Question about Samsung CLP 300 Laser Printer
My Samsung CLP-300 won't pick up paper (it goes 1 inch & stops)
How do you fix this? I took out the componentand the paper tray and turned it so I can see the bottom, should I put oil on the white plastic wheel that's partially covered with a wrinkly rubber-like thing? or is it something else?
  • 87 Answers
No oil on rubber rollers! You must gently clean the rubber roller with isopropyl alcohol and a soft cloth. Let it dry and it should work again. Make sure to get ALL of the oil off of the paper paths surfaces.
Posted on Sep 10, 2009
Samsung CLP-300 printer not printing, the paper tray will not pick up the paper.
Often the rubber pickup roller is either worn or dirty. It is located just above the paper tray. Use a damp cloth and try to cleaning it, sometimes that helps. Otherwise you will need to replace the roller.
Jun 16, 2011 | Samsung CLP 300 Laser Printer
Samsung CLP-300 paper does not seem to be catching when printing?
Hi. Kelly,
I think the issue is the due to paper pick-up roller. When the rollers get dirty or worn-out, the printer fails to pick the paper, which results in paper jam etc.. So, remove the paper tray and toner cartridge and locate the paper pick up roller in the middle. Clean it with damp (with luke-warm water) and lint-free cloth. I hope this would fix the issue. If the Roller is damaged or worn out, it needs to be replaced.
Hope this helps! Good Luck!
CreativeTECH
Feb 15, 2011 | Samsung CLP 300 Laser Printer
Samsung clp-300. Begins to print for split-second then stops. Takes up about an inch of paper before stopping. All toner is filled and fresh.
This is a common problem with both this and the Xerox phaser 6110 (a rebadged Samsung)
It is due to the pickup roller "tyre" that is the rubber roller that pulls the paper from the tray.
It gets shiny and slips on the paper.
The cure is to "rough up" the roller with some sand paper or emery cloth.
The best way is to remove the imager unit and store it in a cupboard or a box IN THE DARK.
This stops toner getting everywhere.
Remove the paper tray turn the printer on its side you will see the roller underneath, using some sand paper or similar carefully rough up the rubber roller all round.
now put the machine back together and try printing it should be ok, if the problem persists try repeating the process.
Jan 04, 2011 | Samsung CLP 300 Laser Printer
Samsung clp 300 paper jams after feeding about 5cm. Tried more paper, less paper, printing black only, printing colour, no change. Help
Clean up the Pick Up Rubber.
When you are able to get the Pick Up Rubber out of the maschine rotate it 180 degrees an reinstall it. then the problem would be fixed.
Oct 14, 2009 | Samsung CLP 300 Laser Printer
Samsung CLP-300 picking up too many pages
Hi
Thanks for using FixYa. Paper jam is a very common problem with the printers.
First of all clean off the rubber piece that pulls the paper into the printer from the tray with rubbing alcohol, and also take a knife to the rubber piece to rough it up to create more traction.
To clear the paper jam problem you need to remove the back roller mechanism to get at paper. If still the problem persists, then check the following to resolve the issue--
1. Please check all interlocks, electrical and signal connections are seated properly.
2. Front cover, back cover and lid are closed properly.
3. Power plug and USB cable are connected.
4. Printer is turned on with switch on the back.
5. Toner signal lights sequenced, with yellow overall led on.
6. There is some noise of paper roller movement.
7. Toner signal lights all out, overall status light turned to red
8. No visible paper in paper tray or anywhere else.
9. No paper in tray---added paper
10. Waste toner container is full or not installed ---empty, installed properly.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Samsung CLP 300 Laser Printer
The printer will not pick up the paper!
Suggest you clean the pick-up rubber that lifts the paper.
And also lift up the front of your CLP-300 by about 3 inches. I put a box under the front. The paper will fed slightly downhill into the printer.
It works for me.
Richard
May 04, 2009 | Samsung CLP 300 Laser Printer
Refusing to take paper
Someone suggested to empty the gray toner waste container located on the left side of the printer next to the cartridges. Be careful when emptying this as toner can make a real mess. Clean up with toilet paper or paper towel - not water!
Easy fix and this fixed mine like a charm. No need to send the unit in!
Feb 17, 2009 | Samsung CLP 300 Laser Printer
Samsung CLP-300 paper feed
Clean the feed roller.
Remove the paper tray, from the bottom there is a grey rubber semi wheel in the middle front of where the paper tray would be. Use a cloth with WD-40, brake cleaner, or lighter fluid to lightly wipe the rubber clean. Put the paper tray back in and it should print.
Jan 24, 2009 | Samsung CLP 300 Laser Printer
Samsung CLP 300 Laser Printer Logo
690 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
