Question about Apple iPod touch
My ipod touch 2g with 3.0 firmware will not turn on
I have tried reseting it, putting it in dfu mode, charging it, restoring it does not work. When i plug it into my laptop it says device is unreconizable. PLEASE HELP
My ipod touch has gone really dark , like the brightness u cant even see anything . everything works but the screen. ive been into seetings but its nothing to do with that. what do i do
Posted on Sep 15, 2009
HI i am Isuru Medonza, i own an 8GB ipod touch 2G , a week ago, I updated it to the firmware 4.2.1, and I jailbroke it using Redsnow, Red snow asked me whether i wanted to put a new boot screen , and i...
There are a couple of things for you to try. First off just a couple of notes, the "Sleep Button" is the button on top of your iPod and the "Home Button" is the button on the front of your iPod. huntermaggar.jpg So to fix your problem you first need to restore it. But first we need to get iTunes to recognize it.
1.You can try restarting it by holding the sleep button and the home button until the whole iPod reboots. (Usually around 10 seconds)
  • After that try to plug your iPod into your computer again and try to restore it.
2. Try to put your iPod into "DFU" mode.
  • With your iPod powered off and plugged into your computer (plug it in and then power it off)
  • Hold the sleep button for 3 seconds.
  • While continuing to hold the sleep button, hold the home button and sleep button for 10 seconds.
  • Let go of the sleep button, but keep holding the home button for another 30 seconds.
After that your iPod should be in DFU mode which is factory settings and you should be able to use it with iTunes.
And the next time you want to downgrade it you should check out this video. This is what I used to downgrade my iPod touch 2g.
Jun 01, 2011 | Apple iPod touch
White screen on ipod touch 2g, even after a hard reset
sounds like you need to restore the ipod. put the ipod into DFU mode and follow the instructions on iTunes
May 02, 2011 | Apple iPod touch
MY APPLE IPOD TOUCH OF 8G & IT SAYS IPOD IS DISABLE CONNECT TO ITUNES WHERE THE COMPUTER I FIRST CONNECTED IT WITH IS SPOILED WHAT SHOULD I DO?
If the solution above doesn't work, try restoring your iPod. Firstly, make sure you have the same (or above) version of firmware on your computer somewhere. By doing the next step, you need to know that all data and settings will be erased from your device. If you are OK with this, put your iTouch into DFU mode by:
1. Plugging your device into your computer.
2. Holding down the power button for 3 seconds.
3. Without releasing the power button, hold down the home button for 10 seconds.
4. Release the power button, but keep holding the home button for 30 seconds.
Next, go to the iPod Touch panel in iTunes, and click on the "Restore" button. Now follow the on-screen prompts.
If you want to restore your firmware to a specific firmware (advanced users), shift-click the "Restore" button and select an ISPW firmware file to update it to.
Jun 18, 2010 | Apple iPod touch
How can i unlock my ipod touch? i forgot my passcode.
The only thing that could make your iPod touch work again is to put it to DFU mode and restore. I have a full instruction about that to guide you step by step, making sure that you're doing the right thing.
However, that process will wipe out all the data from your iPod, you won't even be able to sync or create a back-up because iTunes does not recognize any iPod that is passcode-locked.
That is also why you need to put your iPod to DFU mode first, so that iTunes can recognize it, to by-pass the fact that it is passcode-locked. And, once its in DFU mode, the only thing that you'll be able to do is to restore, nothing else. And you have no other choice.
Click here for instruction on how to put your iPod touch to DFU mode and restore.
For more iPod touch / iPhone tips, click here.
Feb 11, 2010 | Apple iPod touch
My iphone 2g currently running 2.0.2 firmware after jailbreak received msg on screen ''Repair Needed'' contact apple/support pls help
Contact apple and say you tried to downgrade your firmware but you downloaded the firmware from a internet site because iTunes wouldent download.
The error is in the CPU can be fixed by going into DFU mode and restoring .
Google "How to put iPhone/iPod Touch into DFU mode"
Oct 26, 2009 | Apple iPhone Smartphone
Is my iPod touch bricked? It is unresponsive
Well if its not responsive ya I am afraid its bricked. You might want to try to recover but it seems like you did that already i hate to spread bad news.
thanks please rate
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Oct 03, 2009 | Apple iPod touch
IPod Touch 8gb won't turn on
Have you tried putting it into DFU mode? From here you can restore your ipod.
Here is a great step by step guide on how to do it.
http://limitededitioniphone.com/how-to-put-the-iphone-into-dfu-mode/
Apr 13, 2009 | Apple iPod touch
Does not turn om
it's possible that you have a bad power switch circuit .
have you plugged an a/c charger into the ipod yet?
it should boot with an a/c charger.
also,
plug it into the computer and see if itune recognizes it, if so then your LCD is probably bad and you just don;t know it's on.
and if you have put the ipod into dfu mode it will come up on itunes as being in recovery mode.
go ahead and restore it, if you worried about a jailbreak, dont, you can jail break it easy after it's restored. but i would make sure you have a copy of your current firmware prior so you can restore to the some firmware or something close.
here is a link to a firmware for the 2g: ipod touch firmware
here are the steps to put the ipod in dfu mode:
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Plug the usb cable into the Ipod and NOT into the computer.
Hold the Home Button down for 5 second (do not release it)
Then Press and hold the Power Button for approx 10 secs (count them out)
Your iPod will reboot.
Release the power button and continue holding the Home button for an additional 27secs.
You may see the screen go blank or not.
Plug the USB end into the computer with itunes open.
Your ipod will mount in recovery mode.
When you go to press restore press the SHIFT key when you hit restore and choose the firmware you have downloaded.
Mar 11, 2009 | Apple iPod touch
Apple iPod touch Logo
314 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
