Question about LG LSC26905TT Side by Side Refrigerator
Only the comp won't start everything else is ok
Replaced ptc / compressor still does not start. coil cooling fan does work
  • 308 Answers
Have you checked to ensure you actually have power @ the compressor? If so, is your start capacitor good? Is the overload on the compressor open or closed? If it is open, why? Hope this helps
Posted on Sep 11, 2009
Msd3756aew fridge won't stay warm, freezer cold but not keeping frozen. Cioils not frozen, fan working
the ptc overload/relay on the compressor is bad and not starting the compressor,remove back cover unplug the ptc off the compressor and replace it with a new exact replacement part
Feb 01, 2013 | Refrigerators
Jenn Aire side by side, both sides warm, PTC replaced.
If you hear it trying to come on, (the lights may even dim more than normal) followed by a "tink" noise, it's the compressor.
Jan 11, 2008 | Refrigerators
Refrigerator not cooling
replace the ptc overload/relay on the side of the compressor this aids in starting and running of the compressor
Jan 12, 2013 | Maytag MFI2568AES Stainless Steel Bottom...
LG Fridge LSC26945TT compressor getting to hot and not cooling
if it's not cooling unplug it so you don't damage the compressor,hopefully you just have a bad overload and relay,it's plugged into the side of the compressor,with the machine unplugged remove the bottom back panel,look at the compressor,remove the cover on the side of compressor and remove the start device or ptc assy. call your local parts store and give them the model number and buy a new start device for your machine.if you can hear a clicking sound every once and a while and the compressor is hot change this out first,if it still doesn't start then you have a bad compressor and will be in the market for a new fridge if the compressor is running take everything out of the freezer,remove the back inside wall of the freezer and check the evap coil,if the coil is all iced up you have a defrost problem,if the evap coil doesn't have an even frost pattern covering the whole coil you have a freon leak.if you have a freon leak you'll have to replace the fridge..hope this helps
Jul 04, 2012 | LG Refrigerators
Fan blowing warm air food not freezeing
the ptc overload/relay on the compressors dead so the compressor cannot start,therefore the unit cannot cool,replace the ptc and it will run again
Aug 03, 2011 | Freezers
Freezer quit freezing ice cream Thur night, but everything else was fine, not everything is starting a slow thaw
either the ptc overload relay on the compressor is bad and the compressors not operating to cool the unit or the evaporator coil behind the freezers inside wall is iced up and cant let cold air out due to this blockagethen its a defrost heater/thermostat on the evaporator coil issue
Jul 02, 2011 | Kenmore Side by Side Refrigerator
Not getting cold any where. Fan in frezzer runs, Fan blowing on comp. works, turned defrost time no help there. Had stater on comp. checked was told it was ok. What's next?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 08, 2011 | Roper RT14DKX Top Freezer Refrigerator
I have a Hotpoint HSS25IF and just finished cleaning and vacuuming the complete compressor and coil areas, the fan is running and all lights work but it is not cooling, what can I do?
ptc starting device may be bad are you hearing a clicking every feww minutes if so thats the ptc compresor relay.... otherwise the control board in back has failed ......make sure its not a defrost problem remove freezer wall and check frost pattern .... can u see just aluminum coils in freezer if so compressor isnt running and or is their a giant block of ice . if so defrost heater and thermister need replaced...
Feb 03, 2011 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Not cooling
your ptc overload on your compressor has gone out and needs replacement,locate the compressor and unplug the overload off the compressor and take it to an appliance parts place and purchase the correct replacement ptc overload and plug it back in and your good to go
Jun 18, 2010 | Hotpoint HSS25GFP Side by Side...
My Kenmore fridge is not cooling anymore and the freezer is not freezing also properly...everything else seems okay like the lights and I can hear the motor
your fans are running,but the compressor isn't,you need to replace the ptc overload relay on the compressor as this supplies start and run current for the compressor,it unplugs off the compressor body on the unit
Apr 11, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
LG LSC26905TT Side by Side Refrigerator Logo
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
