Ran yesterday. Won't start
Cheak your fuse under the drivers side under the hood. Look in your manuel for fuel fuse. It looks like a little black box.
Jun 14, 2009 | 2002 Chevrolet Malibu
2005 chevy malibu won't start
You will need to Check the Fuel Pump and Relays, and also Change the Fuel Filter. There is a Fuse Relay Box under the Hood that has the Fuel Pump Relay in it.
Jan 25, 2009 | 2005 Chevrolet Malibu
RTO Star Products  Deluxe Vacuum and Fuel Pump Tester # TU1P Logo
391 people viewed this question
Top RTO Measuring Tools & Sensors Experts
jdthefixer
Steve
Tim Venetis
Are you a RTO Measuring Tool and Sensor Expert? Answer questions, earn points and help others
