Question about Mitsubishi WS-55809 55" Rear Projection Television
If this is a projection tv then the bulbs may be out in the back, double check the mirror alignment in the back that reflects the image on the screen. if neither of these is the issue you will need to take it in for service. There is most likely something wrong with the board. Did this just happen or was there a power surge? I have had my home owners insurance replace my tv for a brown out we had. when working with any item that uses electricty, please be sure to take precautions aginst electric shock, TV's and Microwaves hold a lot of current even when not plugged in.
Posted on Sep 10, 2009
SOURCE: blue lines across screen sony tv
blown fues on the G board, that should fix my problem
and or might need to replace stk392 convergance amp ic's
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 05, 2007
SOURCE: no picture
Sound like you lost Vertical Deflection. Youshould not have a line across the screen because this could destroy the threeCRT Red, Green, and Blue (Picture tubes) if left on to long. There is a protection circuit built in to protect your CRT’s. Check on the PCB-SIGNALboard (Tuner located on this board) transistors Q-206 Collector should be around 1 Volt Base and Emitter 0V. If the voltage atthis point is greater then 5 Volts the Vertical output IC-401 (Mounted on heat sink 7 pin inline IC) is bad, Part # LA7845. Pin Voltages should be PIN 1= 0V, 2= 34V, 3= 32V, 4= 3V, 5= 3V, 6= 33v, 7= -6V. Data sheet located at http://pdf1.alldatasheet.com/datasheet-pdf/view/40357/SANYO/LA7845.html
Posted on Aug 16, 2008
SOURCE: 3 inch red area at top of screen and smaller blue area at bottom of screen
this would need a optical block. there would be no other way to solve this issue
Posted on Apr 19, 2009
SOURCE: blue spots
This is a Light Engine problem. Call a good TV Tech and explain the problem. These can be rebuilt for around $450. New ones are $800 to $1200.
Posted on Jul 31, 2009
Feb 01, 2016 | Mitsubishi Diamond 835 Wd-73835 73" 1080p...
Jul 23, 2017 | Sony Video Cameras
Jan 16, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Nov 27, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Jul 11, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Jun 30, 2009 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Jun 05, 2009 | Televison & Video
Jun 22, 2008 | Mitsubishi VS-6043 60" Rear Projection...
May 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mar 17, 2016 | Mitsubishi WS-55809 55" Rear Projection...
94 people viewed this question
