Question about Sharp AR-156 Copier
How do I change the developer on a Sharp AR-156?
  • ltcol54 Sep 11, 2009
    Installed new developer in Sharp AR-156 but still have a maintenance lite indicating maint and developer still needed. How can I get the maint lites reset??
  • 146 Answers
Posted on Oct 20, 2009
Testimonial: "Sent exactly the procedure I was looking for to reset the developer light. Hope to try it later this week. If any problems I will advise. "
    Scholar:
  • 118 Answers
The developer sits in a small, black casing that houses the toner bottle. When you pull out the toner, look for a small, blue or green screw that holds the developer box in.
Once you pull the developer out, you'll notice three screws on the outer casing (two on top as you look down on the unit, plus one looking down into the opening where the toner bottle sits). Removed these screws and set them aside. You should now be able to pull the cover off the unit and expose the developer assembly.
Dump out the old toner in a plastic bag. Be careful, as it can spill out quite easily and it's a pain to clean up out of carpets. You'll want to invert the developer unit and use the plastic gear on the backside of the unit to spin the magnetic rod until all of the developer has been removed (be careful not to scratch the surface of this rod, as it's what holds the developer in place during copy processes).
Place the new developer into the open auger area of the unit. Put the cover back on and install the three screws you removed earlier. Place the developer assembly back into the body of the copier and screw the blue or green retaining screw back into place. Now you can re-install the toner bottle and start the copier back up.
Posted on Sep 10, 2009
Testimonial: "This kind of answer is truly valuable. Thank you!!"
3 Suggested Answers
  • 87 Answers
SOURCE: How do I change the developer for a Sharp AR-156?
It's part of a kit. You'll need to consult their support site or a tech to get the part number and pricing. It's all disposable these days...
  • 153 Answers
SOURCE: Sharp AR-156 Developer light stays on.but the
in service mode
Posted on Sep 28, 2009
Code CH s.v.p.
i really need a code to reset AR-sharp 5320E which display developer light with toner light together at the same time
Jan 30, 2011 | Sharp AR-156 Copier
Sharp AR-156, with code H-4
H4: Heat roller abnormally low
temperature.
cause:-
Thermistor failure
Heater lamp failure
MCU PWB failure
Thermostat failure
Power supply failure
Execute Simulation 14 to reset
Dec 21, 2010 | Sharp AR-156 Copier
Developer in my sharp ar-5520s mfp
if you want change developer,pullout toner cartridge open blue screw,remove developer unit ,open 3 screws,remove black cover remove old developer and add new
Apr 30, 2010 | Sharp SF 2020 Copier
Sharp AR 235, output light
You have to change the Developer in the developing unit. code is: AR271D
This procedure must be done by a copier tech.
Feb 15, 2010 | Sharp AR-235 Copier
Sharp AR-156 shows F2 error. I have a new ink cartridge. What's the problem?
f2 problem from toner ,plese check and fix orginal toner
Nov 11, 2009 | Sharp AR-156 Copier
How do I reset the maint lites on a Sharp AR-156? Replaced developer bvut still have maint lites.
http://free-manuals.ru/download/53f901ad306715dee588d2c0e77ea8cd
please, take the manual data/ Yous descriptions is too aa litle? i do not undestend, what the lite is on? goodgold@inbox.ru i am Sergey, write me
Sep 11, 2009 | Sharp AR-156 Copier
Sep 10, 2009 | Sharp AR-156 Copier
SHARP AR 5012 developer reset
i have a sharp sf 1025 , and i want to reset developer conter? can u help me pls
Jun 25, 2009 | Sharp AR-5320 Black and White Copier
Sharp copier ar-5316
That unit uses an AR-016TD Toner/Developer Cartridge. The developer is changed each time you replace the toner. To remove the drum unit open the right side cover, then the front cover, remove the TD cartridge, loosen the green screw on the front of the developer unit housing just above the TD slot. carefully remove the DV unit without tipping or you will spill out the existing DV. Then you can pull out the drum unit. There may be a green screw on the drum that must be loosened but I don't think so on that particular model. Installation is the reverse of removal.
Jan 05, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-156 Copier Logo
168 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
