Question about Lexmark Z735 InkJet Printer
The plastic piece on the left side of the paper holder ( feed) On my Lexmark Z735,fell out & I can not get it back in! Help! ( Its all intact!)
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Force it into the chanel groove it will click in
Vitally
Posted on Sep 10, 2009
While removing a paper jam a white plastic piece fell into the paper feed area. It appears intact, but I cannot work out how or exactly where to re-attach it. The printer cannot feed the paper correctly...
This white plastic pease is from Paper Out Chut, There are two latch to fix it, If you can , Other wise you have to open the cabinet and than only 'you can fix it.
May 02, 2010 | Brother DCP 165C Compact Color Inkjet...
My granddaughter put a toy in printer & a part broke off - thin, translucent piece about 1/4 inch wide by 7 inches long. How do I open up the printer in order to try to put this part back?
The plastic piece you are talking about it just prevents the paper from bending forward when is inserted in the printer. That plastic piece should not cause any paper jams or printing problems. If you do happen to have paper jams maybe a piece of plastic fell inside where the paper goes. Simply turn off the printer, remove the paper and flip the printer upside down and shake it a little that should remove any debris inside the printer.
Jan 31, 2010 | Lexmark X5470 All-In-One InkJet Printer
Long thin plastic piece fell out of Lexmark Z33
Google your printer, try pcappliancerepair.com. This item goes from one side of your printer to the other, passing through the cartridges holder. Look for the places it attaches. You may have to move the cartridge holder to the center to install the plastic.
May 01, 2009 | Lexmark JetPrinter Color Z33 InkJet
Lexmark x5435 paper feeder broken
Feeder goes halfway down & stops on Lexmark #5270 & would like free answer
Mar 16, 2009 | Lexmark X5470 All-In-One InkJet Printer
I have a canon pixma mp180. some little plastic pieces fell into the paper feed. I pulled what i could see out but now the paper jams when being fed. I did the maintenance roller cleaning. I was wondering...
I kept running the maintenance roller cleaning with paper in the feed and eventually I was able to see the tip of the plastic piece that had fallen in as I pulled the paper through with my fingers, I was able to get the whole piece and now the printer is golden.
Jan 28, 2009 | Office Equipment & Supplies
Problem with paper feed
check the paper pickup path. there is something or a paper stuck in the path.
you need to physically look and figure out the paper path. from pickup to feed out.
Oct 15, 2008 | Lexmark X5470 All-In-One InkJet Printer
Crazy Z33
Remove screws from back of printer. Carefully remove plastic top cover. If necessary write down the steps you have taken so that you won't have difficulties reassembling printer. Once cover removed check small feed roller at back of printer to see if there is any obstruction and also front main rollers.
Place some paper in raer holder to see if it is seating correctly.
If this fails I have further solution .
Aug 14, 2008 | Lexmark Z33 InkJet Printer
HP Laserjet 3380
If it is from the adf which is on the top then there is a small piece of paper stuck in the back. open the lid and you will find a plastic holder in the back. This helps the paper turn through the adf. Usally the paper is in there or this is out of positions which will cause this.
May 12, 2008 | HP LaserJet 3380 All-In-One Printer
Paper not feeding through on right hand side
I had the exact same problem.  I disconnected the printer and then when I flipped it upside down, I heard something drop out of it.  Low and behold was my missing letter opener.   I then tested the printer to see if it works, and sure enough it feeds properly.  Try cheecking to see if any objects may have accidentally fallen into it.
Sep 29, 2007 | Lexmark Z735 InkJet Printer
Lexmark Z735 InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
