Question about Maytag MSD2732GR Side by Side Refrigerator
My fridge just stopped running after i cleaned the drain out
My fridge just stopped running after i cleaned out the drain in the freezer and vacumed the underside it ran for five minutes then quit and hasnt ran again for awhile it is not cold yet.
  • 74 Answers
Might of bump a wire
Posted on Sep 10, 2009
Water accumulating inside the fridge
hi kostas.
Condensation runs down the back of the fridge and collects in the gully sitting at the back of the fridge where the water is then channelled through the drain hole into a container which sits on the compressor, it's then evaporated away.
How to Stop Water Collecting in Your Fridge ' eSpares
https://www.espares.co.uk/advice/.../how-to-stop-water-collecting-in-your-fridge Water accumulating inside the fridge Google Search
Nov 07, 2017 | Refrigerators
I have a GE Profile fridge that is pooling water inside on the bottom portion of the fridge and dripping out onto the floor in front of the fridge. I checked the freezer portion of the fridge and found...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 14, 2011 | GE Refrigerators
My fridge keeps filling up with water, I pulled the bottom of the fridge out and vacumed, the tray underneath is dry and I guess the fridge isn't draining properly. How do I fix this?
Yes you are correct it is not drainind properly.
Remove the back panel in your freezer and at the bottom of the evaporator coil you will see a hole about ½” in diameter this is the drain tube. You might need to use some warm water to melt the ice and then run a wire being very careful not to puncture the hose and run it down the tube to free up the drain. This tube travel down to the bottom of your refrigerator to a pan sometimes located on top of the compressor or somewhere else down there. It collects the water there to evaporate. You can enter your model # at www.appliancehelponline.com for a diagram or illustration of your refrigerator. Not all models are available.
Apr 12, 2010 | Kenmore 64802 Top Freezer Refrigerator
American fridge/freezer - fridge stopped cooling, freezer side ok
Have you pulled out the refrigerator and cleaned or used a vacum cleaner to get out the dirt and dust off the back of the coils, or if the coils are underneath, you need to get an inexpensive appliance brush for fridge, and clean the coils under the fridge, pull off the panel on the front bottom of the fridge, get a flash light and look to see if the coils are covered in dust....may just need to vacum and use appliance brush underneath...this should be done at least one a year, you will notice your fridge running much better and cooling back to normal.......hope this helps......
Jan 05, 2010 | Refrigerators
My freezer is still freezing but the fridge is not cold. You can hear it running but nothing. HELP!
is the fan running in the freezer? if not replace fan .if not unplug fridge,,remove all inside pannels in freezing unit,,in the bac ,in the middle, on the bottom ,there is a drain that drains into the very bottom of fridge,is it like aice bottom across the bottom of the freezer?if so,use hot water to defrost all the ice and may be a hair dryer,water will melt and **** down the drain threw the drain tube,to the bottom of fridge into a shallow pan under the fridge,that slides out(could be messey).clean all bottom of freezer out good(crumbs mostley)that stop up drain and pour water threw drain a few time to clear drain good.reasemble and ur good to go.now if there is no ice and drain is good,you might find ice on coils,this means ur defrost timer is most likeely gone out ,just replace timer
Jul 04, 2009 | Electrolux Refrigerators
Freezer freezes, fridge below will not cool
if your freezer is still freezing fine, except for perhaps a slight softening of ice cream. this is a good sign. the second fan you are looking for is located behind the back wall of the freezer, emptying the freezer will gain you access to the screws to remove he panel. you should be able to hear the fan blowing when the freezer door is opened.if indeed the fan is blowing you may have frost building up on the rear panel, this would indicate a defrost problem( unit not self defrosting) and so much frost has built up that the air flow has been restricted to the refrig compartment
Nov 17, 2008 | Kenmore Refrigerators
Bosch intelligent frost free 40
The small drain pipe on the back of the fridge gets clogged, hence no drainage when defrosting, hence ice blocks the airflow between the freezer compartment and the fridge compartment.
Remove the rubber stop from the drain pipe and clean (can be found above the motor)
Defrost the fridge for a few days (it takes at least 48 hours). During this time, if you are not brave enough to remove the internal panels of the freezer and continually clean the water, check for water coming out and clean.
If during the defrost there is no water coming out the drain pipe, use about 2m of flexible and strong wire to clean the pipe.
The aim is to unblock the pipe once the ice has melted.
Jul 27, 2008 | Bosch Refrigerators
Maytag MSD2732GR Side by Side Refrigerator Logo
161 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
